Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
QSV and ffmpeg C++ example
I'm trying to use qsv from ffmpeg with an example i found if ffmpeg src, but it isnt work for me, could you suggest me another one example or say what i do wrong?
When i used this example i had an output:
[AVHWFramesContext @ 048F29E0] Error synchronizing the operation: -3
Error transferring the data to system memory
[AVHWFramesContext @ 048F29E0] Error synchronizing the operation: -2
if i change in function ret = av_hwdevice_ctx_create(&decode.hw_device_ref, AV_HWDEVICE_TYPE_QSV, "auto", NULL, 0) "auto" to "auto_any" its starts work but it using my Nvidia? not Intel Gpu....what I do wrong?
There is an example src i used:
 * Copyright (c) 2015 Anton Khirnov
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 * THE SOFTWARE.
 * @file
 * Intel QSV-accelerated H.264 decoding example.
 * @example qsvdec.c
 * This example shows how to do QSV-accelerated H.264 decoding with output
 * frames in the GPU video surfaces.
#include "config.h"
#include <stdio.h>
#include "libavformat/avformat.h"
#include "libavformat/avio.h"
#include "libavcodec/avcodec.h"
#include "libavutil/buffer.h"
#include "libavutil/error.h"
#include "libavutil/hwcontext.h"
#include "libavutil/hwcontext_qsv.h"
#include "libavutil/mem.h"
typedef struct DecodeContext {
    AVBufferRef *hw_device_ref;
} DecodeContext;
static int get_format(AVCodecContext *avctx, const enum AVPixelFormat *pix_fmts)
    while (*pix_fmts != AV_PIX_FMT_NONE) {
        if (*pix_fmts == AV_PIX_FMT_QSV) {
            DecodeContext *decode = avctx->opaque;
            AVHWFramesContext  *frames_ctx;
            AVQSVFramesContext *frames_hwctx;
            int ret;
            /* create a pool of surfaces to be used by the decoder */
            avctx->hw_frames_ctx = av_hwframe_ctx_alloc(decode->hw_device_ref);
            if (!avctx->hw_frames_ctx)
                return AV_PIX_FMT_NONE;
            frames_ctx   = (AVHWFramesContext*)avctx->hw_frames_ctx->data;
            frames_hwctx = frames_ctx->hwctx;
            frames_ctx->format            = AV_PIX_FMT_QSV;
            frames_ctx->sw_format         = avctx->sw_pix_fmt;
            frames_ctx->width             = FFALIGN(avctx->coded_width,  32);
            frames_ctx->height            = FFALIGN(avctx->coded_height, 32);
            frames_ctx->initial_pool_size = 32;
            frames_hwctx->frame_type = MFX_MEMTYPE_VIDEO_MEMORY_DECODER_TARGET;
            ret = av_hwframe_ctx_init(avctx->hw_frames_ctx);
            if (ret < 0)
            return AV_PIX_FMT_QSV;
        pix_fmts++;
    fprintf(stderr, "The QSV pixel format not offered in get_format()\n");
static int decode_packet(DecodeContext *decode, AVCodecContext *decoder_ctx,
                         AVFrame *frame, AVFrame *sw_frame,
                         AVPacket *pkt, AVIOContext *output_ctx)
    int ret = 0;
    ret = avcodec_send_packet(decoder_ctx, pkt);
    if (ret < 0) {
        fprintf(stderr, "Error during decoding\n");
        return ret;
    while (ret >= 0) {
        int i, j;
        ret = avcodec_receive_frame(decoder_ctx, frame);
        if (ret == AVERROR(EAGAIN) || ret == AVERROR_EOF)
            break;
        else if (ret < 0) {
            return ret;
        /* A real program would do something useful with the decoded frame here.
