Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
Problem with second process started from not root user
ANdrey_R_1
I compile ffmpeg with qsv supporting (MEDIASDK 2018R1) and try run:
ffmpeg -i sintel_trailer-1080p.mp4 -vcodec h264_qsv -init_hw_device qsv:hw out_qsv.mp4 Twice and more time from root user and is works
But when i run second process from any other user i have an error
libva info: VA-API version 1.0.0
open lib: No such file or directory
libva info: va_getDriverName() returns 1
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_0
get chip id failed: -1 [13]
param: 4, val: 0
libva error: /opt/intel/mediasdk/lib64/iHD_drv_video.so init failed
libva info: va_openDriver() returns 18
What does it mean ? How to fix ?
CentOS Linux release 7.4.1708 (Core)
Linux localhost.localdomain 3.10.0-693.21.1.el7.x86_64 #1 SMP
libva info: va_getDriverName() returns 0
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.0 (libva )
vainfo: Driver version: 16.8.69021-ubit
vainfo: Supported profile and entrypoints
      VAProfileNone                   : VAEntrypointVideoProc
      VAProfileNone                   : <unknown entrypoint>
      VAProfileMPEG2Simple            : VAEntrypointVLD
      VAProfileMPEG2Simple            : VAEntrypointEncSlice
      VAProfileMPEG2Main              : VAEntrypointVLD
      VAProfileMPEG2Main              : VAEntrypointEncSlice
      VAProfileH264Main               : VAEntrypointVLD
      VAProfileH264Main               : VAEntrypointEncSlice
      VAProfileH264Main               : <unknown entrypoint>
      VAProfileH264Main               : VAEntrypointEncSliceLP
      VAProfileH264High               : VAEntrypointVLD
      VAProfileH264High               : VAEntrypointEncSlice
      VAProfileH264High               : <unknown entrypoint>
      VAProfileH264High               : VAEntrypointEncSliceLP
      VAProfileVC1Simple              : VAEntrypointVLD
      VAProfileVC1Main                : VAEntrypointVLD
      VAProfileVC1Advanced            : VAEntrypointVLD
      VAProfileJPEGBaseline           : VAEntrypointVLD
      VAProfileJPEGBaseline           : VAEntrypointEncPicture
      VAProfileH264ConstrainedBaseline: VAEntrypointVLD
      VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline: <unknown entrypoint>
      VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP
      VAProfileVP8Version0_3          : VAEntrypointVLD
      VAProfileHEVCMain               : VAEntrypointVLD
      VAProfileHEVCMain               : VAEntrypointEncSlice
      VAProfileHEVCMain               : <unknown entrypoint>
export PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin/
export LIBVA_DRIVERS_PATH=/opt/intel/mediasdk/lib64
export LIBVA_DRIVER_NAME=iHD
export MFX_HOME=/opt/intel/mediasdk
TurtleCrazy
Make sure that the user is a member of the video group. That means, the process  has read and write rights on `/dev/dri/*` devices.
Mark_L_Intel1
Hi Andrey,
I saw the following line in the error message:
"get chip id failed: -1 [13]"
What processor are you using? Note we don't support KabyLake process in Linux.
Mark
ANdrey_R_1
Liu, Mark (Intel) wrote:
Hi Andrey,
Mark
Thats problem what first run of ffmpeg it works but on second on any user except root i got this error !
I use i7 6700
ANdrey_R_1
Is member because the first run is works !
It happens on any linux and any kernel !
Also some problems with motherboards, i success only with asus z170
Mark_L_Intel1
Good, it seems like the missing member of video group also causes device id error. This is a good learning.
Mark
ANdrey_R_1
Mark
You mean what simple adding user to the video group members is solution ?
I using command
usermod -a -G video {username}
but is not helps ! Second request of ffmpeg giving error listed before.
Mark_L_Intel1
Hi Andrey,
Sorry for the late response and I might mis-interrupt your question before.
When you got ffmpeg failure under the normal user, could you run sample_multi_transcode?
To run it, download the sample package from here, uncompress it to a local folder, it should have pre-built binary, you should be able to run following command directly:
> sample_multi_transcode -i::h264 <input file> -o::h264 <output file>
I am curious how did you install the package? Which package are you using, Media Server Studio or Media SDK for embedded Linux?
Mark
