In my application I want to Encode 1928*1080 (16:9 )size video buffer (UYVY format) to 720*576 (4:3) H264 stream using IQSV encoder.
What parameter in VPP, I have to set encoder perform downscaling in such a way, there is letter box at top and bottom.
I tried to set following parameter in VPP
mfxStatus CEncodingPipeline::InitMfxVppParams(sInputParams *pInParams)
MSDK_CHECK_POINTER(pInParams, MFX_ERR_NULL_PTR);
// specify memory type
if (pInParams->bd3dAlloc)
m_mfxVppParams.IOPattern = MFX_IOPATTERN_IN_VIDEO_MEMORY | MFX_IOPATTERN_OUT_VIDEO_MEMORY;
else
m_mfxVppParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY | MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
// input frame info
m_mfxVppParams.vpp.In.FourCC = MFX_FOURCC_NV12;
m_mfxVppParams.vpp.In.PicStruct = 2;
ConvertFrameRate(25,25,1);
m_mfxVppParams.vpp.In.Width = 1920;
m_mfxVppParams.vpp.In.Height = 1088;
m_mfxVppParams.vpp.In.CropW = 1920;
m_mfxVppParams.vpp.In.CropH = 1080;
// fill output frame info
memcpy(&m_mfxVppParams.vpp.Out, &m_mfxVppParams.vpp.In, sizeof(mfxFrameInfo));
// only resizing is supported
m_mfxVppParams.vpp.Out.Width = 720
m_mfxVppParams.vpp.Out.Height = 576
m_mfxVppParams.vpp.Out.CropX = 0;
m_mfxVppParams.vpp.Out.CropY = 36;
m_mfxVppParams.vpp.Out.CropW = 720;
m_mfxVppParams.vpp.Out.CropH = 504;
// configure and attach external parameters
AllocAndInitVppDoNotUse();
m_VppExtParams.push_back((mfxExtBuffer *)&m_VppDoNotUse);
mfxStatus CEncodingPipeline::AllocAndInitVppDoNotUse()
m_VppDoNotUse.NumAlg = 4;
m_VppDoNotUse.AlgList = new mfxU32 [m_VppDoNotUse.NumAlg];
MSDK_CHECK_POINTER(m_VppDoNotUse.AlgList, MFX_ERR_MEMORY_ALLOC);
m_VppDoNotUse.AlgList[0] = MFX_EXTBUFF_VPP_DENOISE; // turn off denoising (on by default)
m_VppDoNotUse.AlgList[1] = MFX_EXTBUFF_VPP_SCENE_ANALYSIS; // turn off scene analysis (on by default)
m_VppDoNotUse.AlgList[2] = MFX_EXTBUFF_VPP_DETAIL; // turn off detail enhancement (on by default)
m_VppDoNotUse.AlgList[3] = MFX_EXTBUFF_VPP_PROCAMP; // turn off processing amplified (on by default)
return MFX_ERR_NONE;
} // CEncodingPipeline::AllocAndInitVppDoNotUse()
Renit Shah
I am not seeing any issue using NV12 buffer input and output with VPP. How are you converting your UYVY format buffer to VPP Input? What do you observe as an output?
I believe you have the right size and crop parameters to achieve what you want (letterbox).
Hello Tony,
Thanks for reply.
I am converting UYVY to NV12 using third party color converter.
please find my encoder setting also
m_mfxEncParams.mfx.CodecId =MFX_CODEC_MPEG2;
m_mfxEncParams.mfx.TargetUsage = pInParams->nTargetUsage; // trade-off between quality and speed
m_mfxEncParams.mfx.TargetKbps = 8000; // in Kbps
m_mfxEncParams.mfx.MaxKbps = 0;
m_mfxEncParams.mfx.RateControlMethod = MFX_RATECONTROL_CBR;
ConvertFrameRate(25, 25, 1);
m_mfxEncParams.mfx.EncodedOrder = 0; // binary flag, 0 signals encoder to take frames in display order
m_mfxEncParams.mfx.GopOptFlag = MFX_GOP_CLOSED ;
m_mfxEncParams.mfx.IdrInterval = 1;//Keep IdrInterval as 0 to make all I frames as IDR-REF frames
m_mfxEncParams.mfx.DecodedOrder = 0; //Taken from Mainconcept
m_mfxEncParams.mfx.GopRefDist = 2 + 1; //To set Number of B-Frames,
//If Number of B-Frame needs to be N then GopRefDist should be N+1
m_mfxEncParams.mfx.GopPicSize = 16
m_mfxEncParams.IOPattern = MFX_IOPATTERN_IN_VIDEO_MEMORY;
else
m_mfxEncParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY;
// frame info parameters
m_mfxEncParams.mfx.FrameInfo.FourCC = MFX_FOURCC_NV12;
m_mfxEncParams.mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420;
m_mfxEncParams.mfx.FrameInfo.PicStruct = pInParams->nPicStruct;
m_mfxEncParams.mfx.FrameInfo.AspectRatioW = 4 * 576;
m_mfxEncParams.mfx.FrameInfo.AspectRatioH = 3 * 720;
// set frame size and crops
// width must be a multiple of 16
// height must be a multiple of 16 in case of frame picture and a multiple of 32 in case of field picture
m_mfxEncParams.mfx.FrameInfo.Width = MSDK_ALIGN16(720);
m_mfxEncParams.mfx.FrameInfo.Height = (MFX_PICSTRUCT_PROGRESSIVE == m_mfxEncParams.mfx.FrameInfo.PicStruct)?
MSDK_ALIGN16(576) : MSDK_ALIGN32(576);
m_mfxEncParams.mfx.FrameInfo.CropX = 0;
m_mfxEncParams.mfx.FrameInfo.CropY = 0;
m_mfxEncParams.mfx.FrameInfo.CropW = 720;
m_mfxEncParams.mfx.FrameInfo.CropH = 576;
Thanks & Regards
Renit
Hi Renit,
The encode parameters should not matter, as the input to the encode step is just a 720x576 uncompressed frame.
What is the actual issue you are seeing, as I see this scaling and letterboxing working well? What does your output look like?