         * We just retrieve the raw data and write it to a file, which is rather
         * useless but pedagogic. */
        ret = av_hwframe_transfer_data(sw_frame, frame, 0);
        if (ret < 0) {
            fprintf(stderr, "Error transferring the data to system memory\n");
            goto fail;
        for (i = 0; i < FF_ARRAY_ELEMS(sw_frame->data) && sw_frame->data; i++)
            for (j = 0; j < (sw_frame->height >> (i > 0)); j++)
                avio_write(output_ctx, sw_frame->data + j * sw_frame->linesize, sw_frame->width);
fail:
        av_frame_unref(sw_frame);
        av_frame_unref(frame);
        if (ret < 0)
            return ret;
    return 0;
int main(int argc, char **argv)
    AVFormatContext *input_ctx = NULL;
    AVStream *video_st = NULL;
    AVCodecContext *decoder_ctx = NULL;
    const AVCodec *decoder;
    AVPacket pkt = { 0 };
    AVFrame *frame = NULL, *sw_frame = NULL;
    DecodeContext decode = { NULL };
    AVIOContext *output_ctx = NULL;
    int ret, i;
    av_register_all();
    if (argc < 3) {
        fprintf(stderr, "Usage: %s <input file> <output file>\n", argv[0]);
        return 1;
    /* open the input file */
    ret = avformat_open_input(&input_ctx, argv[1], NULL, NULL);
    if (ret < 0) {
        fprintf(stderr, "Cannot open input file '%s': ", argv[1]);
        goto finish;
    /* find the first H.264 video stream */
    for (i = 0; i < input_ctx->nb_streams; i++) {
        AVStream *st = input_ctx->streams;
        if (st->codecpar->codec_id == AV_CODEC_ID_H264 && !video_st)
            video_st = st;
        else
            st->discard = AVDISCARD_ALL;
    if (!video_st) {
        fprintf(stderr, "No H.264 video stream in the input file\n");
        goto finish;
    /* open the hardware device */
                                 "auto", NULL, 0);
    if (ret < 0) {
        fprintf(stderr, "Cannot open the hardware device\n");
        goto finish;
    /* initialize the decoder */
    decoder = avcodec_find_decoder_by_name("h264_qsv");
    if (!decoder) {
        fprintf(stderr, "The QSV decoder is not present in libavcodec\n");
        goto finish;
    decoder_ctx = avcodec_alloc_context3(decoder);
    if (!decoder_ctx) {
        ret = AVERROR(ENOMEM);
        goto finish;
    decoder_ctx->codec_id = AV_CODEC_ID_H264;
    if (video_st->codecpar->extradata_size) {
        decoder_ctx->extradata = av_mallocz(video_st->codecpar->extradata_size +
                                            AV_INPUT_BUFFER_PADDING_SIZE);
        if (!decoder_ctx->extradata) {
            goto finish;
        memcpy(decoder_ctx->extradata, video_st->codecpar->extradata,
               video_st->codecpar->extradata_size);
        decoder_ctx->extradata_size = video_st->codecpar->extradata_size;
    decoder_ctx->refcounted_frames = 1;
    decoder_ctx->opaque      = &decode;
    decoder_ctx->get_format  = get_format;
    ret = avcodec_open2(decoder_ctx, NULL, NULL);
    if (ret < 0) {
        fprintf(stderr, "Error opening the decoder: ");
        goto finish;
    /* open the output stream */
    ret = avio_open(&output_ctx, argv[2], AVIO_FLAG_WRITE);
    if (ret < 0) {
        fprintf(stderr, "Error opening the output context: ");
        goto finish;
    frame    = av_frame_alloc();
    sw_frame = av_frame_alloc();
    if (!frame || !sw_frame) {
        goto finish;
    /* actual decoding */
    while (ret >= 0) {
        ret = av_read_frame(input_ctx, &pkt);
        if (ret < 0)
            break;
        if (pkt.stream_index == video_st->index)
            ret = decode_packet(&decode, decoder_ctx, frame, sw_frame, &pkt, output_ctx);
        av_packet_unref(&pkt);
    /* flush the decoder */
    pkt.data = NULL;
    pkt.size = 0;
finish:
    if (ret < 0) {
        char buf[1024];
        av_strerror(ret, buf, sizeof(buf));
        fprintf(stderr, "%s\n", buf);
    avformat_close_input(&input_ctx);
    av_frame_free(&frame);
    av_frame_free(&sw_frame);
    avcodec_free_context(&decoder_ctx);
    av_buffer_unref(&decode.hw_device_ref);
    avio_close(output_ctx);
    return ret;
Highlighted
I think you may want to check your CPU is supported by MSDK in release note.
https://software.intel.com/sites/default/files/media_server_studio_essentials_release_notes_linux.pd...
Zachary
