Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
Upscaling PAL to FullHD
Maximilian_W_
Hello There!
I'm trying to upscale the PAL (720x576@50i) signal to a progressive FullHD (1920x1080) at same fps rate, while cutting equal parts from the top and the bottom of the source picture, to gain the correct "picture aspect ratio".
My parameters look quite right for me, but i get "MFX_ERR_UNDEFINED_BEHAVIOR" error on the "MFXVideoSession::SyncOperation" call.
What i'm doing wrong? Thanks in advance!
"Intel API Implementation: MFX_IMPL_SOFTWARE Version: 1.13"
"-------VPP Parameter-------"
"AsyncDepth: 0"
"NumExtParam: 0"
"IOPattern: MFX_IOPATTERN_IN_SYSTEM_MEMORY,MFX_IOPATTERN_OUT_SYSTEM_MEMORY"
"-------VPP INPUT-------"
"BitDepthLuma: 8"
"BitDepthChroma: 8"
"Shift: 0"
"FourCC: YUY2"
"Width: 720"
"Height: 576"
"CropX: 0"
"CropY: 85"
"CropW: 720"
"CropH: 405"
"FrameRateExtN: 25000"
"FrameRateExtD: 1000"
"AspectRatioW: 0"
"AspectRatioH: 0"
"PicStruct: MFX_PICSTRUCT_FIELD_TFF"
"ChromaFormat: MFX_CHROMAFORMAT_YUV422"
"-------VPP OUTPUT-------"
"BitDepthLuma: 8"
"BitDepthChroma: 8"
"Shift: 0"
"FourCC: RGB4"
"Width: 1920"
"Height: 1088"
"CropX: 0"
"CropY: 0"
"CropW: 1920"
"CropH: 1080"
"AspectRatioW: 0"
"AspectRatioH: 0"
"PicStruct: MFX_PICSTRUCT_PROGRESSIVE"
"ChromaFormat: MFX_CHROMAFORMAT_YUV444"
Kind regards,
Max
Maximilian_W_
I solved the Problem by myself. The configurtation of input paramter was the issue:
"Width: 720"
"Height: 576"
"CropX: 0"
"CropY: 85"
"CropW: 720"
"CropH: 405"
405+2*85=575 and not 576 as supposed.
"CropH" should be changed to 406.
Nevertheless i would expect "MFX_ERR_INVALID_VIDEO_PARAM" as error.
regards,
Max
