Skylake installation problem
ANdrey_R_1
I have big problem with installation mine cent os !
I try all version of SDK (2017R[1,2,3], 2018R1) and following versions of cent os (1511,1511,1611,1708) in every installation same result:
After reboot i have black screen and nothing
In debug mode i see what os was freeze after trying run the updated drivers. (help only nomodeset or i915.modeset=0)
----- Last mine experience:
2017R3
I install all except kmod-ukmd-16.5.2-64009.el7.centos.x86_64.rpm (it i just unpack in following directories). All tests answer what libraries was works (sys_analyzer.py), but samples not work and aswer with error.
Please help.
ANdrey_R_1
I found the problem !
Skylake and MSI motherboards incompatible. (not difference with chipset [i try B250,z270,z170)
ANdrey_R_1
Also not works Asus z270-p
ANdrey_R_1
Thats strange i was trying install cent os but after installing drivers i got freeze on boot
fb: switching to inteldrmfb from EFI VGA
Then freeze ! Please help with solution.
Mark_L_Intel1
Thanks ANdrey,
Your update for MSI board is appreciated,  I remembered we had this issue before, so it should be a known issue. But more confirmation is better, thanks.
About freeze on boot, I am not sure what your installation sequence is, are you installed a driver on an old OS version and updated it to a new OS version? For driver, do you mean KMD, this implied you are updating a new kernel?
Mark
ANdrey_R_1
Liu, Mark (Intel) wrote:
Thanks ANdrey,
Mark
Dear, i do all.
I install KMD, i compile it . and not success. But i just change the motherboard and it works. (on same os)
So now works:
z170 Asus, H110 Asus
z170 Intel
All other desktop motherboards had an issues ... (We try MSI, Gigabyte, ASRock)
Mark_L_Intel1
Thanks so much for the hardware work,
This should have everyone! I am appreciated your work.
I am wondering what the cause, the incompatible hardware causes KMD error?
You might also try our open source build since it support more advanced kernel:
https://software.intel.com/en-us/articles/build-and-debug-open-source-media-stack
Also MSS2018R1 might help, it uses a little bit different kernel 4.4.111
Mark Liu
