QSV dowsn't work, MSS2017 on Ubuntu 16
Milan_C_
Ubuntu 16.04.1 LTS
Linux Stream.local 4.4.0 #1 SMP Wed Sep 7 12:00:18 CEST 2016 x86_64 x86_64 x86_64 GNU/Linux
CPU0: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (family: 0x6, model: 0x3c, stepping: 0x3)
- Media Server Studio 2017, installation via install_IntelSDK.sh, all kernel patches installed
- cuda_8.0.27.1_linux
cat /etc/environment
# CUDA
CUDA_HOME=/usr/local/cuda
# Intel MediaSDK
LIBVA_DRIVER_NAME=iHD
LIBVA_DRIVERS_PATH=/opt/intel/mediasdk/lib64
PATH="/usr/local/cuda:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
LD_LIBRARY_PATH="/usr/local/cuda/lib64:/opt/intel/opencl:/usr/local/lib:/usr/lib64"
cd /opt/intel/mediasdk/opensource/libdrm/2.4.66-55964/
tar xf libdrm-2.4.66.tar.bz2
cd libdrm-2.4.66
./configure
make -j 8
make install
cd /opt/intel/mediasdk/opensource/libva/1.67.0.pre1-55964
tar xf libva-1.67.0.pre1.tar.bz2
cd libva-1.67.0.pre1
./configure --enable-static
make -j 8
make install
cd /opt/intel/mediasdk/opensource/mfx_dispatch/
mkdir build
cd build
cmake –D__ARCH:STRING=intel64 ../
make -j 8
# cat /usr/lib/pkgconfig/libmfx.pc
prefix=/opt/intel/mediasdk
exec_prefix=${prefix}
libdir=${prefix}/lib/lin_x64
includedir=${prefix}/include
Description: Intel Media Server Studio SDK
Version: 16.4.2
Requires:
Libs: -L${libdir} -lmfx -lva -lstdc++ -ldl -lva-drm -ldrm
Cflags: -I${includedir} -I/usr/local/include/libdrm
# ls -l /dev/dri
crwxrwxrwx 1 vlc vlc 226,   0 Sep 14 11:23 card0
crwxrwxrwx 1 vlc vlc 226,  64 Sep 14 11:23 controlD64
crwxrwxrwx 1 vlc vlc 226, 128 Sep 14 11:23 renderD128
# vainfo
error: can't connect to X server!
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.99 (libva 1.67.0.pre1)
vainfo: Driver version: 16.5.55964-ubit
vainfo: Supported profile and entrypoints
      VAProfileH264ConstrainedBaseline: VAEntrypointVLD
      VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline: <unknown entrypoint>
      VAProfileH264Main               : VAEntrypointVLD
      VAProfileH264Main               : VAEntrypointEncSlice
      VAProfileH264Main               : <unknown entrypoint>
      VAProfileH264High               : VAEntrypointVLD
      VAProfileH264High               : VAEntrypointEncSlice
      VAProfileH264High               : <unknown entrypoint>
      VAProfileMPEG2Simple            : VAEntrypointEncSlice
      VAProfileMPEG2Simple            : VAEntrypointVLD
      VAProfileMPEG2Main              : VAEntrypointEncSlice
      VAProfileMPEG2Main              : VAEntrypointVLD
      VAProfileVC1Advanced            : VAEntrypointVLD
      VAProfileVC1Main                : VAEntrypointVLD
      VAProfileVC1Simple              : VAEntrypointVLD
      VAProfileJPEGBaseline           : VAEntrypointVLD
      VAProfileJPEGBaseline           : VAEntrypointEncPicture
      VAProfileVP8Version0_3          : VAEntrypointEncSlice
      VAProfileVP8Version0_3          : VAEntrypointVLD
      VAProfileVP8Version0_3          : <unknown entrypoint>
      VAProfileVP9Profile0            : <unknown entrypoint>
      <unknown profile>               : VAEntrypointVideoProc
      VAProfileNone                   : VAEntrypointVideoProc
      VAProfileNone                   : <unknown entrypoint>?
