Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Sample Decode Crashing doing JPEG decoding with VPP on d3d11
The sample decoder is crashing when doing JPEG decoding & a VPP stage for the sample JPEG attached. Its crashing only for d3d11 and works fine in d3d9 & sw modes.
To regenerate the crash, just the run the sample decode with the following params (using the sample jpeg file attached)
jpeg -hw -d3d11 -w 960 -h 480 -i ./input/Live-0-210.jpg -o ./output/Live-0-210.yuv
The actual dimension of the jpeg is 1920x960 and the above command attempts to decode the jpeg & scale it to half the original dimensions.
Curiously enough, the crash is seen only if a vpp stage is involved. It works fine even in d3d11 if we don't introduce the vpp stage.
jpeg -hw -d3d11 -w 1920 -h 960 -i ./input/Live-0-210.jpg -o ./output/Live-0-210.yuv
works fine in all modes (d3d, d3d11 & sw)
Had tried it on "Intel® Media SDK 2018 R1 - Media Samples 8.3.26.352"
Are there any corrections required in the "sample decode" to get this working?
I have reproduced what you observed and reported, I will keep you updated with the progress.
Mark
Highlighted
The above fails on HD4600 with IMSDK 2018.R2 (Sept2018 release as well)
C:\Users\developer\Documents\Intel® Media SDK 2018 R2 - Media Samples 8.4.27.378\_bin\x64>sample_decode.exe jpeg -hw -d3d11  -w 960 -h 480 -i C:\akhil\Live-0-210.jpg
pretending that aspect ratio is 1:1
Decoding Sample Version 8.4.27.378
Input video     JPEG
Output format   NV12 (using vpp)
Input:
  Resolution    1920x960
  Crop X,Y,W,H  0,0,1920,960
Output:
  Resolution    960x480
Frame rate      30.00
Memory type             d3d11
MediaSDK impl           hw_d3d11
MediaSDK version        1.20
Decoding started
[ERROR], sts=MFX_ERR_DEVICE_FAILED(-17), CDecodingPipeline::RunDecoding, DecodeFrameAsync returned error status at src\pipeline_decode.cpp:1837
Frame number:    0, fps: 0.000, fread_fps: 0.000, fwrite_fps: 0.000
[ERROR], sts=MFX_ERR_DEVICE_FAILED(-17), CDecodingPipeline::RunDecoding, Unexpected error!! at src\pipeline_decode.cpp:1947
ERROR: Hardware device was lost or returned unexpected error. Recovering...
[ERROR], sts=MFX_ERR_DEVICE_FAILED(-17), CD3D11Device::Reset, Cannot create swap chain required for rendering. at src\d3d11_device.cpp:226
[ERROR], sts=MFX_ERR_DEVICE_FAILED(-17), wmain, Pipeline.ResetDevice failed at src\sample_decode.cpp:716
Highlighted
Hi Mark,
Any updates on this issue?
Thanks And Regards,
Sree
Highlighted
Yes, some updates.
It seems like this is the sample issue. By turning on rendering, this issue was disappeared.
It is still under investigation.
Mark.
