I used the 2017 SDK R1 with the following command:
sample_encode.exe mvc -rgb4 -i L.rgb -i R.rgb -o BRGB.mvc -w 1920 -h 1080
The ouput file has "noise" on the upper half while playing.
But the display will be ok when I encode each file separately with the following command:
sample_encode.exe h264 -rgb4 -i L.rgb -o BRGB.mp4 -w 1920 -h 1080
Furthemore, the display will also be ok when I convert L.rgb and R.rgb into L.yuv and R.yuv then use the following command:
sample_encode.exe mvc -nv12 -i L.yuv -i R.yuv -o BRGB.mvc -w 1920 -h 1080
I would like to know is it possibile to use RGB4 streams to make a MVC file with correct display?