+ ffmpeg compiled with --enable-libmfx alo ok.
All seems ok, but...
# /opt/intel/mediasdk/samples/sample_multi_transcode -i::h264 /opt/intel/mediasdk/samples/content/test_stream.264 -o::h264 /opt/intel/mediasdk/samples/content/test_out.h2$
Multi Transcoding Sample Version 7.0.16053497
Return on error: error code -2, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/pipeline_transcode.cpp        3372
Return on error: error code -2, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/sample_multi_transcode.cpp    277
ffmpeg -y -i "udp://@239.23.0.101:1234" -c:v h264_qsv -preset:v faster out.qsv.mp4
Input #0, mpegts, from 'udp://@239.23.0.101:1234':
  Duration: N/A, start: 36732.375211, bitrate: N/A
  Program 261
    Stream #0:0[0x7d1]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x7d2](cze): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 192 kb/s
    Stream #0:2[0x7d4](cze): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, mono, s16p, 64 kb/s (visual impaired)
    Stream #0:3[0x7d6](cze): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) (hearing impaired)
[h264_qsv @ 0x40e9200] Error initializing the encoder
Output #0, mp4, to 'out.qsv.mp4':
    Stream #0:0: Unknown: none, SAR 1:1 DAR 0:0
    Metadata:
      encoder         : Lavc57.55.101 h264_qsv
    Stream #0:1(cze): Unknown: none
    Metadata:
      encoder         : Lavc57.55.101 aac
Stream mapping:
  Stream #0:0 -> #0:0 (h264 (native) -> h264 (h264_qsv))
  Stream #0:1 -> #0:1 (mp2 (native) -> aac (native))
Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
Alexander_K_5
Hi
MSS2017 doesn't support 4th genereration Intel Core processors.
Milan_C_
Thx Alexander, I'm going to try it on i7-6700K​.
Milan_C_
Hi, I have the same issue on Skylake... :(
/# vainfo
      VAProfileHEVCMain               : VAEntrypointVLD
      VAProfileHEVCMain               : VAEntrypointEncSlice
Anna_B_Intel
Hi Milan,
It seems like you don't have rights for writing to /opt/intel/mediasdk/samples/content/. Try to save output in another directory.
Best wishes,
Anna
Milan_C_
Ouch, I apologize.
It was my big mistake in paths. :/ Now it works and solved. :-)
jan_g_1
i install media server studio 2017 on i7-6700k ubuntu 16.04.
root@tvhneu:/opt/intel/mediasdk/opensource/mfx_dispatch/build# vainfo
then i compile ffmpeg but ....
    Stream #0:0[0x201]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], Closed Captions, 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x202](deu): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 192 kb/s
Please use -b:a or -b:v, -b is ambiguous
[h264_qsv @ 0x37fa7c0] Error initializing the encoder
Output #0, mpegts, to 'udp://127.0.0.1:10000':
    Stream #0:0: Video: h264, none, q=2-31, 128 kb/s, SAR 1:1 DAR 0:0, 25 fps
    Metadata:
      encoder         : Lavc56.60.100 h264_qsv
    Stream #0:1(deu): Audio: aac, 0 channels, 128 kb/s
    Metadata:
      encoder         : Lavc56.60.100 aac
Stream mapping:
can anyone help me?
root@tvhneu:/opt/intel/mediasdk/samples# ./sample_multi_transcode -i::h264 /opt/intel/mediasdk/samples/streams/test_stream.264 -o::h264 /home/bla.264
Pipeline surfaces number (DecPool): 20
Return on error: error code -3,    /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/pipeline_transcode.cpp    2924
Return on error: error code -3,    /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/sample_multi_transcode.cpp    307
Jeffrey_M_Intel1
In case it might help to diagnose your system, I've added some updates to the system analyzer here: https://software.intel.com/en-us/articles/mss-sys-analyzer-linux
This white paper documents some of the things you can check to diagnose issues with your Media SDK + FFmpeg install: http://www.intel.com/content/www/us/en/cloud-computing/quicksync-video-ffmpeg-install-valid.html
If all else fails, strace can also sometimes help to debug startup issues like this.
