Hi
Installed MSDK 2015R2, Preview Evaluation 16.4, on Centos 7, 3.10.0-123.el7.x86_64, with Intel(R) Core(TM) i3-4330T CPU @ 3.00GHz. While building the sample transcode example, I am getting the follwing error:
[root@localhost samples]# pwd /home/gotron/gotron/IMSDK2015/MediaSamples_Linux_5.0.1604371.71/samples [root@localhost samples]# perl build.pl --cmake=intel64.make.release -build /home/gotron/gotron/IMSDK2015/MediaSamples_Linux_5.0.1604371.71/samples/sample_common/src/plugin_utils.cpp:98:24: error: \u2018MFX_PLUGINID_HEVCE_FEI_HW\u2019 was not declared in this scope return MFX_PLUGINID_HEVCE_FEI_HW; // HEVC FEI uses ENC interface ^ gmake[2]: *** [sample_common/CMakeFiles/sample_common_drm.dir/src/plugin_utils.cpp.o] Error 1 gmake[2]: Leaving directory `/home/gotron/gotron/IMSDK2015/MediaSamples_Linux_5.0.1604371.71/samples/__cmake/intel64.make.release' gmake[1]: *** [sample_common/CMakeFiles/sample_common_drm.dir/all] Error 2 gmake[1]: Leaving directory `/home/gotron/gotron/IMSDK2015/MediaSamples_Linux_5.0.1604371.71/samples/__cmake/intel64.make.release' gmake: *** [all] Error 2 [ intel64.make.release State: FAIL ]
Here is my install process:
From SDK2015PreviewEvaluation16.4 directory
- ./install_sdk_UMD.sh
- ./install_KMD.sh
- reboot to 3.10.0MSSr2
- Copied over mfxhei.h to /opt/intel/mediasdk/include
- cd /home/gotron/gotron/IMSDK2015/MediaServerStudioProfessionalEvaluation2015R2/HEVCEvaluation2015
- ./install.sh
- Then builded the samples: perl build.pl --cmake=intel64.make.release -build
[root@localhost samples]# lsmod |grep 'i915' i915 730175 2 i2c_algo_bit 13413 1 i915 drm_kms_helper 52758 1 i915 drm 297577 2 i915,drm_kms_helper i2c_core 40325 5 drm,i915,i2c_i801,drm_kms_helper,i2c_algo_bit video 19267 1 i915
Did I do something wrong ?
Thanks in advance !
Hi Zhu,
Could you please try the latest release of Media Server Studio - 2015 R3 - it has been released very recently and is available as eval version on the web. If the problem still exists, please report back and we will look into it.
Nina
Nina Kurina (Intel) wrote:Hi Nina. Thanks for reply. I tried another sample packages MediaSamples-Linux-5.0.1603344.93446, then builded it with no errors.
Hi Zhu,
Nina
export MFX_HOME=/opt/intel/mediasdk export LD_LIBRARY_PATH=$MFX_HOME/lib64 SAMPLE_BIN="/home/gotron/gotron/IMSDK2015/MediaSamples-Linux-5.0.1603344.93446/samples/__cmake/intel64.make.release/__bin/release" export PATH=$SAMPLE_BIN:$PATH Actually , I don't known if these Envionments above are necessary. [root@localhost gotron]# uname -ar Linux localhost.localdomain 3.10.0MSSr2 #1 SMP Tue Dec 23 02:59:08 EST 2014 x86_64 x86_64 x86_64 GNU/Linux [root@localhost gotron]# sample_multi_transcode_drm -i::h264 f.h264 -o::h264 test_out.h264 -hw Intel(R) Media SDK Multi Transcoding Sample Version 0.0.000.0000 terminate called after throwing an instance of 'std::bad_alloc' what(): std::bad_alloc Aborted (core dumped) [root@localhost gotron]#
Here is my dmesg:
There seems to be something wrong with it.
I didn't found any device under /dev/dri/
[ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0MSSr2 (root@localhost.localdomain) (gcc version 4.8.2 20140120 (Red Hat 4.8.2-16) (GCC) ) #1 SMP Tue Dec 23 02:59:08 EST 2014 [ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-3.10.0MSSr2 root=/dev/mapper/centos-root ro rd.lvm.lv=centos/swap nomodeset crashkernel=auto vconsole.keymap=us vconsole.font=latarcyrheb-sun16 rd.lvm.lv=centos/root rhgb quiet LANG=en_US.UTF-8 [ 0.000000] e820: BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable [ 0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000ad7dafff] usable [ 0.000000] BIOS-e820: [mem 0x00000000ad7db000-0x00000000ad7e1fff] ACPI NVS [ 0.000000] BIOS-e820: [mem 0x00000000ad7e2000-0x00000000ae2b7fff] usable [ 0.000000] BIOS-e820: [mem 0x00000000ae2b8000-0x00000000ae810fff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000ae811000-0x00000000c0e36fff] usable [ 0.000000] BIOS-e820: [mem 0x00000000c0e37000-0x00000000c0ecefff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000c0ecf000-0x00000000c0f14fff] usable [ 0.000000] BIOS-e820: [mem 0x00000000c0f15000-0x00000000c0fccfff] ACPI NVS [ 0.000000] BIOS-e820: [mem 0x00000000c0fcd000-0x00000000c2ffefff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000c2fff000-0x00000000c2ffffff] usable [ 0.000000] BIOS-e820: [mem 0x00000000c3800000-0x00000000df9fffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved [ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000011f5fffff] usable [ 0.000000] NX (Execute Disable) protection: active [ 0.000000] SMBIOS 2.7 present. [ 0.000000] DMI: Gigabyte Technology Co., Ltd. Z87M-D3H/Z87M-D3H, BIOS F11 08/12/2014 [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable [ 0.000000] No AGP bridge found [ 0.000000] e820: last_pfn = 0x11f600 max_arch_pfn = 0x400000000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-CFFFF write-protect [ 0.000000] D0000-E7FFF uncachable [ 0.000000] E8000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 0000000000 mask 7F00000000 write-back [ 0.000000] 1 base 0100000000 mask 7FE0000000 write-back [ 0.000000] 2 base 00E0000000 mask 7FE0000000 uncachable [ 0.000000] 3 base 00D0000000 mask 7FF0000000 uncachable [ 0.000000] 4 base 00C8000000 mask 7FF8000000 uncachable [ 0.000000] 5 base 00C4000000 mask 7FFC000000 uncachable [ 0.000000] 6 base 00C3800000 mask 7FFF800000 uncachable [ 0.000000] 7 base 011F800000 mask 7FFF800000 uncachable [ 0.000000] 8 base 011F600000 mask 7FFFE00000 uncachable [ 0.000000] 9 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] original variable MTRRs [ 0.000000] reg 0, base: 0GB, range: 4GB, type WB [ 0.000000] reg 1, base: 4GB, range: 512MB, type WB [ 0.000000] reg 2, base: 3584MB, range: 512MB, type UC [ 0.000000] reg 3, base: 3328MB, range: 256MB, type UC [ 0.000000] reg 4, base: 3200MB, range: 128MB, type UC [ 0.000000] reg 5, base: 3136MB, range: 64MB, type UC [ 0.000000] reg 6, base: 3128MB, range: 8MB, type UC [ 0.000000] reg 7, base: 4600MB, range: 8MB, type UC [ 0.000000] reg 8, base: 4598MB, range: 2MB, type UC [ 0.000000] total RAM covered: 3630M [ 0.000000] Found optimal setting for mtrr clean up [ 0.000000] gran_size: 64K chunk_size: 16M num_reg: 7 lose cover RAM: 0G [ 0.000000] New variable MTRRs [ 0.000000] reg 0, base: 0GB, range: 2GB, type WB [ 0.000000] reg 1, base: 2GB, range: 1GB, type WB [ 0.000000] reg 2, base: 3GB, range: 64MB, type WB [ 0.000000] reg 3, base: 3128MB, range: 8MB, type UC [ 0.000000] reg 4, base: 4GB, range: 512MB, type WB [ 0.000000] reg 5, base: 4598MB, range: 2MB, type UC [ 0.000000] reg 6, base: 4600MB, range: 8MB, type UC [ 0.000000] e820: update [mem 0xc3800000-0xffffffff] usable ==> reserved [ 0.000000] e820: last_pfn = 0xc3000 max_arch_pfn = 0x400000000 [ 0.000000] found SMP MP-table at [mem 0x000fd6e0-0x000fd6ef] mapped at [ffff8800000fd6e0] [ 0.000000] Base memory trampoline at [ffff880000097000] 97000 size 