Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
Unable to get vaapipostproc element to work with `format=bgr`.
SandeshKum_S_Intel
Plugin Details:
  Name                     vaapi
  Description              VA-API based elements
  Filename                 /opt/intel/openvino_2020.2.120/data_processing/gstreamer/lib/gstreamer-1.0/libgstvaapi.so
  Version                  1.16.2
  License                  LGPL
  Source module            gstreamer-vaapi
  Binary package           gstreamer-vaapi
  Origin URL               http://bugzilla.gnome.org/enter_bug.cgi?product=GStreamer
Launching RTSP encoded stream with the following pipeline: ( videotestsrc  ! videoscale ! video/x-raw,width=1280,height=720 ! capsfilter ! queue ! x264enc speed-preset=superfast ! rtph264pay name=pay0 pt=96  )
Gstreamer Pipleline used to decode the frame and read the buffer into application from appsink: ( rtspsrc location=rtsp://localhost:8554/live.sdp latency=100 ! rtph264depay ! h264parse ! vaapih264dec ! vaapipostproc format=bgr ! videoconvert ! video/x-raw,format=BGR ! appsink )
The above gstreamer pipeline does not work and produced the following failure when tested with gst-launch-1.0 tool in GST_DEBUG mode:
0:00:02.229807981 21492 0x7f32040034f0 WARN           basetransform gstbasetransform.c:1371:gst_base_transform_setcaps:<vaapipostproc0> FAILED to configure incaps video/x-raw(memory:VASurface), format=(string)NV12, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1 and outcaps video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)30/1, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, format=(string)BGR, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, colorimetry=(string)sRGB
The vaapipostproc element works with `format=bgrx` and then videoconvert can be used to force the pixel format to BGR. But we would want the element to work with `format=bgr` itself (as bgr format is mentioned in the plugin inspect) and avoid the overhead caused by videoconvert element.
Luis_at_Intel
Hi S, Sandesh Kumar,
From the document of the vaapipostproc attributes, it doesn’t support BGR as output (src): https://gstreamer.freedesktop.org/documentation/vaapi/vaapipostproc.html?gi-language=c
This is a limitation of vaapipostproc, I am not sure if there is a way to get around it. Since vaapih264dec outputs BGRx; I think instead of removing videoconvert you could remove vaapipostproc.
Luis
SandeshKum_S_Intel
Any updates on the thread ?
Luis_at_Intel
Luis
