Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
SynchronizeFirstTask Return sts=MFX_ERR_DEVICE_FAILED, when enable lowpower . GUC and HUC is opened
fujianfang
OS: ubuntu 20.04
kernel:  Intel Linux kernel 5.10.0-1023-oem
MediaSDK 2022q2
CPU Model: 1165G7 Tiger-lake
We use the YUV data needed by the encoder is filled in by myself. mem type is SYSTEM_MEMORY.  -17  error occurs frequently in the coding process.
MFXVideoSession::virtual mfxStatus SyncOperation(mfxSyncPoint syncp, mfxU32 wait) return -17, and couldn't return to normal, unless destroy and recreate.
If only 265 or 264 is encoded,  the problem does not reappear temporarily.
If both h.265 and h.264 (with lowpower:on ) is encoded, the problem is appear in a few minutes.
Because we would use at least 8 stream encoding we must open lowpower parameters to make sure all encoding process is quick enough.
We have turned on GUC and HUC.
[10.12.32.197]# cat /sys/kernel/debug/dri/0/gt/uc/guc_info
GuC firmware: i915/tgl_guc_35.2.0.bin
status: RUNNING
version: wanted 35.2, found 35.2
uCode: 417344 bytes
RSA: 256 bytes
GuC status 0x8002f077:
Bootrom status = 0x3b
uKernel status = 0xf0
MIA Core status = 0x2
Scratch registers:
0: 0x0
1: 0x0
2: 0x7effd3
3: 0x0
4: 0x4000
5: 0x40
6: 0x1004
7: 0x0
8: 0x0
9: 0x0
10: 0x0
11: 0x0
12: 0x0
13: 0x0
14: 0x0
15: 0x0
GuC log relay not created
[TM1400 B640B6E7 ~ ]
[10.12.32.197]# cat /sys/kernel/debug/dri/0/gt/uc/huc_info
HuC firmware: i915/tgl_huc_7.5.0.bin
status: RUNNING
version: wanted 7.5, found 7.5
uCode: 580352 bytes
RSA: 256 bytes
HuC status: 0x00090001
/opt/intel/mediasdk/share/mfx/samples/_bin/sample_encode h265 -gpucopy::on -i /tmp/yuv/cnn.yuv -o test.h265 -nv12 -w 1920 -h 1080 -dstw 1920 -dsth 1080 -b 10000 -fps 60 -f 60 -hw -async 2 -lowpower:on -u speed -timeout 600 &
/opt/intel/mediasdk/share/mfx/samples/_bin/sample_encode h264 -gpucopy::on -i /tmp/yuv/cnn.yuv -o test.h265 -nv12 -w 1920 -h 1080 -dstw 1920 -dsth 1080 -b 15000 -fps 60 -f 60 -hw -async 2 -lowpower:on -u speed -timeout 600 &
JaideepK_Intel
We were able to reproduce your issue from our end, and we are working on this internally. We will get back to you with an update.
Jaideep
fujianfang
hi Jaideep,
Thanks for the reply, I found another clue, when I change kernel to 5.15.0-56-generic, it use i915/tgl_huc_7.9.3.bin and i915/tgl_guc_62.0.0.bin. there is no such error.
JaideepK_Intel
Glad to know your issue is resolved after changing kernel.
Could you please provide a memory dump and full machine specifications, if possible?
Jaideep
fujianfang
uname -a
Linux tpack 5.10.0-1023-oem #1 SMP Wed May 12 07:03:31 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
cat /proc/cpuinfo
model name : 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz
[10.12.32.197]# dmidecode -t baseboard
# dmidecode 3.2
Getting SMBIOS data from sysfs.
SMBIOS 3.3.0 present.
