Unable to encode YUV4:2:0 data to color JPEG image
stsybikov
I have video streaming (YUV 4:2:0 1920x1080) that comes from hardware. I was able to encode and muxing this video to MPEG2, MPEG4 and H.264 file, but I have the problem to save a single frame as jpeg file.
I have buffer with raw YUV 4:2:0 video frame (1920x1080) and using a sample code from UIC jpeg I only was able to encode the data only as image with GRAY color. I tried to manipulate with different configuration and parameters but the image file has 0 size or if the file doesn't have 0 bytes size when I try to open the image I receive the message that the file can't be opened because the file appears to be damaged, corrupted, or is too large.
Any ideas what could be wrong?
I tried to use the SaveImageJPEG functions from jpeg.cpp without and play around with data that I am passing to it. This is the sample of one of my try code before using SaveImageJPEG function
CIppImage data(1920,1080,1,8,0);
data.Attach(1920,1080,1,8, YUV_4_2_0_buffer, 0);
data.Color(IC_RGB);
data.NChannels(1);
data.Format(IF_FIXED);
data.ComponentOrder(0);
data.Sampling(IS_422);
PARAMS_JPEG params;
params.nthreads = 1;
params.color = IC_RGB;
params.huffman_opt = 1;
params.mode = JPEG_BASELINE;
params.point_transform = 0;
params.predictor = 1;
params.quality = 100;
params.sampling = IS_422;
params.dct_scale = JD_1_8;
params.use_qdct = 1;
params.tmode = 1;
params.restart_interval = 1;
params.comment_size = sizeof(params..comment);
SaveImageJPEG(......);
Thank you in advance,
Sergey
IDZ_A_Intel
Hi Sergey,
This is a question best addressed on the Intel IPP forum. Could you please post your question there for appropriate support.
http://software.intel.com/en-us/forums/intel-integrated-performance-primitives/
Petter
stsybikov
Hi, Peter:
Thank you. I will try to post there.
Sergey
