Set Encoding Frame Order
Mohammad_T_1
I am using Intel Media SDK 388 version 1.16. I do Encode raw data in h264 and it's working fine. Encoding parameters are:
m_mfxEncParams.mfx.EncodedOrder = 0;
m_mfxEncParams.mfx.IdrInterval = 0;
m_mfxEncParams.mfx.GopPicSize = 24;
m_mfxEncParams.mfx.GopRefDist = 3;
 m_mfxEncParams.mfx.CodecProfile = MFX_PROFILE_AVC_MAIN;
The encoded h264 file is working fine. Output frames are in orders: IPBBPBBPBB... and so on.
But for one requirement i want to change the Frame orders as IBBPBBPBBP... and so on.
I tried to change Encode order by changing m_mfxEncParams.mfx.EncodedOrder = 1; but not succeeded.
So please guide me, how can in set Encoding Frame order.
Thank you
Anna_B_Intel
Hi Mohammad,
First of all you should update your Media SDK up to Media SDK 2016 R2.
To have gop-structure "IBBPBBPBBP" you should set m_mfxEncParams.mfx.EncodedOrder = 1; and specify type of frames by FrameType enumerator (see details in mediasdk-man.pdf).
Best wishes,
Anna
Anna_B_Intel
Hi Mohammad,
Best wishes,
Anna