24576 [ 0.000000] Using GB pages for direct mapping [ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff] [ 0.000000] [mem 0x00000000-0x000fffff] page 4k [ 0.000000] BRK [0x01e20000, 0x01e20fff] PGTABLE [ 0.000000] BRK [0x01e21000, 0x01e21fff] PGTABLE [ 0.000000] BRK [0x01e22000, 0x01e22fff] PGTABLE [ 0.000000] init_memory_mapping: [mem 0x11f400000-0x11f5fffff] [ 0.000000] [mem 0x11f400000-0x11f5fffff] page 2M [ 0.000000] BRK [0x01e23000, 0x01e23fff] PGTABLE [ 0.000000] init_memory_mapping: [mem 0x11c000000-0x11f3fffff] [ 0.000000] [mem 0x11c000000-0x11f3fffff] page 2M [ 0.000000] init_memory_mapping: [mem 0x100000000-0x11bffffff] [ 0.000000] [mem 0x100000000-0x11bffffff] page 2M [ 0.000000] init_memory_mapping: [mem 0x00100000-0xad7dafff] [ 0.000000] [mem 0x00100000-0x001fffff] page 4k [ 0.000000] [mem 0x00200000-0x3fffffff] page 2M [ 0.000000] [mem 0x40000000-0x7fffffff] page 1G [ 0.000000] [mem 0x80000000-0xad5fffff] page 2M [ 0.000000] [mem 0xad600000-0xad7dafff] page 4k [ 0.000000] init_memory_mapping: [mem 0xad7e2000-0xae2b7fff] [ 0.000000] [mem 0xad7e2000-0xad7fffff] page 4k [ 0.000000] [mem 0xad800000-0xae1fffff] page 2M [ 0.000000] [mem 0xae200000-0xae2b7fff] page 4k [ 0.000000] BRK [0x01e24000, 0x01e24fff] PGTABLE [ 0.000000] init_memory_mapping: [mem 0xae811000-0xc0e36fff] [ 0.000000] [mem 0xae811000-0xae9fffff] page 4k [ 0.000000] [mem 0xaea00000-0xc0dfffff] page 2M [ 0.000000] [mem 0xc0e00000-0xc0e36fff] page 4k [ 0.000000] BRK [0x01e25000, 0x01e25fff] PGTABLE [ 0.000000] init_memory_mapping: [mem 0xc0ecf000-0xc0f14fff] [ 0.000000] [mem 0xc0ecf000-0xc0f14fff] page 4k [ 0.000000] init_memory_mapping: [mem 0xc2fff000-0xc2ffffff] [ 0.000000] [mem 0xc2fff000-0xc2ffffff] page 4k [ 0.000000] RAMDISK: [mem 0x33699000-0x35b44fff] [ 0.000000] Reserving 161MB of memory at 656MB for crashkernel (System RAM: 3582MB) [ 0.000000] ACPI: RSDP 00000000000f0490 00024 (v02 ALASKA) [ 0.000000] ACPI: XSDT 00000000c0f99078 0006C (v01 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: FACP 00000000c0fa5e08 0010C (v05 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: DSDT 00000000c0f99178 0CC8D (v02 ALASKA A M I 00000088 INTL 20091112) [ 0.000000] ACPI: FACS 00000000c0fcb080 00040 [ 0.000000] ACPI: APIC 00000000c0fa5f18 00072 (v03 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: FPDT 00000000c0fa5f90 00044 (v01 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: SSDT 00000000c0fa5fd8 00539 (v01 PmRef Cpu0Ist 00003000 INTL 20120711) [ 0.000000] ACPI: SSDT 00000000c0fa6518 00AD8 (v01 PmRef CpuPm 00003000 INTL 20120711) [ 0.000000] ACPI: MCFG 00000000c0fa6ff0 0003C (v01 ALASKA A M I 01072009 MSFT 00000097) [ 0.000000] ACPI: HPET 00000000c0fa7030 00038 (v01 ALASKA A M I 01072009 AMI. 00000005) [ 0.000000] ACPI: SSDT 00000000c0fa7068 0036D (v01 SataRe SataTabl 00001000 INTL 20120711) [ 0.000000] ACPI: SSDT 00000000c0fa73d8 034E1 (v01 SaSsdt SaSsdt 00003000 INTL 20091112) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] No NUMA configuration found [ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000011f5fffff] [ 0.000000] Initmem setup node 0 [mem 0x00000000-0x11f5fffff] [ 0.000000] NODE_DATA [mem 0x11f5d4000-0x11f5fafff] [ 0.000000] [ffffea0000000000-ffffea00047fffff] PMD -> [ffff88011b200000-ffff88011ebfffff] on node 0 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x00001000-0x00ffffff] [ 0.000000] DMA32 [mem 0x01000000-0xffffffff] [ 0.000000] Normal [mem 0x100000000-0x11f5fffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x00001000-0x0009cfff] [ 0.000000] node 0: [mem 0x00100000-0xad7dafff] [ 0.000000] node 0: [mem 0xad7e2000-0xae2b7fff] [ 0.000000] node 0: [mem 0xae811000-0xc0e36fff] [ 0.000000] node 0: [mem 0xc0ecf000-0xc0f14fff] [ 0.000000] node 0: [mem 0xc2fff000-0xc2ffffff] [ 0.000000] node 0: [mem 0x100000000-0x11f5fffff] [ 0.000000] On node 0 totalpages: 917178 [ 0.000000] DMA zone: 64 pages used for memmap [ 0.000000] DMA zone: 21 pages reserved [ 0.000000] DMA zone: 3996 pages, LIFO batch:0 [ 0.000000] DMA32 zone: 12261 pages used for memmap [ 0.000000] DMA32 zone: 784670 pages, LIFO batch:31 [ 0.000000] Normal zone: 2008 pages used for memmap [ 0.000000] Normal zone: 128512 pages, LIFO batch:31 [ 0.000000] ACPI: PM-Timer IO Port: 0x1808 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1]) [ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000 [ 0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff] [ 0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff] [ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff] [ 0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff] [ 0.000000] PM: Registered nosave memory: [mem 0xad7db000-0xad7e1fff] [ 0.000000] PM: Registered nosave memory: [mem 0xae2b8000-0xae810fff] [ 0.000000] PM: Registered nosave memory: [mem 0xc0e37000-0xc0ecefff] [ 0.000000] PM: Registered nosave memory: [mem 0xc0f15000-0xc0fccfff] [ 0.000000] PM: Registered nosave memory: [mem 0xc0fcd000-0xc2ffefff] [ 0.000000] PM: Registered nosave memory: [mem 0xc3000000-0xc37fffff] [ 0.000000] PM: Registered nosave memory: [mem 0xc3800000-0xdf9fffff] [ 0.000000] PM: Registered nosave memory: [mem 0xdfa00000-0xf7ffffff] [ 0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff] [ 0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff] [ 0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff] [ 0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff] [ 0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff] [ 0.000000] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff] [ 0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff] [ 0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff] [ 0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff] [ 0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff] [ 0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff] [ 0.000000] e820: [mem 0xdfa00000-0xf7ffffff] available for PCI devices [ 0.000000] Booting paravirtualized kernel on bare hardware [ 0.000000] setup_percpu: NR_CPUS:5120 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 29 pages/cpu @ffff88011f200000 s86656 r8192 d23936 u524288 [ 0.000000] pcpu-alloc: s86656 r8192 d23936 u524288 alloc=1*2097152 [ 0.000000] pcpu-alloc: [0] 0 1 2 3 [ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 902824 [ 0.000000] Policy zone: Normal [ 0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-3.10.0MSSr2 root=/dev/mapper/centos-root ro rd.lvm.lv=centos/swap nomodeset crashkernel=auto vconsole.keymap=us vconsole.font=latarcyrheb-sun16 rd.lvm.lv=centos/root rhgb quiet LANG=en_US.UTF-8 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] xsave: enabled xstate_bv 0x7, cntxt size 0x340 [ 0.000000] Checking aperture... [ 0.000000] No AGP bridge found [ 0.000000] Memory: 3325384k/4708352k available (6109k kernel code, 1039640k absent, 343328k reserved, 4070k data, 1584k init) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] RCU restricting CPUs from NR_CPUS=5120 to nr_cpu_ids=4. [ 0.000000] Experimental no-CBs for all CPUs [ 0.000000] Experimental no-CBs CPUs: 0-3. [ 0.000000] NR_IRQS:327936 nr_irqs:712 16 [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] allocated 15204352 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] hpet clockevent registered [ 0.000000] tsc: Fast TSC calibration using PIT [ 0.001000] spurious 8259A interrupt: IRQ7. [ 0.002000] tsc: Detected 2992.983 MHz processor [ 0.000002] Calibrating delay loop (skipped), value calculated using timer frequency.. 