Hi.
I've bought intel media SDK for linux and following hardware: Intel S1200V3RPL motherboard and Intel Xeon E3-1200 v3 (rev 06) CPU.
Here is what I see in my server:
root@ubuntu:/opt/intel/mediasdk/samples/_bin/x64# lspci -nn |grep VGA
02:00.0 VGA compatible controller [0300]: Matrox Electronics Systems Ltd. MGA G200e [Pilot] ServerEngines (SEP1) [102b:0522] (rev 05)
ls /dev/dri/
There are no files in /dev/dri and VGA controller differs from what does PDF file in SDK says.
Examples are not running:
root@ubuntu:/opt/intel/mediasdk/samples/_bin/x64# /sample_decode_drm h264 -i bunny.h264
Return on error: error code -3, /home/msdk/mdp_msdk-samples/samples/sample_decode/src/pipeline_decode.cpp 158
Return on error: error code 1, /home/msdk/mdp_msdk-samples/samples/sample_decode/src/sample_decodecpp 341
My questions are:
1) is hardware quicksync compatible? I was told that it is compatible before I bought it, but right now I'm not 100% sure
2) what are my steps for troubleshooting this installation? Maybe I need to do something to enable dri?
- « Previous
- 1
- 2
- Next »
Thank you!
I will do it right now.
Very, very cool! Thanks a lot for your help! 2015R2 really helped, thanks for your work! root@ubuntu:/opt/intel/mediasdk/samples/_bin/x64# ./sample_decode_drm h264 -hw -i bunny.h264 -o out.yuv libva info: VA-API version 0.34.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so libva info: Found init function __vaDriverInit_0_32 libva info: va_openDriver() returns 0 Intel(R) Media SDK Decoding Sample Version 5.0.1603344.93446 Input video AVC Output format YUV420 Resolution 240x160 Crop X,Y,W,H 0,0,0,0 Frame rate 24.00 Memory type system MediaSDK impl hw MediaSDK version 1.10 Decoding started Frame number: 1440, fps: 772.493, fread_fps: 0.000, fwrite_fps: 1151.6575 Decoding finished
Hello Maksim - Very glad you got it working. Hope you enjoy the product! If you have any questions, let us know.
Where you need to enter a trial key? What file?
test
- « Previous
- 1
- 2
- Next »
