I tried to configure the Video_Conferencing_Sample_5.0.337.78585 to test these RC method. The code modified as follow:
void VideoConfPipeline::InitBrc() { ...... else { // Modified //m_mfxEncParams.mfx.TargetKbps = m_initParams.nTargetKbps; // in Kbps //m_mfxEncParams.mfx.RateControlMethod = MFX_RATECONTROL_VBR; //dynamic bitrate change requires for encoder to be initialized with VBR // Replaced by /*m_mfxEncParams.mfx.RateControlMethod = MFX_RATECONTROL_ICQ; m_mfxEncParams.mfx.ICQQuality = 27;*/ m_mfxEncParams.mfx.RateControlMethod = MFX_RATECONTROL_VCM; // end Modified } }
But when comes to sts = m_encoder->Init(&m_mfxEncParams); the call returns MFX_ERR_INVALID_VIDEO_PARAM for both RC method.
Is that anything I did wrong? Could anyone give the features of these RC method?
Thanks in advance.
Hi there,
Just heard from the developer and has found that the ICQ and VCM methods are supported from Haswell(HD4400) and not supported on Ivy Bridge(HD4000). That's why it didn't work on your first machine, but worked in the other system you have even with old drivers. We have a gap in the existing documentation and we are trying to improve it in our future releases.
-Surbhi
Besides, the parameters passed to start the program was
-i "E:\foreman\foreman_cif.yuv" -o "E:\foreman\foreman_cif_ts4.h264" -w 352 -h 288 -hw -latency
Hi kz,
I tested the video conference sample with MFX_RATECONTROL_VCM method and did not run into the issue you have mentioned. I have also tested with the params you have given and it has worked for me.
To debug more can you please send the system analyzer of your machine, details how to use the tool it can be found here - Suggested Format For Forum Questions
I hope you are assigning the value of target kbps in your code and haven't the commented below line of the code before if statement.
If you still see the issue, then try doing fresh install of video conferencing sample and run VCM Bitrate Control Method and check if that works for you.
-Surbhi
Hi Surbhi,
I've just tried you suggestions. I first made sure the nTargetKbps is set. And then I installed the latest MSDK 2014R2 client, as well as Video Conferencing Sample 5.0.461.91752. But the issue is still there. So I upload the analysis result. It seems the HW means are fully supported on my platform. Can something be figured out from this?
Intel Media SDK System Analyzer (32 bit) The following versions of Media SDK API are supported by platform/driver: Version Target Supported Dec Enc 1.0 HW Yes X X 1.0 SW Yes X X 1.1 HW Yes X X 1.1 SW Yes X X 1.3 HW Yes X X 1.3 SW Yes X X 1.4 HW Yes X X 1.4 SW No 1.5 HW Yes X X 1.5 SW No 1.6 HW Yes X X 1.6 SW No 1.7 HW Yes X X 1.7 SW No 1.8 HW Yes X X 1.8 SW No Graphics Devices: Name Version State Intel(R) HD Graphics 4000 10.18.10.3496 Active System info: CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz OS: Microsoft Windows 7 Installed Media SDK packages (be patient...processing takes some time): Analysis complete... [press ENTER]
Hi Surbhi,
It seems the -HW lead to the problem. When I run the sample without the -HW param, it goes well for both VCM and IQC. Since the analyzer result shows the HW acceleration is supported, isn't that weird?
This is quite a strange behavior. Great it worked with SW.
Can you please confirm if you are running the code also on Win32 platform, so that there is no mismatch on Information as your system analyzer is for 32 bit. Also it would be good to update your graphics driver, it has been helpful to fix lot of issues in the past. Driver can be downloaded from this website - downloadcenter.intel.com
-Surbhi
Yes I'm running a 32bit Windows 7. I just upgrade the driver. According to the analysis result, nothing seems changed except the driver version.
Intel Media SDK System Analyzer (32 bit) The following versions of Media SDK API are supported by platform/driver: Version Target Supported Dec Enc 1.0 HW Yes X X 1.0 SW Yes X X 1.1 HW Yes X X 1.1 SW Yes X X 1.3 HW Yes X X 1.3 SW Yes X X 1.4 HW Yes X X 1.4 SW No 1.5 HW Yes X X 1.5 SW No 1.6 HW Yes X X 1.6 SW No 1.7 HW Yes X X 1.7 SW No 1.8 HW Yes X X 1.8 SW No Graphics Devices: Name Version State Intel(R) HD Graphics 4000 10.18.10.3945 Active System info: CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz OS: Microsoft Windows 7
I also run the sample on another PC with HD4400 graphic card installed. The VCM and ICQ mode both running successfully with HW enable! Following is the analysis result of that PC.
