I'm trying to test the screen capture plugin, which is installed on my system at <media_sdk>/bin/win32/22d62c07e672408fbb4cc20ed7a053e4. However, after initializing MFX to the latest supported hardware implementation (1.20 on this machine), a call to MFXVideoUSER_Load results in MFX_ERR_NOT_FOUND. See the code excerpt below:
version.Major = 1; version.Minor = 20; res = MFXInit(MFX_IMPL_HARDWARE, &version, &session); // Check for error... res = MFXVideoUSER_Load(session, &MFX_PLUGINID_CAPTURE_HW, 1); // res == -9 is true
Here is the result of running the system analysis tool:
Intel(R) Media Server Studio 2016 R2 - System Analyzer (32-bit) The following versions of Media SDK API are supported by platform/driver [opportunistic detection of MSDK API > 1.19]: Version Target Supported Dec Enc 1.0 HW Yes X X 1.0 SW Yes X X 1.1 HW Yes X X 1.1 SW Yes X X 1.2 HW Yes X X 1.2 SW Yes X X 1.3 HW Yes X X 1.3 SW Yes X X 1.4 HW Yes X X 1.4 SW Yes X X 1.5 HW Yes X X 1.5 SW Yes X X 1.6 HW Yes X X 1.6 SW Yes X X 1.7 HW Yes X X 1.7 SW Yes X X 1.8 HW Yes X X 1.8 SW Yes X X 1.9 HW Yes X X 1.9 SW Yes X X 1.10 HW Yes X X 1.10 SW Yes X X 1.11 HW Yes X X 1.11 SW Yes X X 1.12 HW Yes X X 1.12 SW Yes X X 1.13 HW Yes X X 1.13 SW Yes X X 1.14 HW Yes X X 1.14 SW Yes X X 1.15 HW Yes X X 1.15 SW Yes X X 1.16 HW Yes X X 1.16 SW Yes X X 1.17 HW Yes X X 1.17 SW Yes X X 1.18 HW Yes X X 1.18 SW Yes X X 1.19 HW Yes X X 1.19 SW Yes X X 1.20 HW Yes X X 1.20 SW Yes X X 1.21 SW Yes X X 1.22 SW Yes X X 1.23 SW Yes X X Graphics Devices: Name Version State Intel(R) Iris(TM) Pro Graphics P6300 20.19.15.4835 Active VMware SVGA 3D 8.15.1.60 Active System info: CPU: Intel(R) Xeon(R) CPU E3-1285L v4 @ 3.40GHz OS: Microsoft Windows 10 Enterprise Arch: 64-bit Installed Media SDK packages (be patient...processing takes some time): Intel(R) Media SDK 2017 R1 Samples for Intel(R) Media SDK 2017 for Windows* Installed Media SDK DirectShow filters: Installed Intel Media Foundation Transforms: Intel(R) Quick Sync Video H.264 Encoder MFT : {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471} Analysis complete... [press ENTER]
And here are the contents of the plugin's config file:
PluginVersion = 1 APIVersion = 279 //0x0117 FileName32 = "mfxplugin32_screen_capture.dll" FileName64 = "mfxplugin64_screen_capture.dll" Type = 01 //decode CodecID = "CAPT" Default = 0
Running the screen_decode.exe sample yields a similar result.
What could be causing the API not to find the plugin?
I've updated to the latest driver and that didn't fix the problem. Also as a sanity check, I've printed out the plugin UID, which matches the folder name. I have one other plugin installed, MFX_PLUGINID_CAMERA_HW. If I ask to load that plugin, the MFXVideoUSER_Load function returns successfully.
The problem also persists in a 64-bit build.
Did you find a way to fix it? I have a similar problem.
