Software decoding in RGB4
Stefano_M_
I'm decoding a h264 video stream into rgb4 (BGRA32) using media sdk 2016.
When I use the software acceleration the alpha channel is always set to 0, instead using hardware acceleration the alpha channel is set to 255.
Jeffrey_M_Intel1
What OS and hardware are you using?  If Windows, what driver # is installed?  I've replicated in Windows on BDW but want to be sure this is what you're looking at.
