Hi
I installed the intel media sdk R6 version on ubuntu, ubuntu is 14.04.3
uname -a
Linux suirui 3.19.0-25-generic # 26 ~ 14.04.1-Ubuntu SMP Fri Jul 24 21:16:20 UTC 2015 x86_64 x86_64 x86_64 GNU / Linux
I installed documentation generic way to install and compile the sample MediaSamples_Linux_6.0.16043175.175, produced sample_encode_x11 bin file, and then I use the command ./sample_encode_x11 h264 -i test_stream_176x96.yuv -o 3.264 -w 176 -h 96 -vaapi
First run properly, resulting in a h264 file
libva info: VA-API version 0.35.0
libva info: va_getDriverName () returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver () returns 0
Encoding Sample Version 0.0.000.0000
Input file format YUV420
Output video AVC
Source picture:
Resolution 176x96
Crop X, Y, W, H 0,0,176,96
Destination picture:
Resolution 176x96
Frame rate 30.00
Bit rate (Kbps) 112
Target usage balanced
Memory type d3d
Media SDK impl hw
Media SDK version 1.16
Processing started
Frame number: 101
Processing finished
The same command being given a second time
Output video AVC
Source picture:
Resolution 176x96
Resolution 176x96
Frame rate 30.00
Bit rate (Kbps) 112
Memory type d3d
Media SDK impl hw
Processing started
Return on error: error code -7, /home/suirui/MediaSamples_Linux_6.0.16043175.175/samples/sample_encode/src/pipeline_encode.cpp 1212
Return on error: error code -7, /home/suirui/MediaSamples_Linux_6.0.16043175.175/samples/sample_encode/src/pipeline_encode.cpp 1367
Return on error: error code 1, /home/suirui/MediaSamples_Linux_6.0.16043175.175/samples/sample_encode/src/sample_encode.cpp 678
The third re-run the command normal again, I checked the error, is MFX_ERR_LOCK_MEMORY, is what causes?
I suspect that is not caused by the kernel version, The documentation requirement is 3.14.5, but my version is 3.19.0-25
Hi There,
First, I want to get more details about the issue, Can you send the following command line to me when the error happened ?
(only add strace to head of your command line)
$ strace ./sample_encode_x11 h264 -i test_stream_176x96.yuv -o 3.264 -w 176 -h 96 -vaapi
Second, please send outputs of following command lines for better understand your environment.
$ vainfo
$ ls -l /dev/dri
$ lspci -nn | grep VGA
Third, Currently MSS R6 generic package support kernel 3.14.5, Maybe you should update your kernel following "KMD (kernel mode driver) install steps" in media_server_studio_getting_started_guide.pdf
Zachary
Thank you very much
As you say the way
first strace ./sample_encode_x11 h264 -i test_stream_176x96.yuv -o 3.264 -w 176 -h 96 -vaapi
I get the result
libva info: va_getDriverName() returns 0
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.35 (libva 1.3.1)
vainfo: Driver version: 16.4.2.1.39163-ubit
vainfo: Supported profile and entrypoints
VAProfileNone : VAEntrypointVideoProc
VAProfileNone : <unknown entrypoint>
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileH264Baseline : VAEntrypointEncSlice
VAProfileH264Baseline : <unknown entrypoint>
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264Main : <unknown entrypoint>
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264High : <unknown entrypoint>
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: <unknown entrypoint>
VAProfileVP8Version0_3 : VAEntrypointEncSlice
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileVP8Version0_3 : <unknown entrypoint>
crw-rw----+ 1 root video 226, 0 9月 9 15:27 card0
crw-rw---- 1 root video 226, 64 9月 9 15:27 controlD64
crw-rw---- 1 root video 226, 128 9月 9 15:27 renderD128
Since NUC5i5RYK I use, it's graphics are HD 6000, kervel version 3.14.5 does not support, so is the use ubuntu 14.04.3, it kernerl version is 3.19.0-25
I was using another four generations of NUC, try 3.14.5.
Hi ,
Can you test with ./sample_encode_drm instead of ./sample_encode_x11 ? Let's see if the same issue happened.
About " it's graphics are HD 6000, kervel version 3.14.5 does not support", How do you verify this ?
Do you meet some issues when using build and setup kernel 3.14.5 on NUC5i5RYK ?
Zachary
Hello there - As Zachary pointed out, please let us know if you are seeing the same error with the drm executable instead of x11. I have faced similar errors in my own experiments, and for me, the cause was faulty driver module installation. In your case, it can possibly be launching two X11 sessions - please let us know your results. I'm interested in this topic as well.
