Hi Philipp,
The drivers and HW you are using are 'embedded' version and I have contacted that team. The issue sounds similar to an issue that was recently seen (and fixed) on similar tablet platforms. For the best support of embedded driver, I would recommend using Intel Premier Support, but I will also try to connect the two teams.
The two drivers are different, however there is a good chance that both teams had the same bug, and new embedded driver has not been built yet.
There is also the possibility that issue is due to physical design (thermal, etc.).
If you could capture a log of MSDK API activity by using the 'tracer' tool, we might be able to identify if it is indeed a similar issue.
Hi Tony,
thanks for your fast response.
We tried to produce a log via the MSDK "tracer" tool. Unfortunately in case of this error the whole OS hangs, hence the tracer tool can't successfully write a log file to the disk (or at least did not do it on our system).
Are there any other ways we could help your driver / SDK teams in identifying the issue? E.g. running the system with an instrumented version of the embedded driver and sending back the kernel mode logs?
Philipp
