Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
Re: Unable to register and download the Media SDK for Windows
m20003
Thank you. Anyway - is the new oneVPL environment also suitable to use together with the VCA / VCA2 board ? VCA uses P560 graphics accelerator and Intel v4 Xeon. If this is supported, then of course the older environment is no longer needed. As for GPU support, this is my biggest concern.
JyothisV_Intel
Good day to you.
We are checking on this internally and will get back to you with an update soon.
Thanks and Regards,
Jyothis V James
JyothisV_Intel
Good day to you.
Apologies for the delay in getting back to you.
Our internal team has informed us that VPL dispatcher will work using the Media SDK runtime with any hardware supported by Media SDK.
Here is a list of current implementations:
oneVPL-intel-gpu (https://github.com/oneapi-src/oneVPL-intel-gpu) for use on Intel Xe graphics and newer
Media SDK (https://github.com/Intel-Media-SDK/MediaSDK) for use on legacy (pre-Xe) Intel graphics
If this resolves your query, kindly accept this as a solution as it will help others with a similar query.
Thanks and Regards,
Jyothis V James
JyothisV_Intel
Good day to you.
Did the previous reply resolve your issue? If yes, kindly accept it as a solution as it with help others with a similar query. If not, do get back to us so that we can assist you better.
Thanks and Regards,
Jyothis V James
JyothisV_Intel
Good day to you.
We have not received any response from you. We assume that your issue is resolved.
Intel will no longer monitor this thread. If you need assistance in using any Intel products or services, kindly post a new question.
Thanks and Regards,
Jyothis V James
