System: Microsoft Surface Pro 6 (128 GB)
I am using the Media SDK for decoding an H.264 stream, with VPP to convert the decoder's NV12 output to RGB. On the Surface Pro 6, decoding 1920x1080 content takes about ~2.5 - 3 ms. Converting NV12 to (RGB) takes ~8-9 ms, but can take upwards of 20 ms on some frames. It gets a couple milliseconds slower running on battery (despite selecting the Best Performance power profile). I tried two different Surface Pro 6 tablets and both have this performance.
On a Microsoft Surface Go (Intel UHD 615), it's a lot more reasonable. Decoding takes about ~4 ms while the color format conversion takes ~2 ms, with very little variance.
Task Manager has a Video Processing graph for the Surface Pro 6, but it always shows 0% usage. Not sure if this is intended to capture VPP workload or not though. The SDK never returns MFX_WRN_PARTIAL_ACCELERATION.
This sounds like a firmware issue from my perspective, but if there is any workaround (or if this is fixed in a newer driver), please let me know! Any advice would be appreciated.
