Problem with media SDK 2013
Nicolas_G_1
I have used the sample_videoconf sample of the media SDK 2013 to integrate h264 compression into a video acquisition software.
It works well but on some occasions there is a random initialization problem.
The setup is the following :
- 4 video streams coming from digital cameras (1024x1024 @ 50 fps)
- encoder set to level 4 (balanced)
- 5 min of video stream encoded each hours
Sometimes the system will run without problem for more than 40 hours, sometimes it will run only 10 hours or less.
The issue seems related to the initialization of the video pipeline.
I added logs to retrieve more informations, but meanwhile has someone encontered similar problems with sample_videoconf ?
Surbhi_M_Intel
Hi Nicolas,
It would be great if you can add more detail-
Few things you might wanna consider-
  • Please upgrade to the latest driver for you system if you haven't already. Latest drivers can be downloaded from here - https://downloadcenter.intel.com. With every driver release, lot of fixes get included.
  • We have release Media Server Studio 2015 R3 Release which has many fixes to our products.
-Surbhi
