3058 Discussions
Question about using HEVC plugin in Media SDK samples
chao_s_
I'm now learning programming with intel media sdk, for using hevc plugin, I installed Intel media server studio for windows (Evaluation), and copied the HEVC plugin from media server studio install dir:
C:\Program Files\Intel\Intel(R) Media Server Studio 2015 R6\HEVC Decoder & Encoder\Plugin
To Media SDK plugin dir:
C:\Program Files (x86)\IntelSWTools\Intel(R)_Media_SDK_2016.0.1\bin\x64
I'm not quite sure this is the correct way to install plug-in on Media SDK, for there was screen capture plugin mfxplugin64_screen_capture.dll located here, so I guess this is the plugin dir for media sdk.
Now I do some test with sample_encode and sample_decode which part of Intel Media Samples following its document: readme-encode.pdf
First soft encode:
sample_encode.exe h265 -i input.yuv -o output.h265 -w 352 -h 288 -b 256 -f 30 -u speed -d3d11 -sw
It works fine, even i didn't use the -p arg to specify the guid of mfxplugin64_hevce_sw
Then hard encode:
sample_encode.exe h265 -i input.yuv -o output.h265 -w 352 -h 288 -b 256 -f 30 -u speed -d3d11 -hw -p e5400a06c74d41f5b12d430bbaa23d0b
Where e5400a06c74d41f5b12d430bbaa23d0b is the dir name (also the guid) where mfxplugin64_hevce_hw.dll located.
It fails with the output:
Return on error: error code -3, src\pipeline_encode.cpp 574
Return on error: error code -3, src\pipeline_encode.cpp 1156
Return on error: error code -3, src\pipeline_encode.cpp 1086
Return on error: error code 1,  src\sample_encode.cpp   656
The soft decode:the output.h265
./sample_decode.exe h265 -i output.h265 -o test.yuv
sample_decode.exe h265 -i output.h265 -o test.yuv -p 15dd936825ad475ea34e35f3f54217a6
Where 15dd936825ad475ea34e35f3f54217a6 is the dir name for mfxplugin64_hevcd_sw.dll
All fail with the output:
Return on error: error code -3, src\pipeline_decode.cpp 541
Return on error: error code -3, src\pipeline_decode.cpp 271
Return on error: error code 1,  src\sample_decode.cpp   501
I don't know what's going wrong?!! Is it the problem the way i use the plugin???
Sravanthi_K_Intel
Hi Chao,
The default plugin that is called when you dont specify "-p" parameter is the SW plugin, To enforce any other plugin, you have to use "-p" to specify it.
Did you install the HEVC package on your system? The eval version of MSS does not come with HEVC package. You need to download the Pro version for it that has the HEVC package, and install the package.
I tested your command lines above and they work fine for me. I have MSS pro installed that has the HEVC package.
chao_s_
Hi, Sravanthi
Thank you for your kindly help.
Through debugging, I found the the program (sample_encode) fails on Version Check, in pipeline_encode.cpp:1022
if (CheckVersion(&version, MSDK_FEATURE_PLUGIN_API))
It didn't run into this if block in which "LoadPlugin" was called.
When program hits here, MSDK_FEATURE_PLUGIN_API = 7; version { minor = 7, major = 1 Version = 65543 }
The HEVC encoder's plugin.cfg as follows:
PluginVersion = 1
APIVersion    = 272 //0x0110
FileName32    = "mfxplugin32_hevce_hw.dll"
FileName64    = "mfxplugin64_hevce_hw.dll"
Type          = 02 //encode
CodecID       = "HEVC"
Default       = 0
On my pc, I firstly installed Intel Media SDK 2016 and then installed Intel Media server Studio 2015 R6 prof.
And the environment variable "INTELMEDIASDKROOT = C:\Program Files\Intel\Intel(R) Media Server Studio 2015 R6\Software Development Kit\"
I still have not got the solution yet!!!
walker_y_
 recently, I have got the same problem, Have you solved ?
