Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
RepeatPPS in qsv HEVC encoding
drquake_a_
hi, i'm using ffmpeg with qsv acceleration in hevc live encoding, on xeon e3-1585 v5. The problem I found is, mfxExtCodingOption2::RepeatPPS cannot be enabled on mfx initialization (saw that in ffmpeg debug log). It is ok for file encoding as the extra data is stored in file container header. But it brings problem to live stream encoding as the output stream cannot be decoded correctly by vlc player or other decoders. Is there solution for this or am I doing something wrong? Any help.
P.S. qsv accelerated h.264 encoding doesn't have such issue. RepeatPPS is enabled without problem.
Stanley_W_
from mediasdk-man.pdf
when use H.264, you should set IdrInterval = 0;
when use HEVC, you should set IdrInterval = 1;
IdrInterval For H.264, IdrInterval specifies IDR-frame interval in terms of
I-frames; if
IdrInterval=0, then every I-frame is an IDR-frame.
If
IdrInterval=1, then every other I-frame is an IDR-frame, etc.
For HEVC, if
IdrInterval=0, then only first I-frame is an IDR
frame
. If
IdrInterval=1, then every I-frame is an IDR-frame. If
IdrInterval=2, then every other I-frame is an IDR-frame, etc.
For MPEG2,
IdrInterval defines sequence header interval in
terms of I-frames. If
IdrInterval=N, SDK inserts the sequence
header before every
Nth I-frame. If IdrInterval=0 (default),
SDK inserts the sequence header once at the beginning of the
stream.
drquake_a_
any body heeeeeeelp
Mark_L_Intel1
Hi drquake,
Sorry for the late response, we are working on other projects and I didn't have a chance to check the forum questions.
I don't know too much detail about the FFmpeg integration and I doubt H.264 case is just the RepeatPPS was enabled by default. You might refer to the following code for help, this is the same code to dump the debug log mentioned in your post:
http://www.ffmpeg.org/doxygen/3.0/qsvenc_8c_source.html
This is the interface to integrate the ffmpeg parameters with MSDK. If you look at line 670, the function ff_qsv_enc_init(), it calls init_video_param() at line 710, I think you can modify it to add the RepeatPPS option.
Let me know if this helps.
Mark
drquake_a_
Liu, Yan wrote:
Hi drquake,
Mark
Thank you very much for your kind support.
I have done some code trying to set RepeatPPS. But it doesn't work. Here is part of my code fix:
if (avctx->codec_id == AV_CODEC_ID_HEVC) {
    q->extco2.Header.BufferId     = MFX_EXTBUFF_CODING_OPTION2;
    q->extco2.Header.BufferSz     = sizeof(q->extco2);
    q->extco2.RepeatPPS = MFX_CODINGOPTION_ON;
    av_log(avctx, AV_LOG_INFO, "set RepeatPPS to ON\n");
And here is the ffmpeg output:
[hevc_qsv @ 059ce620] Using the constant bitrate (CBR) ratecontrol method
[hevc_qsv @ 059ce620] set RepeatPPS to ON
[hevc_qsv @ 059ce620] profile: simple; level: 30
[hevc_qsv @ 059ce620] GopPicSize: 248; GopRefDist: 9; GopOptFlag: closed ; IdrInterval: 0
[hevc_qsv @ 059ce620] TargetUsage: 4; RateControlMethod: CBR
[hevc_qsv @ 059ce620] InitialDelayInKB: 600; TargetKbps: 800; MaxKbps: 800
[hevc_qsv @ 059ce620] NumSlice: 1; NumRefFrame: 5
[hevc_qsv @ 059ce620] RateDistortionOpt: unknown
[hevc_qsv @ 059ce620] RecoveryPointSEI: unknown IntRefType: 0; IntRefCycleSize: 0; IntRefQPDelta: 0
[hevc_qsv @ 059ce620] MaxFrameSize: 0; MaxSliceSize: 0;
[hevc_qsv @ 059ce620] BitrateLimit: unknown; MBBRC: ON; ExtBRC: unknown
[hevc_qsv @ 059ce620] Trellis: auto
[hevc_qsv @ 059ce620] RepeatPPS: OFF; NumMbPerSlice: 0; LookAheadDS: unknown
[hevc_qsv @ 059ce620] AdaptiveI: unknown; AdaptiveB: unknown; BRefType: pyramid
[hevc_qsv @ 059ce620] MinQPI: 0; MaxQPI: 0; MinQPP: 0; MaxQPP: 0; MinQPB: 0; MaxQPB: 0
[hevc_qsv @ 059ce620] Main profile bitstream
[hevc_qsv @ 059ce620] Decoding VUI
You can see clearly that although my code set RepeatPPS to MFX_CODINGOPTION_ON, the final param retrieved from qsv api after init_video_param() shows RepeatPPS is OFF anyway. That causes the problem I described above.
Is it a qsv bug or is my code wrong?
Ramashankar
New Contributor III
Hi drquake,
Though it seems obvious but still wanted to confirm: In above code, after setting the RepeatPPS to ON, are you pushing this setting structure in extended param list also?
m_EncExtParams.push_back((mfxExtBuffer *)&q->extco2);
If not, then it could be the reason why it was still not enabled.
drquake_a_
Ramashankar wrote:
Hi drquake,
Thanks for your anwer.
No I don't use push_back() to validate extended param. Because ffmpeg code is in c not in c++.
The question is, if I choose h.264 encoding, my code can set RepeatPPS to either On or OFF with no problem. But if I choose hevc encoding, RepeatPPS can only be OFF whatever I code. So I'm guessing it's a limit of qsv or something.
drquake_a_
Any updates?
Are there intel qsv supports/experts in this forum?
Stanley_W_
I-frames; if
If
For HEVC, if
frame
. If
For MPEG2,
header before every
stream.
Stanley_W_
information from mediasdk-man.pdf
        For HEVC,
        if IdrInterval=0, then only first I-frame is an IDRframe.
        If IdrInterval=1, then every I-frame is an IDR-frame.
        If IdrInterval=2, then every other I-frame is an IDR-frame, etc
        For H.264, IdrInterval specifies IDR-frame interval in terms of I-frames;
        if IdrInterval=0, then every I-frame is an IDR-frame.
        If IdrInterval=1, then every other I-frame is an IDR-frame, etc.
drquake_a_
IdrInterval
I-frames; if IdrInterval=0, then every I-frame is an IDR-frame.
For HEVC, if IdrInterval=0, then only first I-frame is an IDR
frame
. If IdrInterval=1, then every I-frame is an IDR-frame. If
For MPEG2, IdrInterval defines sequence header interval in
terms of I-frames. If IdrInterval=N, SDK inserts the sequence
header before every Nth I-frame. If IdrInterval=0 (default),
stream.
You are super! Works like a charm
Still curious why RepeatPPS doesn't work for hevc though...
