Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
Some rate controll issues
Oh_i_
I'm tring to strictly control the encoder output bit rate and I cant find any option to do the following:
1. re-encode frame (p-frame) for better shorter/larger bitstream. if i just call the encoder the second time than he thinks it is the next frame and the diffs are wrong, stream-wise.... any idea?
2. I found a way to force I-frame in the stream, but I couldnt find any way to force p-frame, any idea?
Petter_L_Intel
Hi Oh,
" 1. re-encode frame (p-frame) for better shorter/larger bitstream. if i just call the encoder the second time than he thinks it is the next frame and the diffs are wrong, stream-wise.... any idea?"
     Media SDK does not support re-encoding of frames.
" 2. I found a way to force I-frame in the stream, but I couldnt find any way to force p-frame, any idea?"
     In the default "display order" mode, only I-frames are enforceable.  If you need the ability to set P frames on demand you must use "encoded order" mode, in which you must specific the type for each frame.
Petter
Oh_i_
Thanks for the quick replay.
I implement that "encoder order", but after the 3rd p-frame I got an error while syncing (SyncOperation) "devision by zero"....
Settings for I-Frame:
encCtrl.FrameType = MFX_FRAMETYPE_I|MFX_FRAMETYPE_REF;
Settings for P-Frame:
pData.FrameOrder = MFX_FRAME_ORDER_UNKNOWN;
encCtrl.FrameType = MFX_FRAMETYPE_P;
Petter_L_Intel
Hi Oh,
I quickly tested similar scenario setting first frame to I frame and the rest to P frames as you describe but I see no issues.
Can you please share more details about your encoder and system configuration(eg. gfx driver version Media SDK version, HW platform)?
Petter