Intel Media SDK System Analyzer (32 bit) The following versions of Media SDK API are supported by platform/driver: Version Target Supported Dec Enc 1.0 HW Yes X X 1.0 SW No 1.1 HW Yes X X 1.1 SW No 1.3 HW Yes X X 1.3 SW No 1.4 HW Yes X X 1.4 SW No 1.5 HW Yes X X 1.5 SW No 1.6 HW Yes X X 1.6 SW No 1.7 HW Yes X X 1.7 SW No 1.8 HW No 1.8 SW No Graphics Devices: Name Version State Intel(R) HD Graphics 4400 10.18.10.3412 Active System info: CPU: Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz OS: Microsoft Windows Embedded Standard Arch: 32-bit Installed Media SDK packages (be patient...processing takes some time): ......
Then I tested the CQP mode on both PC with HW enable and compared the sample log, I found something interesting. On my PC (on which the ICQ and VCM mode failed with HW enable, but the VBR and CQP runs successfully) the log shows
Intel(R) Media SDK Video Conference Sample Version 5.0.461.92695 Input file format YUV420 Output video AVC Resolution 352x288 Crop X,Y,W,H 0,0,352,288 Frame rate 30.00 Bit rate(Kbps) 29 Memory type d3d Media SDK impl hw Media SDK version 1.10 Processing started Processing finished Frame number: 300
And on the PC with HD4400, the log shows
Input file format YUV420 Output video AVC Resolution 352x288 Crop X,Y,W,H 0,0,352,288 Frame rate 24.00 Bit rate(Kbps) 29 Memory type system Media SDK impl hw Media SDK version 1.7
Only the mem type and the SDK version differs. I tried change the mem type, it had noting to do with the result. So it seems the SDK version has will affect my result. So is the SDK version means the SDK API version? Also, isn't the latest API version is only 1.8? How it detect a version of 1.10?
Hi there,
The maximum API version we support is 1.10 currently. According to the Manual docs, Bit rate control VCM algorithm is supported in SDK API 1.8 version. Also, the system analyzer tells us analyzes the system, but not the capability to support the features present in the Media SDK on the system.
I am in talks with the expert regarding this issue, In the mean time can you please tell us what Media SDK version you are using like Media SDK 2014 R2 ? Also can you please run tracer logs when you run your code and send it to us. Details can be found in this link - Suggested Format For Forum Questions
Just wanted to let you VCM, ICQ, LA_ICQ, LA_VCM modes are experimental modes and couldn't be confirmed to work on all the platform.
-Surbhi
Thanks for telling those RC method are still under experiment.
I'm using Media SDK 2014 R2 now. I configured the sample using VCM RC method and ran it on both PC and traced the log. The result is just as the same as before: the PC installed HD4400 ran the sample successfully with HW enable, while the one installed HD4000 failed. Log files were uploaded as the attachment. Hope it helps. I really found some difference between the two logs. But I'm not understand what it tells.
Hi there,
-Surbhi
SURBHI M. (Intel) wrote:
Hi there,
-Surbhi
Thanks a lot! It really helps!
Besides, could you get some detailed information about how VCM and ICQ work? Or, how they determine the bitrate? So far I found nothing except some words in the MSDK document.
Hi there,
Little more Info about ICQ and VCM
ICQ is a intelligent constant quality factor, requires ICQQuality factor only – it is not bitrate control actually(not controlling bitrate and HRD), but quality control method(adjusts QP values for better visual quality).This mode tries to encode frames for constant and better subjective quality.
VCM is an algorithm for video conferencing usage i.e for talking head with static background. It is not supported for B frames, so only I & P frames can be used. It works pretty much as VBR(requires TargetKbps and MaxKbps). Again it can provide better subjective quality for talking head type content, but would be worse for any other type.
Just for FYI it is currently broken(gives same result for any bitrates) on the latest driver versions available at intel.com, and will be available only in December.
Hope this helps!
-Surbhi
Hi Surbhi,
Really thanks for telling so much about the VCM and the ICQ. It helps a lot in my work!
