Support for Braswell in Linux SDK (4.4 Kernel)
remi_o_
I have installed the MediaServerStudioEssentials2017R2 SDK and
build the linux-4.4 kernel with the supplied patched
However i can't get the mediasamples working !
I think the Braswell chipset (N3700 CPU) is not supported....
I own this board more than a year now, and really would like to use hardware QSV
(since this was the main reason for buying this mainboard and CPU)
U use the below settings in my profile:
export LD_LIBRARY_PATH=/usr/lib64:/usr/local/lib
export MFX_HOME=/opt/intel/mediasdk
export LIBVA_DRIVER_NAME=iHD
export LIBVA_DRIVERS_PATH=/opt/intel/mediasdk/lib64
#pkg-config --cflags --libs libmfx
-I/opt/intel/mediasdk/include -I/usr/include/libdrm
-L/opt/intel/mediasdk/lib/lin_x64 -lmfx -lva -lstdc++ -ldl -lva-drm -ldrm
#vainfo gives the below output:
error: can't connect to X server!
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.99 (libva 1.67.0.pre1)
vainfo: Driver version: 16.5.1.59511-ubit
vainfo: Supported profile and entrypoints
      VAProfileH264ConstrainedBaseline: VAEntrypointVLD
      VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline: <unknown entrypoint>
      VAProfileH264Main               : VAEntrypointVLD
      VAProfileH264Main               : VAEntrypointEncSlice
      VAProfileH264Main               : <unknown entrypoint>
      VAProfileH264High               : VAEntrypointVLD
      VAProfileH264High               : VAEntrypointEncSlice
      VAProfileH264High               : <unknown entrypoint>
      VAProfileMPEG2Simple            : VAEntrypointEncSlice
      VAProfileMPEG2Simple            : VAEntrypointVLD
      VAProfileMPEG2Main              : VAEntrypointEncSlice
      VAProfileMPEG2Main              : VAEntrypointVLD
      VAProfileVC1Advanced            : VAEntrypointVLD
      VAProfileVC1Main                : VAEntrypointVLD
      VAProfileVC1Simple              : VAEntrypointVLD
      VAProfileJPEGBaseline           : VAEntrypointVLD
      VAProfileJPEGBaseline           : VAEntrypointEncPicture
      VAProfileVP8Version0_3          : VAEntrypointEncSlice
      VAProfileVP8Version0_3          : VAEntrypointVLD
      VAProfileVP8Version0_3          : <unknown entrypoint>
      VAProfileVP9Profile0            : <unknown entrypoint>
      <unknown profile>               : VAEntrypointVideoProc
      VAProfileNone                   : VAEntrypointVideoProc
      VAProfileNone                   : <unknown entrypoint>
Segmentation fault (core dumped)
When i try to run sample_multi_transcode from the MediaSamples ..
./sample_multi_transcode -i::h264 ~/test.mkv -o::h264 content/test_out.h264
I get the following line in my syslog:
UbuntuServer kernel: [78881.928689] traps: sample_multi_tr[32656] trap invalid opcode ip:7fca2ff8d767 sp:7fffe254c5e0 error:0 in libmfxhw64-p.so.1.21[7fca2fd85000+aad000]
PLEASE HELP !!
