Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
2945 Discussions
Sample Decode Crashing doing JPEG decoding with VPP on d3d11
Prakash__Sree
The sample decoder is crashing when doing JPEG decoding & a VPP stage for the sample JPEG attached. Its crashing only for d3d11 and works fine in d3d9 & sw modes.
To regenerate the crash, just the run the sample decode with the following params (using the sample jpeg file attached)
jpeg -hw -d3d11 -w 960 -h 480 -i ./input/Live-0-210.jpg -o ./output/Live-0-210.yuv
The actual dimension of the jpeg is 1920x960 and the above command attempts to decode the jpeg & scale it to half the original dimensions.
Curiously enough, the crash is seen only if a vpp stage is involved. It works fine even in d3d11 if we don't introduce the vpp stage.
jpeg -hw -d3d11 -w 1920 -h 960 -i ./input/Live-0-210.jpg -o ./output/Live-0-210.yuv
works fine in all modes (d3d, d3d11 & sw)
Had tried it on "Intel® Media SDK 2018 R1 - Media Samples 8.3.26.352"
Are there any corrections required in the "sample decode" to get this working?
Mark_L_Intel1
I have reproduced what you observed and reported, I will keep you updated with the progress.
Mark
Kumar__Akhil1
The above fails on HD4600 with IMSDK 2018.R2 (Sept2018 release as well)
C:\Users\developer\Documents\Intel® Media SDK 2018 R2 - Media Samples 8.4.27.378\_bin\x64>sample_decode.exe jpeg -hw -d3d11  -w 960 -h 480 -i C:\akhil\Live-0-210.jpg
pretending that aspect ratio is 1:1
Decoding Sample Version 8.4.27.378
Input video     JPEG
Output format   NV12 (using vpp)
Input:
  Resolution    1920x960
  Crop X,Y,W,H  0,0,1920,960
Output:
  Resolution    960x480
Frame rate      30.00
Memory type             d3d11
MediaSDK impl           hw_d3d11
MediaSDK version        1.20
Decoding started
[ERROR], sts=MFX_ERR_DEVICE_FAILED(-17), CDecodingPipeline::RunDecoding, DecodeFrameAsync returned error status at src\pipeline_decode.cpp:1837
Frame number:    0, fps: 0.000, fread_fps: 0.000, fwrite_fps: 0.000
[ERROR], sts=MFX_ERR_DEVICE_FAILED(-17), CDecodingPipeline::RunDecoding, Unexpected error!! at src\pipeline_decode.cpp:1947
ERROR: Hardware device was lost or returned unexpected error. Recovering...
[ERROR], sts=MFX_ERR_DEVICE_FAILED(-17), CD3D11Device::Reset, Cannot create swap chain required for rendering. at src\d3d11_device.cpp:226
[ERROR], sts=MFX_ERR_DEVICE_FAILED(-17), wmain, Pipeline.ResetDevice failed at src\sample_decode.cpp:716
Prakash__Sree
Hi Mark,
Any updates on this issue?
Thanks And Regards,
Sree
Mark_L_Intel1
Hi Sree,
Apology for the long delay of this issue.
I have got confirmed from dev team that the solution was merged internally, it should be available in the open source Media SDK project with following pull request:
https://github.com/Intel-Media-SDK/MediaSDK/pull/2531
https://github.com/Intel-Media-SDK/MediaSDK/pull/2535
and https://github.com/intel-innersource/drivers.gpu.media.sdk.lib/pull/320
The Windows version will be updated at the middle of this year.
Please let me know if you have any questions.
Mark Liu
Mark_L_Intel1
Yes, some updates.
It seems like this is the sample issue. By turning on rendering, this issue was disappeared.
It is still under investigation.
Mark.
