Media (Intel® oneAPI Video Processing Library, Intel Media SDK)
Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
2945 Discussions
Use media sdk 2017 R1 to encode video will cause memory leak on intel i7-7700T
li_x_
Hi:
we used os is win7.
when input video resolution and output video reolution is different, encode will cause memory leak on i7-7700T,
if input video resolution and output video reolution is same , encode will not cause memory leak on i7-7700T.
there is no problem on other cpu(for example: i7-4770, i7-6700).
we found the function caused memory leak is RunFrameVPPAsync. maybe image scale lead to memory leak?
Best wishes!
li. x
Jiandong_Z_Intel
Hi There,
I think you may need make sure have the most graphic driver first.
https://downloadcenter.intel.com/
Zachary