5985.96 BogoMIPS (lpj=2992983) [ 0.000005] pid_max: default: 32768 minimum: 301 [ 0.000025] Security Framework initialized [ 0.000031] SELinux: Initializing. [ 0.000038] SELinux: Starting in permissive mode [ 0.000287] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.001133] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.001491] Mount-cache hash table entries: 4096 [ 0.001669] Initializing cgroup subsys memory [ 0.001677] Initializing cgroup subsys devices [ 0.001679] Initializing cgroup subsys freezer [ 0.001680] Initializing cgroup subsys net_cls [ 0.001681] Initializing cgroup subsys blkio [ 0.001682] Initializing cgroup subsys perf_event [ 0.001684] Initializing cgroup subsys hugetlb [ 0.001712] CPU: Physical Processor ID: 0 [ 0.001713] CPU: Processor Core ID: 0 [ 0.003419] mce: CPU supports 7 MCE banks [ 0.003437] CPU0: Thermal monitoring enabled (TM1) [ 0.003451] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0 Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0 tlb_flushall_shift: 6 [ 0.003535] Freeing SMP alternatives: 24k freed [ 0.004398] ACPI: Core revision 20130517 [ 0.010300] ACPI: All ACPI Tables successfully acquired [ 0.010745] ftrace: allocating 23394 entries in 92 pages [ 0.019937] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0 [ 0.029936] smpboot: CPU0: Intel(R) Core(TM) i3-4330T CPU @ 3.00GHz (fam: 06, model: 3c, stepping: 03) [ 0.029943] TSC deadline timer enabled [ 0.029949] Performance Events: PEBS fmt2+, 16-deep LBR, Haswell events, full-width counters, Intel PMU driver. [ 0.029955] ... version: 3 [ 0.029956] ... bit width: 48 [ 0.029956] ... generic registers: 4 [ 0.029957] ... value mask: 0000ffffffffffff [ 0.029958] ... max period: 0000ffffffffffff [ 0.029958] ... fixed-purpose events: 3 [ 0.029959] ... event mask: 000000070000000f [ 0.046038] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter. [ 0.031042] smpboot: Booting Node 0, Processors #1 #2 #3 OK [ 0.076072] Brought up 4 CPUs [ 0.076076] smpboot: Total of 4 processors activated (23943.86 BogoMIPS) [ 0.080088] devtmpfs: initialized [ 0.080681] EVM: security.selinux [ 0.080682] EVM: security.ima [ 0.080683] EVM: security.capability [ 0.080735] PM: Registering ACPI NVS region [mem 0xad7db000-0xad7e1fff] (28672 bytes) [ 0.080737] PM: Registering ACPI NVS region [mem 0xc0f15000-0xc0fccfff] (753664 bytes) [ 0.081296] atomic64 test passed for x86-64 platform with CX8 and with SSE [ 0.081328] NET: Registered protocol family 16 [ 0.081433] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it [ 0.081435] ACPI: bus type PCI registered [ 0.081436] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 0.081475] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000) [ 0.081477] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820 [ 0.086254] PCI: Using configuration type 1 for base access [ 0.086810] bio: create slab <bio-0> at 0 [ 0.086909] ACPI: Added _OSI(Module Device) [ 0.086910] ACPI: Added _OSI(Processor Device) [ 0.086912] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.086913] ACPI: Added _OSI(Processor Aggregator Device) [ 0.088199] ACPI: EC: Look up EC in DSDT [ 0.089772] ACPI: Executed 1 blocks of module-level executable AML code [ 0.091735] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored [ 0.094944] ACPI: SSDT 00000000c0ec4c18 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20120711) [ 0.095265] ACPI: Dynamic OEM Table Load: [ 0.095267] ACPI: SSDT (null) 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20120711) [ 0.097039] ACPI: SSDT 00000000c0ec4618 005AA (v01 PmRef ApIst 00003000 INTL 20120711) [ 0.097414] ACPI: Dynamic OEM Table Load: [ 0.097415] ACPI: SSDT (null) 005AA (v01 PmRef ApIst 00003000 INTL 20120711) [ 0.099943] ACPI: SSDT 00000000c0ec3d98 00119 (v01 PmRef ApCst 00003000 INTL 20120711) [ 0.100261] ACPI: Dynamic OEM Table Load: [ 0.100262] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20120711) [ 0.102391] ACPI: Interpreter enabled [ 0.102397] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_] (20130517/hwxface-571) [ 0.102402] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20130517/hwxface-571) [ 0.102414] ACPI: (supports S0 S3 S4 S5) [ 0.102415] ACPI: Using IOAPIC for interrupt routing [ 0.102435] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.102536] ACPI: No dock devices found. [ 0.108571] ACPI: Power Resource [FN00] (off) [ 0.108620] ACPI: Power Resource [FN01] (off) [ 0.108668] ACPI: Power Resource [FN02] (off) [ 0.108713] ACPI: Power Resource [FN03] (off) [ 0.108758] ACPI: Power Resource [FN04] (off) [ 0.109306] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e]) [ 0.109311] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI] [ 0.109473] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME] [ 0.109561] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability] [ 0.109904] PCI host bridge to bus 0000:00 [ 0.109907] pci_bus 0000:00: root bus resource [bus 00-3e] [ 0.109909] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7] [ 0.109910] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff] [ 0.109911] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.109912] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff] [ 0.109913] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff] [ 0.109914] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff] [ 0.109915] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff] [ 0.109916] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff] [ 0.109917] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff] [ 0.109918] pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff] [ 0.109926] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000 [ 0.109998] pci 0000:00:02.0: [8086:0412] type 00 class 0x030000 [ 0.110011] pci 0000:00:02.0: reg 0x10: [mem 0xf7800000-0xf7bfffff 64bit] [ 0.110018] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref] [ 0.110023] pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f] [ 0.110086] pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300 [ 0.110093] pci 0000:00:03.0: reg 0x10: [mem 0xf7d14000-0xf7d17fff 64bit] [ 0.110183] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330 [ 0.110201] pci 0000:00:14.0: reg 0x10: [mem 0xf7d00000-0xf7d0ffff 64bit] [ 0.110262] pci 0000:00:14.0: PME# supported from D3hot D3cold [ 0.110293] pci 0000:00:14.0: System wakeup disabled by ACPI [ 0.110315] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000 [ 0.110334] pci 0000:00:16.0: reg 0x10: [mem 0xf7d1e000-0xf7d1e00f 64bit] [ 0.110398] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold [ 0.110457] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320 [ 0.110476] pci 0000:00:1a.0: reg 0x10: [mem 0xf7d1c000-0xf7d1c3ff] [ 0.110564] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold [ 0.110608] pci 0000:00:1a.0: System wakeup disabled by ACPI [ 0.110633] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300 [ 0.110647] pci 0000:00:1b.0: reg 0x10: [mem 0xf7d10000-0xf7d13fff 64bit] [ 0.110717] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.110749] pci 0000:00:1b.0: System wakeup disabled by ACPI [ 0.110769] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400 [ 0.110834] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.110867] pci 0000:00:1c.0: System wakeup disabled by ACPI [ 0.110887] pci 0000:00:1c.2: [8086:8c14] type 01 class 0x060400 [ 0.110957] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold [ 0.110990] pci 0000:00:1c.2: System wakeup disabled by ACPI [ 0.111011] pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400 [ 0.111076] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold [ 0.111109] pci 0000:00:1c.3: System wakeup disabled by ACPI [ 0.111137] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320 [ 0.111156] pci 0000:00:1d.0: reg 0x10: [mem 0xf7d1b000-0xf7d1b3ff] [ 0.111244] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold [ 0.111286] pci 0000:00:1d.0: System wakeup disabled by ACPI [ 0.111310] pci 0000:00:1f.0: [8086:8c44] type 00 class 0x060100 [ 0.111456] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601 [ 0.111471] pci 0000:00:1f.2: reg 0x10: [io 0xf0b0-0xf0b7] [ 0.111478] pci 0000:00:1f.2: reg 0x14: [io 0xf0a0-0xf0a3] [ 0.111485] pci 0000:00:1f.2: reg 0x18: [io 0xf090-0xf097] [ 0.111492] pci 0000:00:1f.2: reg 0x1c: [io 0xf080-0xf083] [ 0.111499] pci 0000:00:1f.2: reg 0x20: [io 0xf060-0xf07f] [ 0.111506] pci 0000:00:1f.2: reg 0x24: [mem 0xf7d1a000-0xf7d1a7ff] [ 0.111541] pci 0000:00:1f.2: PME# supported from D3hot [ 0.111585] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500 [ 0.111599] pci 0000:00:1f.3: reg 0x10: [mem 0xf7d19000-0xf7d190ff 64bit] [ 0.111619] pci 0000:00:1f.3: reg 0x20: [io 0xf040-0xf05f] [ 0.111731] acpiphp: Slot [1] registered [ 0.111736] pci 0000:00:1c.0: PCI bridge to [bus 01] [ 0.111807] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000 [ 0.111823] pci 0000:02:00.0: reg 0x10: [io 0xe000-0xe0ff] [ 0.111852] pci 0000:02:00.0: reg 0x18: [mem 0xf7c00000-0xf7c00fff 64bit] [ 0.111871] pci 0000:02:00.0: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref] [ 0.111965] pci 0000:02:00.0: supports D1 D2 [ 0.111966] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.111996] pci 0000:02:00.0: System wakeup disabled by ACPI [ 0.113922] pci 0000:00:1c.2: PCI bridge to [bus 02] [ 0.113925] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff] [ 0.113928] pci 0000:00:1c.2: bridge window [mem 0xf7c00000-0xf7cfffff] [ 0.113932] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref] [ 0.114000] pci 0000:03:00.0: [8086:244e] type 01 class 0x060401 [ 0.114133] pci 0000:03:00.0: supports D1 D2 [ 0.114134] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.114158] pci 0000:03:00.0: System wakeup disabled by ACPI [ 0.114175] pci 0000:00:1c.3: PCI bridge to [bus 03-04] [ 0.114303] pci 0000:03:00.0: PCI bridge to [bus 04] (subtractive decode) [ 0.114325] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode) [ 0.114326] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode) [ 0.114327] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode) [ 0.114328] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode) [ 0.114355] acpi PNP0A08:00: Disabling ASPM (FADT indicates it is unsupported) [ 0.114980] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.115015] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled. [ 0.115047] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.115079] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15) [ 0.115111] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled. [ 0.115142] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled. [ 0.115174] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 10 11 12 14 15) [ 0.115206] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15) [ 0.115469] ACPI: Enabled 4 GPEs in block 00 to 3F [ 0.115475] ACPI: \_SB_.PCI0: notify handler is installed [ 0.115524] Found 1 acpi root devices [ 0.115585] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none [ 0.115587] vgaarb: loaded [ 0.115588] vgaarb: bridge control possible 0000:00:02.0 [ 0.115629] SCSI subsystem initialized [ 0.115644] ACPI: bus type USB registered [ 0.115654] usbcore: registered new interface driver usbfs [ 0.115658] usbcore: registered new interface driver hub [ 0.115683] usbcore: registered new device driver usb [ 0.115738] PCI: Using ACPI for IRQ routing [ 0.117119] PCI: pci_cache_line_size set to 64 bytes [ 0.117163] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff] [ 0.117164] e820: reserve RAM buffer [mem 0xad7db000-0xafffffff] [ 0.117165] e820: reserve RAM buffer [mem 0xae2b8000-0xafffffff] [ 0.117166] e820: reserve RAM buffer [mem 0xc0e37000-0xc3ffffff] [ 0.117167] e820: reserve RAM buffer [mem 0xc0f15000-0xc3ffffff] [ 0.117168] e820: reserve RAM buffer [mem 0xc3000000-0xc3ffffff] [ 0.117169] e820: reserve RAM buffer [mem 0x11f600000-0x11fffffff] [ 0.117236] NetLabel: Initializing [ 0.117237] NetLabel: domain hash size = 128 [ 0.117238] NetLabel: protocols = UNLABELED CIPSOv4 [ 0.117245] NetLabel: unlabeled traffic allowed by default [ 0.117273] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0 [ 0.117276] hpet0: 8 comparators, 64-bit 14.318180 MHz counter [ 0.119288] Switching to clocksource hpet [ 0.122767] pnp: PnP ACPI init [ 0.122777] ACPI: bus type PNP registered [ 0.122844] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved [ 0.122847] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.122856] pnp 00:01: [dma 4] [ 0.122867] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.122878] pnp 00:02: Plug and Play ACPI device, IDs INT0800 (active) [ 0.122957] pnp 00:03: Plug and Play ACPI device, IDs PNP0103 (active) [ 0.122991] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.123070] system 00:05: [io 0x0680-0x069f] has been reserved [ 0.123072] system 00:05: [io 0xffff] has been reserved [ 0.123073] system 00:05: [io 0xffff] has been reserved [ 0.123074] system 00:05: [io 0xffff] has been reserved [ 0.123075] system 00:05: [io 0x1c00-0x1cfe] has been reserved [ 0.123076] system 00:05: [io 0x1d00-0x1dfe] has been reserved [ 0.123078] system 00:05: [io 0x1e00-0x1efe] has been reserved [ 0.123079] system 00:05: [io 0x1f00-0x1ffe] has been reserved [ 0.123080] system 00:05: [io 0x1800-0x18fe] could not be reserved [ 0.123081] system 00:05: [io 0x164e-0x164f] has been reserved [ 0.123083] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.123098] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.123129] system 00:07: [io 0x1854-0x1857] has been reserved [ 0.123131] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active) [ 0.123211] system 00:08: [io 0x0a00-0x0a0f] has been reserved [ 0.123212] system 00:08: [io 0x0a30-0x0a3f] has been reserved [ 0.123214] system 00:08: [io 0x0a20-0x0a2f] has been reserved [ 0.123215] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.123403] pnp 00:09: [dma 0 disabled] [ 0.123433] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.123626] pnp 00:0a: [dma 0 disabled] [ 0.123698] pnp 00:0a: Plug and Play ACPI device, IDs PNP0400 (active) [ 0.123729] system 00:0b: [io 0x04d0-0x04d1] has been reserved [ 0.123731] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.124028] system 00:0c: [mem 0xfed1c000-0xfed1ffff] has been reserved [ 0.124030] system 00:0c: [mem 0xfed10000-0xfed17fff] has been reserved [ 0.124031] system 00:0c: [mem 0xfed18000-0xfed18fff] has been reserved [ 0.124032] system 00:0c: [mem 0xfed19000-0xfed19fff] has been reserved [ 0.124034] system 00:0c: [mem 0xf8000000-0xfbffffff] has been reserved [ 0.124035] system 00:0c: [mem 0xfed20000-0xfed3ffff] has been reserved [ 0.124036] system 00:0c: [mem 0xfed90000-0xfed93fff] has been reserved [ 0.124037] system 00:0c: [mem 0xfed45000-0xfed8ffff] has been reserved [ 0.124038] system 00:0c: [mem 0xff000000-0xffffffff] has been reserved [ 0.124040] system 00:0c: [mem 0xfee00000-0xfeefffff] could not be reserved [ 0.124041] system 00:0c: [mem 0xf7fdf000-0xf7fdffff] has been reserved [ 0.124042] system 00:0c: [mem 0xf7fe0000-0xf7feffff] has been reserved [ 0.124044] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.124205] pnp: PnP ACPI: found 13 devices [ 0.124206] ACPI: bus type PNP unregistered [ 0.130134] pci 0000:00:1c.0: PCI bridge to [bus 01] [ 0.130146] pci 0000:00:1c.2: PCI bridge to [bus 02] [ 0.130148] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff] [ 0.130152] pci 0000:00:1c.2: bridge window [mem 0xf7c00000-0xf7cfffff] [ 0.130156] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref] [ 0.130161] pci 0000:03:00.0: PCI bridge to [bus 04] [ 0.130181] pci 0000:00:1c.3: PCI bridge to [bus 03-04] [ 0.130192] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7] [ 0.130193] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff] [ 0.130195] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff] [ 0.130196] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff] [ 0.130197] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff] [ 0.130198] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff] [ 0.130199] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff] [ 0.130200] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff] [ 0.130201] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff] [ 0.130202] pci_bus 0000:00: resource 13 [mem 0xdfa00000-0xfeafffff] [ 0.130203] pci_bus 0000:02: resource 0 [io 0xe000-0xefff] [ 0.130204] pci_bus 0000:02: resource 1 [mem 0xf7c00000-0xf7cfffff] [ 0.130206] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref] [ 0.130229] NET: Registered protocol family 2 [ 0.130370] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 0.130439] TCP bind hash table entries: 32768 (order: 7, 524288 bytes) [ 0.130528] TCP: Hash tables configured (established 32768 bind 32768) [ 0.130552] TCP: reno registered [ 0.130558] UDP hash table entries: 2048 (order: 4, 65536 bytes) [ 0.130576] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes) [ 0.130629] NET: Registered protocol family 1 [ 0.130638] pci 0000:00:02.0: Boot video device [ 0.160365] PCI: CLS 64 bytes, default 64 [ 0.160404] Unpacking initramfs... [ 0.626365] Freeing initrd memory: 37552k freed [ 0.632604] PCI-DMA: Using software bounce buffering for IO (SWIOTLB) [ 0.632607] software IO TLB [mem 0xbce37000-0xc0e37000] (64MB) mapped at [ffff8800bce37000-ffff8800c0e36fff] [ 0.632953] microcode: CPU0 sig=0x306c3, pf=0x2, revision=0x19 [ 0.632960] microcode: CPU1 sig=0x306c3, pf=0x2, revision=0x19 [ 0.632968] microcode: CPU2 sig=0x306c3, pf=0x2, revision=0x19 [ 0.632975] microcode: CPU3 sig=0x306c3, pf=0x2, revision=0x19 [ 0.633000] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba [ 0.633167] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.633178] Initialise system trusted keyring [ 0.633209] audit: initializing netlink socket (disabled) [ 0.633219] type=2000 audit(1419407435.623:1): initialized [ 0.649661] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 0.650394] zbud: loaded [ 0.650507] VFS: Disk quotas dquot_6.5.2 [ 0.650530] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.650646] msgmni has been set to 6568 [ 0.650685] Key type big_key registered [ 0.650686] SELinux: Registering netfilter hooks [ 0.651325] alg: No test for stdrng (krng) [ 0.651332] NET: Registered protocol family 38 [ 0.651335] Key type asymmetric registered [ 0.651336] Asymmetric key parser 'x509' registered [ 0.651360] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) [ 0.651393] io scheduler noop registered [ 0.651394] io scheduler deadline registered (default) [ 0.651409] io scheduler cfq registered [ 0.651754] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 0.651765] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 0.651806] intel_idle: MWAIT substates: 0x42120 [ 0.651807] intel_idle: v0.4 model 0x3C [ 0.651808] intel_idle: lapic_timer_reliable_states 0xffffffff [ 0.651890] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0 [ 0.651894] ACPI: Power Button [PWRB] [ 0.651917] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1 [ 0.651919] ACPI: Power Button [PWRF] [ 0.651966] ACPI: Fan [FAN0] (off) [ 0.651981] ACPI: Fan [FAN1] (off) [ 0.651996] ACPI: Fan [FAN2] (off) [ 0.652008] ACPI: Fan [FAN3] (off) [ 0.652023] ACPI: Fan [FAN4] (off) [ 0.652061] ACPI: Requesting acpi_cpufreq [ 0.652537] thermal LNXTHERM:00: registered as thermal_zone0 [ 0.652539] ACPI: Thermal Zone [TZ00] (28 C) [ 0.652678] thermal LNXTHERM:01: registered as thermal_zone1 [ 0.652679] ACPI: Thermal Zone [TZ01] (30 C) [ 0.652702] GHES: HEST is not enabled! [ 0.652749] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.673319] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.673718] Non-volatile memory driver v1.3 [ 0.673719] Linux agpgart interface v0.103 [ 0.673775] crash memory driver: version 1.1 [ 0.673792] rdac: device handler registered [ 0.673827] hp_sw: device handler registered [ 0.673829] emc: device handler registered [ 0.673829] alua: device handler registered [ 0.673851] libphy: Fixed MDIO Bus: probed [ 0.673884] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.673886] ehci-pci: EHCI PCI platform driver [ 0.673960] ehci-pci 0000:00:1a.0: EHCI Host Controller [ 0.673997] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1 [ 0.674009] ehci-pci 0000:00:1a.0: debug port 2 [ 