Hello Sir/Madam,
I am using Media SDK 2017 for Windows 8.0.24.271. I am using sample multitranscoder for transcoding the h264 stream. My hardware is Intel Core i7 -4770 CPU and Operating system is Windows 7.
My objective is work on raw Rgb4 frame. My input is input.h264(1920*1080). When I set -i::h264 input.h264 -o::raw output.raw -dc::rgb4 in transcoder sample. And exe throw m_pmfxDEC-> Init failed error.
If i don't set below parameter then Transcoding Sample exe is running fine.
-dc::rgb4
Please advice me.
Thanking you,
Dhrumil Sheth
- Tags:
- Development Tools
- Graphics
- Intel® Media SDK
- Intel® Media Server Studio
- Media Processing
- Optimization
Hi Dhrumil,
Sorry for the late response, I was interrupted by some urgent project and had dealing with the long backlogs.
About your questions, I can reproduce it and I think the sample_multi_transcode might need other arguments to works. But -dc::rgb4 is to force the decoder output and you want to use raw.
If you just want to generate raw output with RGB4 format, you can use sample_decode with following command line:
sample_decode.exe h264 -i input.h264 -o out.raw -rgb4
Does this work for you?
Mark
Hi Dhrumil,
Mark
