Ratecontrol CQP
kyviquel
I would like to know what is exaclty the range of QPI, QPP, QPB for RateControl CQP?
I assumed it was [0,51] but the h264 encoder init function returns Invalid parameter if I set QBI = QPP = QPB = 0.
Karine
Petter_L_Intel
Hi Karine,
QP value range is 0-51. And there should be no issues setting the value to 0.
I performed a quick check here on my side and it works fine.
If you are still encountering issues, please provide a Media SDK trace log, so that we can better understand you complete encoder configuration to determine potential issues.
Petter
kyviquel
Hi Petter,
I just noticed this bug only occurs on the h264 SW encoder, the QSV works well.
Do you test the SW encoder?
Karine
Petter_L_Intel
Hi Karine,
I did a quick test using SW path. it works fine using QPI = QPP = QPB = 0.
Are you SW library from Media SDK 2013?
Petter
kyviquel
Hi Petter,
It is Media SDK 2013.
I will try to give you some extra informations. How do we enable the Intel Media SDK log?
Karine
Petter_L_Intel
Hi Karine,
In the Media SDK tools folder you will find the "mediasdk_tracer" tracer tool. To capture a log just launch the tool and start capturing before running your workload. When done, click Stop and retrieve the log.
Petter
kyviquel
Hi Petter,
This is the 2 files I generated with your logging tool:
- the file analyzerSW.log is the log file generated when I set QP=0 with the h264 SW encoder. In this file you can see the error return by the Init function.
- the file analyzerQSV.log is the log file generated with same parameter but with the h264 QSV encoder
I hope this helps, let me know if you need something else.
Karine
kyviquel
Hi Petter,
Karine
Petter_L_Intel
Hi Karine,
unfortunately your log files did not get attached to your post.
Could you please try to upload the log files again?
Petter
kyviquel
Sorry I have some proxy problem to upload.
It should work this time.
Karine
Petter_L_Intel
Hi Karine,
thanks for the logs. From what I can see, it looks like the reason for the issue is that QPI = QPP = QPB = 0 is not allowed for target usage = 7 (speed).
If you set target usage to a value from 1-6, it works.
I will check with codec expert and get back to you on why this is the case.
Petter
Petter_L_Intel
Hi again Karine,
Many thanks for reporting the issue.
This specific configuration was confirmed to be a bug in the Media SDK SW DLL. Fix will be introduced in future release of the Media SDK.
Petter
kyviquel
Thanks, I will patch it on my current implementation.
Karine