0.677899] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported [ 0.677913] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7d1c000 [ 0.683108] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00 [ 0.683142] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.683143] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.683144] usb usb1: Product: EHCI Host Controller [ 0.683145] usb usb1: Manufacturer: Linux 3.10.0MSSr2 ehci_hcd [ 0.683146] usb usb1: SerialNumber: 0000:00:1a.0 [ 0.683219] hub 1-0:1.0: USB hub found [ 0.683223] hub 1-0:1.0: 2 ports detected [ 0.683359] ehci-pci 0000:00:1d.0: EHCI Host Controller [ 0.683391] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2 [ 0.683402] ehci-pci 0000:00:1d.0: debug port 2 [ 0.687295] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported [ 0.687308] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7d1b000 [ 0.693100] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00 [ 0.693124] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.693126] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.693127] usb usb2: Product: EHCI Host Controller [ 0.693128] usb usb2: Manufacturer: Linux 3.10.0MSSr2 ehci_hcd [ 0.693129] usb usb2: SerialNumber: 0000:00:1d.0 [ 0.693209] hub 2-0:1.0: USB hub found [ 0.693213] hub 2-0:1.0: 2 ports detected [ 0.693293] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.693294] ohci-pci: OHCI PCI platform driver [ 0.693299] uhci_hcd: USB Universal Host Controller Interface driver [ 0.693379] xhci_hcd 0000:00:14.0: xHCI Host Controller [ 0.693418] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3 [ 0.693514] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported [ 0.693532] xhci_hcd 0000:00:14.0: irq 40 for MSI/MSI-X [ 0.693588] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.693589] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.693590] usb usb3: Product: xHCI Host Controller [ 0.693591] usb usb3: Manufacturer: Linux 3.10.0MSSr2 xhci_hcd [ 0.693592] usb usb3: SerialNumber: 0000:00:14.0 [ 0.693655] hub 3-0:1.0: USB hub found [ 0.693672] hub 3-0:1.0: 14 ports detected [ 0.696154] xhci_hcd 0000:00:14.0: xHCI Host Controller [ 0.696184] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4 [ 0.696213] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 0.696214] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.696215] usb usb4: Product: xHCI Host Controller [ 0.696216] usb usb4: Manufacturer: Linux 3.10.0MSSr2 xhci_hcd [ 0.696217] usb usb4: SerialNumber: 0000:00:14.0 [ 0.696281] hub 4-0:1.0: USB hub found [ 0.696292] hub 4-0:1.0: 6 ports detected [ 0.702142] usbcore: registered new interface driver usbserial [ 0.702147] usbcore: registered new interface driver usbserial_generic [ 0.702151] usbserial: USB Serial support registered for generic [ 0.702169] i8042: PNP: No PS/2 controller found. Probing ports directly. [ 0.702532] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 0.702535] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 0.702604] mousedev: PS/2 mouse device common for all mice [ 0.702745] rtc_cmos 00:06: RTC can wake from S4 [ 0.702865] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0 [ 0.702892] rtc_cmos 00:06: alarms up to one month, y3k, 242 bytes nvram, hpet irqs [ 0.702903] Intel P-state driver initializing. [ 0.702914] Intel pstate controlling: cpu 0 [ 0.702927] Intel pstate controlling: cpu 1 [ 0.702939] Intel pstate controlling: cpu 2 [ 0.702950] Intel pstate controlling: cpu 3 [ 0.703020] cpuidle: using governor menu [ 0.703193] hidraw: raw HID events driver (C) Jiri Kosina [ 0.703244] usbcore: registered new interface driver usbhid [ 0.703244] usbhid: USB HID core driver [ 0.703277] drop_monitor: Initializing network drop monitor service [ 0.703336] TCP: cubic registered [ 0.703338] Initializing XFRM netlink socket [ 0.703398] NET: Registered protocol family 10 [ 0.703513] NET: Registered protocol family 17 [ 0.703702] Loading compiled-in X.509 certificates [ 0.704303] Loaded X.509 cert 'Magrathea: Glacier signing key: dc81fd4e343172520400f6632336d3afaed9bb1f' [ 0.704311] registered taskstats version 1 [ 0.705726] Key type trusted registered [ 0.707020] Key type encrypted registered [ 0.708323] IMA: No TPM chip found, activating TPM-bypass! [ 0.708714] rtc_cmos 00:06: setting system clock to 2014-12-24 07:50:35 UTC (1419407435) [ 0.709208] Freeing unused kernel memory: 1584k freed [ 0.711661] systemd[1]: systemd 208 running in system mode. (+PAM +LIBWRAP +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ) [ 0.711800] systemd[1]: Running in initial RAM disk. [ 0.711847] systemd[1]: Set hostname to <localhost.localdomain>. [ 0.730165] systemd[1]: Expecting device dev-mapper-centos\x2droot.device... [ 0.730177] systemd[1]: Starting -.slice. [ 0.730291] systemd[1]: Created slice -.slice. [ 0.730328] systemd[1]: Starting System Slice. [ 0.730384] systemd[1]: Created slice System Slice. [ 0.730411] systemd[1]: Starting Slices. [ 0.730418] systemd[1]: Reached target Slices. [ 0.730437] systemd[1]: Starting Timers. [ 0.730445] systemd[1]: Reached target Timers. [ 0.730465] systemd[1]: Starting Journal Socket. [ 0.730508] systemd[1]: Listening on Journal Socket. [ 0.730626] systemd[1]: Starting dracut cmdline hook... [ 0.730968] systemd[1]: Started Load Kernel Modules. [ 0.730982] systemd[1]: Starting Setup Virtual Console... [ 0.731288] systemd[1]: Starting Journal Service... [ 0.731693] systemd[1]: Started Journal Service. [ 0.736648] systemd-journald[105]: Vacuuming done, freed 0 bytes [ 0.858281] device-mapper: uevent: version 1.0.3 [ 0.858365] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com [ 0.887140] systemd-udevd[261]: starting version 208 [ 0.938559] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded [ 0.938572] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control [ 0.938856] r8169 0000:02:00.0: irq 41 for MSI/MSI-X [ 0.939058] r8169 0000:02:00.0 eth0: RTL8168evl/8111evl at 0xffffc90000630000, 74:d4:35:83:2a:b8, XID 0c900800 IRQ 41 [ 0.939060] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko] [ 0.951338] ACPI: bus type ATA registered [ 0.951437] libata version 3.00 loaded. [ 0.962346] ahci 0000:00:1f.2: version 3.0 [ 0.962502] ahci 0000:00:1f.2: irq 42 for MSI/MSI-X [ 0.962563] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x4 impl SATA mode [ 0.962566] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst [ 0.963545] scsi0 : ahci [ 0.963663] scsi1 : ahci [ 0.963991] scsi2 : ahci [ 0.964084] scsi3 : ahci [ 0.964154] scsi4 : ahci [ 0.964228] scsi5 : ahci [ 0.964337] ata1: DUMMY [ 0.964339] ata2: DUMMY [ 0.964341] ata3: SATA max UDMA/133 abar m2048@0xf7d1a000 port 0xf7d1a200 irq 42 [ 0.964343] ata4: DUMMY [ 0.964344] ata5: DUMMY [ 0.964345] ata6: DUMMY [ 0.993035] usb 1-1: new high-speed USB device number 2 using ehci-pci [ 0.993187] [drm] Initialized drm 1.1.0 20060810 [ 1.106745] [drm:drm_pci_agp_init] *ERROR* Cannot initialize the agpgart module. [ 1.106788] DRM: Fill_in_dev failed. [ 1.107300] usb 1-1: New USB device found, idVendor=8087, idProduct=8008 [ 1.107302] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 1.107437] hub 1-1:1.0: USB hub found [ 1.107544] hub 1-1:1.0: 6 ports detected [ 1.110117] systemd-udevd[266]: renamed network interface eth0 to enp2s0 [ 1.209956] usb 2-1: new high-speed USB device number 2 using ehci-pci [ 1.268924] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 1.269662] ata3.00: ATA-9: WDC WD10JPVX-22JC3T0, 01.01A01, max UDMA/133 [ 1.269664] ata3.