For MPEG2 encode, the streams generated by MSDK do not appear to obey main profile/main level constraints on vbvsize.
Table 8-14 in ISO_IEC_13818-2 limits vbv buffer size to 112*16384 = 1835008 bits for main profile/main level.
In the attached code, I setup the encoder for main profile/main level and parse the coded output to determine what value the encoder specifies. I see the results below. The software version specifies a size of 134*16384 bits and the hardware version specifies136*16384.
Using SW version 1.8
3 buffers suggested
Starting frame encode
Frame 000 of type I is 7640 bytes
Sequence Header Code
Extension Start Code
Sequence Extension
Main Profile
Main Level
vbvsz = 134
Using HW version 1.7
6 buffers suggested
Frame 000 of type I is 5627 bytes
Sequence Extension
Main Profile
Main Level
vbvsz = 136
This leads me to a couple of questions:
Below are the stats on my test system:
Graphics Devices:
Name Version State
Intel(R) HD Graphics 4600 10.18.10.3345 Active
VNC Mirror Driver 1.8.0.0 08
NVIDIA GeForce GTX 650 9.18.13.1407 08
System info:
CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
OS: Microsoft Windows Embedded Standard
Arch: 64-bit
With more investigation, it seems the vbv size is directly proportional to output bit rate. For software version 1.7 I see the following relationship:
OutRate VBVSize 1500 kb/s 67 3000 kb/s 134 6000 kb/s 267 15000 kb/s 667
So, for a MPML stream at maximum rate of 15 Mb/s, the encoder stream specifies a vbv size more than 5 times larger than allowed by that profile and level. In order to match the VBV size constraints, the output rate has to be <= 2500 kb/s.
Am I missing something here? I assume this is relationship is going to be true for all profiles and levels?
I haven't had a chance to look at this in detail yet, but the MSDK implementation can change (increase) the profile/level and provide warning the it needed to adjust parameters. If it is not modifying the profile/level and adjusting the size, it should not be producing values beyond the spec. I'll investigate. Thanks for the detailed information.
Are there any updates available on this issue?
This question has been escalated, and I will follow up today. Thank you for checking on status.
Hi Tony,
Getting same issue for VBV buffer size generate by encoder in elementary stream.
We are getting: For 5Mbps video , VBVsize= 227.
We need to limit VBV buffer size to 112.
I am using Media SDK 2015 R6.
Please do needful.
Praveen K.
HI Praveen,
I apologize, as I had thought this tread was updated long ago.
The issue was fixed in newer Intel(r) HD Graphics drivers. I see your original report mentioned driver version 3345 and my (old) notes mentioned fix should be in any driver newer than 3368.
The very latest drivers (4414) for Intel(r) HD Graphics 4600 are available here:
Please let us know if you still see the issue.
-Tony
