Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
Recommended Hardware, OS and other specs for Intel Media Server Studio 2017
shavkat_n_
Please provide technical specs about hardware & software requirements for recommended most optimal, minimum optimal performance using Intel Media Server Studio 2017 in Data Center for Video Transcoding.
shavkat_n_
I saw #Hardware Requirements on  https://software.intel.com/en-us/intel-media-server-studio/details, I would appreciate recommended specs and more detailed infomation like model name, number (for example: if 6th Generation Intel® Core™ i5 Processors also recommended than which processor graphics better suited ie. Intel® Iris™ Pro Graphics or Intel® Iris™ Graphics )
Jiandong_Z_Intel
Hi There,
Different CPU configuration usually get difference performance, the HW select depend on the customer's business requirement.
You can find performance data from https://software.intel.com/en-us/intel-media-server-studio, you also can find the HW configuration for that performance data under the performance data table.
Zachary
shavkat_n_
Hi Zachary,
Thank you for response. I'm interested in HEVC realtime decode/encode.
For 'performance data' do you mean "Multistream performance: Number of real-time streams" data & Baseline configuration info or do you mean this (https://software.intel.com/sites/default/files/managed/85/7c/Intel-Xeon-Processor-E3-1500-v5-Performance-May-2016.pdf) ?
I am interested in HEVC decode/encode capability (8-bit and 10-bit, Linux & Windows). And hardware-accelerated when applicable.
