Hi:
we used os is win7.
when input video resolution and output video reolution is different, encode will cause memory leak on i7-7700T,
if input video resolution and output video reolution is same , encode will not cause memory leak on i7-7700T.
there is no problem on other cpu(for example: i7-4770, i7-6700).
we found the function caused memory leak is RunFrameVPPAsync. maybe image scale lead to memory leak?
Best wishes!
li. x
Hi There,
I think you may need make sure have the most graphic driver first.
https://downloadcenter.intel.com/
Zachary