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA [ 1.270385] ata3.00: configured for UDMA/133 [ 1.270541] scsi 2:0:0:0: Direct-Access ATA WDC WD10JPVX-22J 01.0 PQ: 0 ANSI: 5 [ 1.282352] sd 2:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB) [ 1.282355] sd 2:0:0:0: [sda] 4096-byte physical blocks [ 1.282412] sd 2:0:0:0: [sda] Write Protect is off [ 1.282414] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 1.282435] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.324241] usb 2-1: New USB device found, idVendor=8087, idProduct=8000 [ 1.324244] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 1.324385] hub 2-1:1.0: USB hub found [ 1.324475] hub 2-1:1.0: 8 ports detected [ 1.387269] sda: sda1 sda2 < sda5 > sda3 sda4 [ 1.387649] sd 2:0:0:0: [sda] Attached SCSI disk [ 1.478857] usb 3-9: new low-speed USB device number 2 using xhci_hcd [ 1.493693] usb 3-9: New USB device found, idVendor=15d9, idProduct=0a4c [ 1.493696] usb 3-9: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.493698] usb 3-9: Product: USB OPTICAL MOUSE [ 1.493817] usb 3-9: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes [ 1.496541] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0/input/input2 [ 1.496639] hid-generic 0003:15D9:0A4C.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:14.0-9/input0 [ 1.633769] tsc: Refined TSC clocksource calibration: 2993.069 MHz [ 1.633772] Switching to clocksource tsc [ 1.648794] usb 3-10: new low-speed USB device number 3 using xhci_hcd [ 1.669834] usb 3-10: New USB device found, idVendor=1c4f, idProduct=0002 [ 1.669837] usb 3-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 1.669838] usb 3-10: Product: USB Keykoard [ 1.669839] usb 3-10: Manufacturer: USB [ 1.669925] usb 3-10: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes [ 1.669928] usb 3-10: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes [ 1.672397] input: USB USB Keykoard as /devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10:1.0/input/input3 [ 1.672473] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [USB USB Keykoard] on usb-0000:00:14.0-10/input0 [ 1.675088] input: USB USB Keykoard as /devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10:1.1/input/input4 [ 1.675156] hid-generic 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [USB USB Keykoard] on usb-0000:00:14.0-10/input1 [ 2.029805] bio: create slab <bio-1> at 1 [ 2.473734] SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled [ 2.474714] XFS (dm-1): Mounting Filesystem [ 2.581541] XFS (dm-1): Ending clean mount [ 2.895247] systemd-journald[105]: Received SIGTERM [ 3.439966] type=1404 audit(1419407438.231:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 [ 3.607993] SELinux: 2048 avtab hash slots, 106409 rules. [ 3.619502] SELinux: 2048 avtab hash slots, 106409 rules. [ 3.646236] SELinux: 8 users, 86 roles, 4801 types, 280 bools, 1 sens, 1024 cats [ 3.646240] SELinux: 83 classes, 106409 rules [ 3.649770] SELinux: Completing initialization. [ 3.649772] SELinux: Setting up existing superblocks. [ 3.649780] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts [ 3.649783] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts [ 3.649791] SELinux: initialized (dev bdev, type bdev), uses genfs_contexts [ 3.649795] SELinux: initialized (dev proc, type proc), uses genfs_contexts [ 3.649819] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs [ 3.649834] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs [ 3.650468] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs [ 3.650472] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts [ 3.651348] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs [ 3.651355] SELinux: initialized (dev anon_inodefs, type anon_inodefs), uses genfs_contexts [ 3.651357] SELinux: initialized (dev aio, type aio), not configured for labeling [ 3.651359] SELinux: initialized (dev devpts, type devpts), uses transition SIDs [ 3.651375] SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses transition SIDs [ 3.651381] SELinux: initialized (dev mqueue, type mqueue), uses transition SIDs [ 3.651387] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts [ 3.651397] SELinux: initialized (dev securityfs, type securityfs), uses genfs_contexts [ 3.651401] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts [ 3.651717] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs [ 3.651724] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs [ 3.651802] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs [ 3.651828] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts [ 3.651835] SELinux: initialized (dev pstore, type pstore), uses genfs_contexts [ 3.651837] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts [ 3.651841] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts [ 3.651845] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts [ 3.651851] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts [ 3.651855] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts [ 3.651857] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts [ 3.651859] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts [ 3.651866] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts [ 3.651868] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts [ 3.651872] SELinux: initialized (dev configfs, type configfs), uses genfs_contexts [ 3.651877] SELinux: initialized (dev dm-1, type xfs), uses xattr [ 3.661320] type=1403 audit(1419407438.452:3): policy loaded auid=4294967295 ses=4294967295 [ 3.666457] systemd[1]: Successfully loaded SELinux policy in 261.128ms. [ 3.887598] systemd[1]: Relabelled /dev and /run in 20.934ms. [ 6.209185] SELinux: initialized (dev autofs, type autofs), uses genfs_contexts [ 6.784758] SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses transition SIDs [ 6.943318] systemd-journald[523]: Vacuuming done, freed 0 bytes [ 7.573786] systemd-udevd[557]: starting version 208 [ 8.611620] RPC: Registered named UNIX socket transport module. [ 8.611624] RPC: Registered udp transport module. [ 8.611624] RPC: Registered tcp transport module. [ 8.611625] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 8.612698] SELinux: initialized (dev rpc_pipefs, type rpc_pipefs), uses genfs_contexts [ 9.133345] parport_pc 00:0a: reported by Plug and Play ACPI [ 9.133400] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE] [ 9.230873] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182f