Milan_C_
mss-sys-analyzer-linux is best tool for diagnostic. It solved my problems, eg.  I had ":" separator in LD_LIBRARY_PATH instead of ";"
But now, when MSS2017 is working and all samples are ok, is another problem here with ffmpeg and segmentation fault...
https://trac.ffmpeg.org/ticket/5859
jan_g_1
Milan_C_
mss-sys-analyzer-linux​ tool works offline, internet connection is not needed (only for download this script).
jan_g_1
root@tvh1:~# ./sys_analyzer_linux.py
Hardware readiness checks:
 [ OK ] Processor name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
OS readiness checks:
 [ OK ] GPU visible to OS
Intel(R) Media Server Studio Install:
 [ OK ] user is root
 [ OK ] libva.so.1 found
 [ OK ] vainfo reports valid codec entry points
 [ OK ] /dev/dri/renderD128 connects to Intel i915
Media SDK Plugins available:
(for more info see /opt/intel/mediasdk/plugins/plugins.cfg)
    H264LA Encoder     = 588f1185d47b42968dea377bb5d0dcb4
    VP8 Decoder     = f622394d8d87452f878c51f2fc9b4131
    HEVC Decoder     = 33a61c0b4c27454ca8d85dde757c6f8e
    HEVC Encoder     = 6fadc791a0c2eb479ab6dcd5ea9da347
Component Smoke Tests:
 [ OK ] Media SDK HW API level:1.19
 [ OK ] Media SDK SW API level:1.19
 [ OK ] OpenCL check:terminate called after throwing an instance of 'OCLRT::xcb_error'
  what():  XCB ERROR: X session is not running!
Aborted (core dumped)
Milan_C_
I have system without X and I didn't see this error.
jan_g_1
https://software.intel.com/en-us/articles/how-to-setup-media-server-studio-on-secondary-os-of-linux
i install it with this script but on ubuntu 16.04 and the kernel compile is without errors but i have the same error in ffmpeg
Milan_C_
I reported to ffmpeg team here: https://trac.ffmpeg.org/ticket/5859
​But no reply. :(
jan_g_1
did u get it work on i7-4790k? with 2016?
my problem is that the./sample_multi_transcode -i::h264 /opt/intel/mediasdk/samples/streams/test_stream.264 -o::h264 /home/bla.264 also is not working... can u explain how u install it?
jan_g_1
root@tvh1:~# /opt/intel/mediasdk/samples/sample_multi_transcode -i::h264 /opt/intel/mediasdk/samples/streams/test_stream.264 -o::h264 /home/test-stream-264
MFX HARDWARE Session 0 API ver 1.19 parameters:
Input  video: AVC
Output video: AVC
Session 0 was NOT joined with other sessions
Transcoding started
Transcoding finished
Common transcoding time is  0.06 sec
MFX session 0 transcoding PASSED:
Processing time: 0.06 sec
Number of processed frames: 101
The test PASSED
seems everything ok or?
root@tvh1:/home/jan# ./sys_analyzer_linux.py
 [ OK ] user in video group
 [ ERROR ] could not open /dev/dri/renderD128
 [ OK ] OpenCL check:platform:Intel(R) OpenCL GPU OK CPU OK
the compile from ffmpeg had an error...
