Hi
Installed media sdk on base Ubuntu 14.04, with i7-4760HQ, running 3.8 kernel:
# uname -r
3.8.0-23-generic
#clinfo
Name: Intel(R) Core(TM) i7-4760HQ CPU @ 2.10GHz
Vendor: Intel(R) Corporation
Device OpenCL C version: OpenCL C 1.2
Platform ID: 0x7f7146e5b920
Name: Intel(R) HD Graphics Haswell CRW GT3 Mobile
Vendor: Intel
Device OpenCL C version: OpenCL C 1.2 beignet 0.9.3
Followed the ./install.sh path, without any problems. After reboot verified correct kmd:
# lsmod | grep i915
i915 617480 2
drm_kms_helper 49196 1 i915
drm 285862 3 i915,drm_kms_helper
i2c_algo_bit 13564 1 i915
video 19652 1 i915
# dpkg -l | grep intel
ii intel-gpu-tools 1.3-0ubuntu2.1 amd64 tools for debugging the Intel graphics driver
iU intel-linux-media-dev-ubuntu 16.3.2.22368 amd64 Dev package of An Intel implementation of the DRI driver.
ii intel-linux-media-ubuntu 16.3.2.22368 amd64 An Intel implementation of the DRI driver - DRM backend.
ii libdrm-intel1:amd64 2.4.52-1 amd64 Userspace interface to intel-specific kernel DRM services -- runtime
ii xserver-xorg-video-intel 2:2.99.910-0ubuntu1.1 amd64 X.Org X server -- Intel i8xx, i9xx display driver
Rebuilt the sample directory without any errors:
make[2]: Leaving directory `/opt/intel/mediasdk/samples/__cmake/intel64.make.release'
/usr/bin/cmake -E cmake_progress_report /opt/intel/mediasdk/samples/__cmake/intel64.make.release/CMakeFiles 74 75 76 77 78 79 80 81 82 83 84 85 86 87
[100%] Built target sample_full_transcode_x11
make[1]: Leaving directory `/opt/intel/mediasdk/samples/__cmake/intel64.make.release'
/usr/bin/cmake -E cmake_progress_start /opt/intel/mediasdk/samples/__cmake/intel64.make.release/CMakeFiles 0
[ intel64.make.release State: OK ]
Verified proper library path:
# ldd ./sample_encode_drm
linux-vdso.so.1 => (0x00007fff96db4000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fa22176e000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fa221550000)
libva.so.1 => /usr/lib/x86_64-linux-gnu/libva.so.1 (0x00007fa221339000)
libdrm.so.2 => /usr/lib/x86_64-linux-gnu/libdrm.so.2 (0x00007fa22112b000)
libva-drm.so.1 => /usr/lib/x86_64-linux-gnu/libva-drm.so.1 (0x00007fa220f28000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fa220c23000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fa22091d000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fa220707000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fa220340000)
/lib64/ld-linux-x86-64.so.2 (0x00007fa22198a000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fa220138000)
However, I am not able to run the sample encoder:
# ./sample_encode_drm h264 -i ~/Videos/BasketballDrive_1920x1080_50.yuv -o ~/Videos/BasketballDrive_1920x1080_50.h264 -w 1920 -h 1080
Return on error: error code -3, /home/msdk/mdp_msdk-samples/samples/sample_encode/src/pipeline_encode.cpp 947
Return on error: error code 1, /home/msdk/mdp_msdk-samples/samples/sample_encode/src/sample_encode.cpp 439
Any help would be appreciated.
Cheers,
Never mind had to add -hw to the cli, Doh:
# ./sample_encode_drm h264 -i ~/Videos/BasketballDrive_1920x1080_50.yuv -o ~/Videos/BasketballDrive_1920x1080_50.h264 -w 1920 -h 1080 -hw
libva info: VA-API version 0.34.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Intel(R) Media SDK Encoding Sample Version 5.0.1603344.93446
Input file format YUV420
Output video AVC
Source picture:
Resolution 1920x1088
Crop X,Y,W,H 0,0,1920,1080
Destination picture:
Frame rate 30.00
Bit rate(Kbps) 3757
Target usage balanced
Memory type system
Media SDK impl hw
Media SDK version 1.10
Processing started
Frame number: 501
Processing finished
Cheers,
Glad you fixed it. The linux versions do not support SW implementation, thus -hw flag is mandatory for running the samples on linux. The help menu for sample applications could be more explicit about this, and give better error messages!
