I installed oneVPL base toolkit on Windows 10. Using the steps here, I don't see oneVPL demos as part of running oneapi-cli.exe. Should there be oneVPL demos? Under oneAPI Libraries (or other branches), I don't see oneVPL. Screenshot from oneapi-cli exe below:
- Tags:
- oneVPL sample
Thank you for posting in Intel communities. We too have observed that, in Windows, the oneVPL samples are not available in oneapi-cli. We will work on this issue internally and get back to you soon with an update.
Meanwhile, we can provide two workarounds so that you can continue working on oneVPL demo samples:
- In Windows, oneVPL samples are available in this path: "C:\Program Files (x86)\Intel\oneAPI\vpl\2021.4.0\examples". You could go through the readme.md files for every sample for your understanding.
- As you're an Intel DevCloud user, you could also try oneVPL in DevCloud. DevCloud has oneVPL samples in oneapi-cli
Hope this helps!
Alekhya
Has the solution provided helped? Please give us an update regarding this issue.
Alekhya
