Hardware: Atom X6425E processors,
OS: Ubuntu 20.04, kernel: 5.15.0-52-generic.
After installing Intel Media SDK 22.5.4, the 'sample_encode' program does not run properly. The error return value is as follows:
Does the x6425E processor not support the Linux version of the Intel Media SDK?
Could you please confirm the Media SDK version? In the screenshot shared, it is showing 21.2.3
Remya Premdas
Also, I looked at the source code of libmfx and found out the problem.
As shown below, for 'H264' encoder, the encoder parameters 'mfx.RateControlMethod', currently only 'CQP' is supported, the others are not. So the default parameter is used to return an error.
Sorry for the inconvenience. We are working on this internally. We will get back to you with an update.
Remya Premdas
I look forward to receiving your reply.
We were able to run sample_encode on oneVPL HW implementation . Could you please switch to oneVPL and try running the sample?
root@9049fa065fa6:~/samples_test/oneVPL/examples/hello/hello-encode# sample_encode h265 -hw -i ../../content/cars_320x240.nv12 -w 320 -h 240 -cqp -qpi 10 -qpb 30 -qpp 30 -g 30 -o output.h265
CONFIGURE LOADER: required implementation: hw
CONFIGURE LOADER: required implementation mfxAccelerationMode: MFX_ACCEL_MODE_VIA_VAAPI
libva info: VA-API version 1.15.0
libva info: User environment variable requested driver 'iHD'
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_15
libva info: va_openDriver() returns 0
Loaded Library configuration:
Version: 2.7
ImplName: mfx-gen
Adapter number : 0
Adapter type: integrated
DRMRenderNodeNum: 128
Used implementation number: 0
Loaded modules:
0: /root/samples_test/oneVPL/lib/libvplswref64.so.1
1: /usr/lib/x86_64-linux-gnu/libmfx-gen.so.1.2.7
2: /usr/lib/x86_64-linux-gnu/libmfxhw64.so.1.35libva info: VA-API version 1.15.0
Encoding Sample Version 8.4.27.0Input file format YUV420
Output video HEVC
Source picture:
Resolution 320x240
Crop X,Y,W,H 0,0,320,240
Destination picture:
Resolution 320x240
Frame rate 30.00
QPI 10
QPP 30
QPB 30
Gop size 30
Ref dist 0
Ref number 0
Idr Interval 0
Target usage balanced
Memory type system
Media SDK impl hw
Media SDK version 2.7Processing started
Frame number: 30
Encoding fps: 1233Processing finished
Remya Premdas
We haven't received any update from your end. Were you able to run the sample code?
Remya Premdas
Thank you for your reply.
I did not switch to oneVPL and try to run the sample.
I switched my ubuntu system to intel-iot Ubuntu 20.04.5 and retried the Media SDK and now I can run the sample program properly.
I think this may have something to do with the kernel of the Ubuntu distribution, and I will now continue to develop with the Media SDK on intel-iot Ubuntu 20.04.5.
Thanks again
Glad to know that your issue is resolved. Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be be monitored by Intel.
Remya Premdas