# SMBIOS implementations newer than version 3.2.0 are not
# fully supported by this version of dmidecode.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: Intel Corporation
Product Name: CM11EBI716W
Version: M15483-302
Serial Number: GEEB1220006G
Asset Tag:
Features:
Board is a hosting board
Board is replaceable
Location In Chassis:
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
dmidecode -t memory
# dmidecode 3.2
Handle 0x0012, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 16 GB
Error Information Handle: Not Provided
Number Of Devices: 8
Handle 0x001D, DMI type 17, 92 bytes
Memory Device
Array Handle: 0x0012
Total Width: 16 bits
Data Width: 16 bits
Form Factor: Row Of Chips
Set: None
Locator: Controller0-ChannelA
Bank Locator: BANK 0
Type: LPDDR4
Type Detail: Synchronous
Speed: 4267 MT/s
Manufacturer: Micron Technology
Serial Number: 00000000
Asset Tag: 9876543210
Part Number: 53E1G32D4NQ-046
Rank: 2
Configured Memory Speed: 4267 MT/s
Minimum Voltage: 0.6 V
Maximum Voltage: 0.6 V
Configured Voltage: 0.6 V
Memory Technology: DRAM
Memory Operating Mode Capability: Volatile memory
Firmware Version: Not Specified
Module Manufacturer ID: Bank 1, Hex 0x2C
Module Product ID: Unknown
Memory Subsystem Controller Manufacturer ID: Unknown
Memory Subsystem Controller Product ID: Unknown
Non-Volatile Size: None
Volatile Size: 2 GB
Cache Size: None
Logical Size: None
Handle 0x001E, DMI type 17, 92 bytes
Memory Device
Data Width: 16 bits
Set: None
Locator: Controller0-ChannelB
Bank Locator: BANK 1
Type: LPDDR4
Speed: 4267 MT/s
Rank: 2
Volatile Size: 2 GB
Cache Size: None
Logical Size: None
Handle 0x001F, DMI type 17, 92 bytes
Memory Device
Data Width: 16 bits
Set: None
Locator: Controller0-ChannelC
Bank Locator: BANK 2
Type: LPDDR4
Speed: 4267 MT/s
Rank: 2
Volatile Size: 2 GB
Cache Size: None
Logical Size: None
Handle 0x0020, DMI type 17, 92 bytes
Memory Device
Data Width: 16 bits
Set: None
Locator: Controller0-ChannelD
Bank Locator: BANK 3
Type: LPDDR4
Speed: 4267 MT/s
Rank: 2
Volatile Size: 2 GB
Cache Size: None
Logical Size: None
Handle 0x0021, DMI type 17, 92 bytes
Memory Device
Data Width: 16 bits
Set: None
Locator: Controller1-ChannelA
Type: LPDDR4
Speed: 4267 MT/s
Rank: 2
Volatile Size: 2 GB
Cache Size: None
Logical Size: None
Handle 0x0022, DMI type 17, 92 bytes
Memory Device
Data Width: 16 bits
Set: None
Locator: Controller1-ChannelB
Type: LPDDR4
Speed: 4267 MT/s
Rank: 2
Volatile Size: 2 GB
Cache Size: None
Logical Size: None
Handle 0x0023, DMI type 17, 92 bytes
Memory Device
Data Width: 16 bits
Set: None
Locator: Controller1-ChannelC
Type: LPDDR4
Speed: 4267 MT/s
Rank: 2
Volatile Size: 2 GB
Cache Size: None
Logical Size: None
Handle 0x0024, DMI type 17, 92 bytes
Memory Device
Data Width: 16 bits
Set: None
Locator: Controller1-ChannelD
Type: LPDDR4
Speed: 4267 MT/s
Rank: 2
Volatile Size: 2 GB
Cache Size: None
Logical Size: None
fujianfang
But we don't want to replace the kernel, can you help me to see why there is a problem with 5.10.0-1023-oem (i915/tgl_guc_35.2.0.bin i915/tgl_huc_7.5.0.bin)
JaideepK_Intel
Sorry to say this, but unfortunately, 5.15 is supported on the TGL platform.
Here is a list of Intel Graphics Support in Linux Kernels: https://github.com/Intel-Media-SDK/MediaSDK/wiki/Intel-Graphics-Support-in-Linux-Kernels.
If you want to try the 5.10 kernel, please choose the supported platform. attaching a screenshot for your reference.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
TGL platform is known to be fully supported by Linux kernel 5.15 or newer. Some Linux distributions may customize their kernels pulling in changes from the later kernels (forklifting). In such a case you may find that ITGL also works with some older kernel versions. This document can give some idea on which kernel is compatible with which Intel Hardware: https://github.com/Intel-Media-SDK/MediaSDK/wiki/Intel-Graphics-Support-in-Linux-Kernels
Jaideep
JaideepK_Intel
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
