I'm trying to use qsv from ffmpeg with an example i found if ffmpeg src, but it isnt work for me, could you suggest me another one example or say what i do wrong?
When i used this example i had an output:
[AVHWFramesContext @ 048F29E0] Error synchronizing the operation: -3
Error transferring the data to system memory
[AVHWFramesContext @ 048F29E0] Error synchronizing the operation: -2
if i change in function ret = av_hwdevice_ctx_create(&decode.hw_device_ref, AV_HWDEVICE_TYPE_QSV, "auto", NULL, 0) "auto" to "auto_any" its starts work but it using my Nvidia? not Intel Gpu....what I do wrong?
There is an example src i used:
/* * Copyright (c) 2015 Anton Khirnov * * Permission is hereby granted, free of charge, to any person obtaining a copy * of this software and associated documentation files (the "Software"), to deal * in the Software without restriction, including without limitation the rights * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell * copies of the Software, and to permit persons to whom the Software is * furnished to do so, subject to the following conditions: * * The above copyright notice and this permission notice shall be included in * all copies or substantial portions of the Software. * * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN * THE SOFTWARE. */ /** * @file * Intel QSV-accelerated H.264 decoding example. * * @example qsvdec.c * This example shows how to do QSV-accelerated H.264 decoding with output * frames in the GPU video surfaces. */ #include "config.h" #include <stdio.h> #include "libavformat/avformat.h" #include "libavformat/avio.h" #include "libavcodec/avcodec.h" #include "libavutil/buffer.h" #include "libavutil/error.h" #include "libavutil/hwcontext.h" #include "libavutil/hwcontext_qsv.h" #include "libavutil/mem.h" typedef struct DecodeContext { AVBufferRef *hw_device_ref; } DecodeContext; static int get_format(AVCodecContext *avctx, const enum AVPixelFormat *pix_fmts) { while (*pix_fmts != AV_PIX_FMT_NONE) { if (*pix_fmts == AV_PIX_FMT_QSV) { DecodeContext *decode = avctx->opaque; AVHWFramesContext *frames_ctx; AVQSVFramesContext *frames_hwctx; int ret; /* create a pool of surfaces to be used by the decoder */ avctx->hw_frames_ctx = av_hwframe_ctx_alloc(decode->hw_device_ref); if (!avctx->hw_frames_ctx) return AV_PIX_FMT_NONE; frames_ctx = (AVHWFramesContext*)avctx->hw_frames_ctx->data; frames_hwctx = frames_ctx->hwctx; frames_ctx->format = AV_PIX_FMT_QSV; frames_ctx->sw_format = avctx->sw_pix_fmt; frames_ctx->width = FFALIGN(avctx->coded_width, 32); frames_ctx->height = FFALIGN(avctx->coded_height, 32); frames_ctx->initial_pool_size = 32; frames_hwctx->frame_type = MFX_MEMTYPE_VIDEO_MEMORY_DECODER_TARGET; ret = av_hwframe_ctx_init(avctx->hw_frames_ctx); if (ret < 0) return AV_PIX_FMT_NONE; return AV_PIX_FMT_QSV; } pix_fmts++; } fprintf(stderr, "The QSV pixel format not offered in get_format()\n"); return AV_PIX_FMT_NONE; } static int decode_packet(DecodeContext *decode, AVCodecContext *decoder_ctx, AVFrame *frame, AVFrame *sw_frame, AVPacket *pkt, AVIOContext *output_ctx) { int ret = 0; ret = avcodec_send_packet(decoder_ctx, pkt); if (ret < 0) { fprintf(stderr, "Error during decoding\n"); return ret; } while (ret >= 0) { int i, j; ret = avcodec_receive_frame(decoder_ctx, frame); if (ret == AVERROR(EAGAIN) || ret == AVERROR_EOF) break; else if (ret < 0) { fprintf(stderr, "Error during decoding\n"); return ret; } /* A real program would do something useful with the decoded frame here. * We just retrieve the raw data and write it to a file, which is rather * useless but pedagogic. */ ret = av_hwframe_transfer_data(sw_frame, frame, 