conflicts with OpRegion 0x0000000000001800-0x000000000000187f (\PMIO) (20130517/utaddress-254) [ 9.230882] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 9.230886] ACPI Warning: SystemIO range 0x0000000000001c30-0x0000000000001c3f conflicts with OpRegion 0x0000000000001c00-0x0000000000001c3f (\GPRL) (20130517/utaddress-254) [ 9.230889] ACPI Warning: SystemIO range 0x0000000000001c30-0x0000000000001c3f conflicts with OpRegion 0x0000000000001c00-0x0000000000001fff (\GPR_) (20130517/utaddress-254) [ 9.230893] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 9.230894] ACPI Warning: SystemIO range 0x0000000000001c00-0x0000000000001c2f conflicts with OpRegion 0x0000000000001c00-0x0000000000001c3f (\GPRL) (20130517/utaddress-254) [ 9.230897] ACPI Warning: SystemIO range 0x0000000000001c00-0x0000000000001c2f conflicts with OpRegion 0x0000000000001c00-0x0000000000001fff (\GPR_) (20130517/utaddress-254) [ 9.230901] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 9.230902] lpc_ich: Resource conflict(s) found affecting gpio_ich [ 9.289089] mei_me 0000:00:16.0: irq 43 for MSI/MSI-X [ 9.340177] input: PC Speaker as /devices/platform/pcspkr/input/input5 [ 9.396783] i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003) [ 9.396873] ACPI Warning: SystemIO range 0x000000000000f040-0x000000000000f05f conflicts with OpRegion 0x000000000000f040-0x000000000000f04f (\_SB_.PCI0.SBUS.SMBI) (20130517/utaddress-254) [ 9.396878] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 9.615327] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 9.615678] SELinux: initialized (dev nfsd, type nfsd), uses genfs_contexts [ 9.656014] ppdev: user-space parallel port driver [ 9.667397] iTCO_vendor_support: vendor-support=0 [ 9.671766] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.10 [ 9.671791] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS [ 9.852582] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 [ 11.094195] alg: No test for __gcm-aes-aesni (__driver-gcm-aes-aesni) [ 11.102529] alg: No test for crc32 (crc32-pclmul) [ 11.105582] Adding 3555324k swap on /dev/mapper/centos-swap. Priority:-1 extents:1 across:3555324k FS [ 11.522448] ------------[ cut here ]------------ [ 11.522472] WARNING: at drivers/gpu/drm/i915/intel_pm.c:5348 i915_request_power_well+0x97/0xa0 [i915]() [ 11.522473] Modules linked in: snd_hda_intel(+) snd_hda_codec snd_hwdep snd_seq snd_seq_device crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel lrw snd_pcm gf128mul glue_helper ablk_helper snd_page_alloc snd_timer cryptd snd soundcore shpchp iTCO_wdt iTCO_vendor_support ppdev nfsd i2c_i801 pcspkr mei_me mei serio_raw lpc_ich mfd_core mperf parport_pc parport auth_rpcgss nfs_acl lockd sunrpc uinput xfs libcrc32c sd_mod crc_t10dif crct10dif_common i915 i2c_algo_bit drm_kms_helper drm ahci libahci libata r8169 mii i2c_core video dm_mirror dm_region_hash dm_log dm_mod [ 11.522493] CPU: 0 PID: 43 Comm: kworker/0:1 Not tainted 3.10.0MSSr2 #1 [ 11.522494] Hardware name: Gigabyte Technology Co., Ltd. Z87M-D3H/Z87M-D3H, BIOS F11 08/12/2014 [ 11.522498] Workqueue: events azx_probe_work [snd_hda_intel] [ 11.522500] 0000000000000000 000000005ac69646 ffff880119207d50 ffffffff815e27bb [ 11.522502] ffff880119207d88 ffffffff8105dee1 ffff880111a45228 ffff8801191e4380 [ 11.522503] 0000000000000000 ffff880111a45000 0000000000000000 ffff880119207d98 [ 11.522505] Call Trace: [ 11.522512] [<ffffffff815e27bb>] dump_stack+0x19/0x1b [ 11.522517] [<ffffffff8105dee1>] warn_slowpath_common+0x61/0x80 [ 11.522520] [<ffffffff8105e00a>] warn_slowpath_null+0x1a/0x20 [ 11.522530] [<ffffffffa01647e7>] i915_request_power_well+0x97/0xa0 [i915] [ 11.522534] [<ffffffffa048f952>] hda_display_power+0x32/0x40 [snd_hda_intel] [ 11.522536] [<ffffffffa048ee59>] azx_probe_continue+0x49/0x8a0 [snd_hda_intel] [ 11.522539] [<ffffffffa048f6c5>] azx_probe_work+0x15/0x20 [snd_hda_intel] [ 11.522543] [<ffffffff8107e03b>] process_one_work+0x17b/0x460 [ 11.522545] [<ffffffff8107ee0b>] worker_thread+0x11b/0x400 [ 11.522547] [<ffffffff8107ecf0>] ? rescuer_thread+0x400/0x400 [ 11.522549] [<ffffffff81085aff>] kthread+0xcf/0xe0 [ 11.522551] [<ffffffff81085a30>] ? kthread_create_on_node+0x140/0x140 [ 11.522554] [<ffffffff815f2dec>] ret_from_fork+0x7c/0xb0 [ 11.522556] [<ffffffff81085a30>] ? kthread_create_on_node+0x140/0x140 [ 11.522557] ---[ end trace 6aa0da9469b17c69 ]--- [ 11.522591] snd_hda_intel 0000:00:03.0: irq 44 for MSI/MSI-X [ 11.522711] snd_hda_intel 0000:00:1b.0: irq 45 for MSI/MSI-X [ 11.541153] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input6 [ 11.541319] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input7 [ 11.541398] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input8 [ 11.561997] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input9 [ 11.562422] input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card1/input10 [ 11.562999] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card1/input11 [ 11.563732] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card1/input12 [ 11.564504] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card1/input13 [ 11.564573] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card1/input14 [ 11.565151] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input15 [ 11.565266] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input16 [ 12.511097] Adding 7811068k swap on /dev/sda5. Priority:-2 extents:1 across:7811068k FS [ 13.194832] XFS (sda3): Mounting Filesystem [ 13.812067] XFS (sda3): Ending clean mount [ 13.812079] SELinux: initialized (dev sda3, type xfs), uses xattr [ 14.245555] XFS (dm-2): Mounting Filesystem [ 15.633377] XFS (dm-2): Ending clean mount [ 15.633388] SELinux: initialized (dev dm-2, type xfs), uses xattr [ 15.642662] systemd-journald[523]: Received request to flush runtime journal from PID 1 [ 15.854959] type=1305 audit(1419407450.650:4): audit_pid=716 old=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:auditd_t:s0 res=1 [ 16.356227] sd 2:0:0:0: Attached scsi generic sg0 type 0 [ 20.531407] ip_tables: (C) 2000-2006 Netfilter Core Team [ 20.849988] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 21.168553] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 21.978150] Ebtables v2.0 registered [ 22.289695] Bridge firewalling registered [ 23.772927] r8169 0000:02:00.0 enp2s0: link down [ 23.772938] r8169 0000:02:00.0 enp2s0: link down [ 23.772984] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready [ 25.322004] r8169 0000:02:00.0 enp2s0: link up [ 25.322013] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready [ 33.657942] fuse init (API version 7.22) [ 33.664007] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts [ 33.679010] SELinux: initialized (dev fusectl, type fusectl), uses genfs_contexts [ 42.196317] Adjusting tsc more than 11% (6227876 vs 6221945)
Regards.
Hi Nina ,
I tried MSS 2015 R3 ,and it works fine.
Regards.
Hi Zhu,
Great to hear that!
Nina
