Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
Questions about temporal scalability
Kz_Liao
I've met some problem in utilizing the temporal scalability. The 1st question was also asked in https://software.intel.com/en-us/forums/topic/515572.
1) It's written in https://software.intel.com/en-us/articles/video-conferencing-features-of-intel-media-software-development-kit/ that "Two consecutive temporal layers must have integer ratio of frame rates". Since 3 is an integer, I suppose the ratio can be 3. So I configured the initializing parameter in the video conferencing conference sample like this:
else if ( 0== msdk_strcmp(strInput, MSDK_STRING("-ts")))
            CHECK_OPTION_ARGS(1);
            params.nTemporalScalabilityBase = 3; // ratio of 3
            lexical_cast(strInput[++i], params.nTemporalScalabilityLayers);
By debugging, the m_temporalScale looked like the follow:
m_temporalScale.Layer[0].Scale == 1;
m_temporalScale.Layer[1].Scale == 3;
m_temporalScale.Layer[2].Scale == 9;
m_temporalScale.Layer[3].Scale == 0;
But the m_encoder->Init(&m_mfxEncParams) returns MFX_ERR_INVALID_VIDEO_PARAM. Is the ratio other than 2 not supported?
2) If the ratio other than 2 is not supported, can I use the mfxExtAVCRefListCtrl at encoding time to simulate the fame dependencies hierarchies like the temporal scalability do?
