Questions about decoding jpeg by HW (bugs?)
Kilik_K_
I'm trying to using sample_decode.exe to do jpeg hw decode.  There're 2 questions that I am confused about...
Hope that someone can give a guide, great thanks in advance !!!
First,
The function CJPEGFrameReader::ReadNextFrame(mfxBitstream *pBS) in sample_utils.cpp.
Shouldn't the condition check ...
MSDK_CHECK_NOT_EQUAL(FindSOImarkers(pBS) == 2, true, MFX_ERR_NOT_ENOUGH_BUFFER);
be like this ===>
MSDK_CHECK_NOT_EQUAL(FindSOImarkers(pBS) <= 2, true, MFX_ERR_NOT_ENOUGH_BUFFER);
Because if a jpeg file doen'st contain thumbnail inside metadata( nSOI =1, it will return "NOT_ENOUGH_BUFFER", here), and finally return error at upper function.
Did I misunderstand this code ??
Second.
Is there any resolution restriction for hw jpeg decode ? 8000 x 6000, 10000 x 5000 ?
I think that if the decoded result is treated as a d3d suface, the resolution upper bound should be the maximum d3d texture size.
Did I misundertand this ?
PS : The version of Media SDK is 3.5.915.45327
Kilik_K_
Sorry, I figured out !! I think the original code in CJPEGFrameReader::ReadNextFrame(mfxBitstream *pBS) is much more appropriate for MJPEG, and when I'm trying to decode a still JPEG with thumbnails inside (maybe 3 "FFD8" pattern in this file), I should add additional handling for these cases.
