I am trying to setup Intel's new open-source iHD driver on a Yocto environment.
https://software.intel.com/en-us/articles/build-and-debug-open-source-media-stack
The documentation says that skl_dmc_ver1_27.bin is required. Their documentation updates a symlink (skl_dmc_ver1.bin), as if the kernel loads it, but starting at kernel 4.8, it stopped loading the symlink and instead loads a specific version of the dmc (see here: https://github.com/torvalds/linux/blob/v4.8/drivers/gpu/drm/i915/intel_csr.c#L48). Is the Intel documentation accurate? It is confusing because the guide refers to 4.14.16 specifically, which doesn't use the symlink file skl_dmc_ver1.bin.
Any ways, I tried replacing skl_dmc_ver1_26.bin with skl_dmc_ver1_27.bin to have the same effect, but I got a segfault on boot.
Should I even bother updating the DMC? Should the iHD driver work on most kernels, even with 1_26 version of DMC?
By the way, this is the kernel I am using (with Yocto).
https://github.com/intel/linux-intel-lts/tree/4.14/yocto/base/drivers/gpu/drm/i915
Any help would be greatly appreciated. There is no documentation on this stuff.
- Tags:
- Development Tools
- Graphics
- Intel® Media SDK
- Intel® Media Server Studio
- Media Processing
- Optimization
Maybe the documentation has changed since your post was published, but, here and now, the documentation requires the 1.26 version.
and instead loads a specific version of the dmc (see here: https://github.com/torvalds/linux/blob/v4.8/drivers/gpu/drm/i915/intel_c.).
#define I915_CSR_SKL "i915/skl_dmc_ver1_26.bin" MODULE_FIRMWARE(I915_CSR_SKL); #define SKL_CSR_VERSION_REQUIRED CSR_VERSION(1, 26)
Good point. The symlink sounds useless since this i915 patch was released.