0); if (ret < 0) { fprintf(stderr, "Error transferring the data to system memory\n"); goto fail; } for (i = 0; i < FF_ARRAY_ELEMS(sw_frame->data) && sw_frame->data; i++) for (j = 0; j < (sw_frame->height >> (i > 0)); j++) avio_write(output_ctx, sw_frame->data + j * sw_frame->linesize, sw_frame->width); fail: av_frame_unref(sw_frame); av_frame_unref(frame); if (ret < 0) return ret; } return 0; } int main(int argc, char **argv) { AVFormatContext *input_ctx = NULL; AVStream *video_st = NULL; AVCodecContext *decoder_ctx = NULL; const AVCodec *decoder; AVPacket pkt = { 0 }; AVFrame *frame = NULL, *sw_frame = NULL; DecodeContext decode = { NULL }; AVIOContext *output_ctx = NULL; int ret, i; av_register_all(); if (argc < 3) { fprintf(stderr, "Usage: %s <input file> <output file>\n", argv[0]); return 1; } /* open the input file */ ret = avformat_open_input(&input_ctx, argv[1], NULL, NULL); if (ret < 0) { fprintf(stderr, "Cannot open input file '%s': ", argv[1]); goto finish; } /* find the first H.264 video stream */ for (i = 0; i < input_ctx->nb_streams; i++) { AVStream *st = input_ctx->streams; if (st->codecpar->codec_id == AV_CODEC_ID_H264 && !video_st) video_st = st; else st->discard = AVDISCARD_ALL; } if (!video_st) { fprintf(stderr, "No H.264 video stream in the input file\n"); goto finish; } /* open the hardware device */ ret = av_hwdevice_ctx_create(&decode.hw_device_ref, AV_HWDEVICE_TYPE_QSV, "auto", NULL, 0); if (ret < 0) { fprintf(stderr, "Cannot open the hardware device\n"); goto finish; } /* initialize the decoder */ decoder = avcodec_find_decoder_by_name("h264_qsv"); if (!decoder) { fprintf(stderr, "The QSV decoder is not present in libavcodec\n"); goto finish; } decoder_ctx = avcodec_alloc_context3(decoder); if (!decoder_ctx) { ret = AVERROR(ENOMEM); goto finish; } decoder_ctx->codec_id = AV_CODEC_ID_H264; if (video_st->codecpar->extradata_size) { decoder_ctx->extradata = av_mallocz(video_st->codecpar->extradata_size + AV_INPUT_BUFFER_PADDING_SIZE); if (!decoder_ctx->extradata) { ret = AVERROR(ENOMEM); goto finish; } memcpy(decoder_ctx->extradata, video_st->codecpar->extradata, video_st->codecpar->extradata_size); decoder_ctx->extradata_size = video_st->codecpar->extradata_size; } decoder_ctx->refcounted_frames = 1; decoder_ctx->opaque = &decode; decoder_ctx->get_format = get_format; ret = avcodec_open2(decoder_ctx, NULL, NULL); if (ret < 0) { fprintf(stderr, "Error opening the decoder: "); goto finish; } /* open the output stream */ ret = avio_open(&output_ctx, argv[2], AVIO_FLAG_WRITE); if (ret < 0) { fprintf(stderr, "Error opening the output context: "); goto finish; } frame = av_frame_alloc(); sw_frame = av_frame_alloc(); if (!frame || !sw_frame) { ret = AVERROR(ENOMEM); goto finish; } /* actual decoding */ while (ret >= 0) { ret = av_read_frame(input_ctx, &pkt); if (ret < 0) break; if (pkt.stream_index == video_st->index) ret = decode_packet(&decode, decoder_ctx, frame, sw_frame, &pkt, output_ctx); av_packet_unref(&pkt); } /* flush the decoder */ pkt.data = NULL; pkt.size = 0; ret = decode_packet(&decode, decoder_ctx, frame, sw_frame, &pkt, output_ctx); finish: if (ret < 0) { char buf[1024]; av_strerror(ret, buf, sizeof(buf)); fprintf(stderr, "%s\n", buf); } avformat_close_input(&input_ctx); av_frame_free(&frame); av_frame_free(&sw_frame); avcodec_free_context(&decoder_ctx); av_buffer_unref(&decode.hw_device_ref); avio_close(output_ctx); return ret; }
- Tags:
- Development Tools
- Graphics
- Intel® Media SDK
- Intel® Media Server Studio
- Media Processing
- Optimization
I think you may want to check your CPU is supported by MSDK in release note.
Zachary