./configure --enable-nonfree --enable-gpl --enable-libmfx --prefix=/home/ffmpeg --incdir=/opt/intel/mediasdk/include/mfx
make
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libva-drm.a(va_drm.o): In Funktion `va_DisplayContextGetDriverName':
(.text+0xaa): Nicht definierter Verweis auf `drmGetMagic'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libva-drm.a(va_drm_auth.o): In Funktion `va_drm_is_authenticated':
(.text+0x6a): Nicht definierter Verweis auf `drmGetClient'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libva-drm.a(va_drm_auth.o): In Funktion `va_drm_authenticate':
(.text+0xf8): Nicht definierter Verweis auf `drmAuthMagic'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libva-drm.a(va_drm_utils.o): In Funktion `VA_DRM_GetDriverName':
(.text+0x2e): Nicht definierter Verweis auf `drmGetVersion'
(.text+0x7d): Nicht definierter Verweis auf `drmFreeVersion'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libva-drm.a(va_drm_utils.o): In Funktion `VA_DRM_IsRenderNodeFd':
(.text+0x133): Nicht definierter Verweis auf `drmGetDeviceNameFromFd'
collect2: error: ld returned 1 exit status
Makefile:131: die Regel für Ziel „ffmpeg_g“ scheiterte
make: *** [ffmpeg_g] Fehler 1
Manuel_M_5
i have the same problem with ubuntu 16.04. I've installed everything as shown in the first post. But when i try to run the sample i got these error:
./sample_multi_transcode -i::h264 content/test_stream.264 -o::h264 /home/manuelmenz/out.h264 -hw -la
[sudo] password for manuelmenz:
I can not download the sys_analyzer script because the server is unavailable...
mikko_h_
I have error -3 when trying Multi Transcoding Sample Version 7.0.16053611, is there a mistake somewhere I did?
Intel Skull Canyon NUC6i7KYK i7 6770HQ Iris Pro graphics 580.
Installed MediaServerStudioProfessionalEvaluation2017 as root from ~/Downloads/MediaServerStudioProfessionalEvaluation2017/SDK2017Production16.5/Generic
using install_ubuntu.sh from https://software.intel.com/en-us/articles/how-to-setup-media-server-studio-on-secondary-os-of-linux
ldd (Ubuntu GLIBC 2.23-0ubuntu4) 2.23 & gcc (Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609
Now:
env | grep LD_LIBRARY_PATH
LD_LIBRARY_PATH=/usr/lib64;/usr/local/lib
vainfo
 [ OK ] Processor name: Intel(R) Core(TM) i7-6770HQ CPU @ 2.60GHz
 [ OK ] OpenCL check:igdrcl: using XCB-DRI2 authentication...
                          ------------------------ERROR---------------------------
~/Downloads/MediaServerStudioProfessionalEvaluation2017/MediaSamples_Linux_2017/samples/_bin/x64/sample_multi_transcode -i::h264 ~/Downloads/MediaServerStudioProfessionalEvaluation2017/MediaSamples_Linux_2017/samples/_bin/content/test_stream.264 -o::h264 ~/transcoded.h264 -hw
Return on error: error code -3,    /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/pipeline_transcode.cpp2968
Joo_Fei_W_
Hi mikko,
Did you manage to fix the issue in the end? I have the same.
huihai_l_
Hi Milan,
I saw CUDA stuff in your post, so I assume you have a Nvidia graphic card in your system. Have you been able to enable both Nvidia graphic card and Intel GPU at the same time, and get MSS2017 to work?
I have a Dell laptop XPS 9550 with both a Nvidia 960M and Intel integrated 530 graphic card. If I use nvidia-prime to switch to intel graphic card only, I can get MSS2017 to work, everything is fine. But if I switched to Nvidia 960M, if I run vainfo, it shows
Xlib:  extension "XFree86-DRI" missing on display ":0".
DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument
Assuming 131072kB available aperture size.
May lead to reduced performance or incorrect rendering.
get chip id failed: -1 [22]
param: 4, val: 0
libva error: /opt/intel/mediasdk/lib64/iHD_drv_video.so init failed
libva info: va_openDriver() returns 18
vaInitialize failed with error code 18 (invalid parameter),exit
Here is my machine configuration:
Ubuntu 16.04LST
nvidia-378 installed
followed this link to install MSS2017 R2:
Best
