Dear Sir / Madam,
I 'm using Intel Media SDK 2019R1 and I complied simple_2_decode solution inside media-tutorial-0.0.4 using Visual Studio 2013
I found that when I run the following command line on my local PC
simple_decode.exe -hw jellyfish-3-mbps-hd-h264.264 output.yuv
The program can run properly.
But, if I run this command on a remote PC via Remote Desktop connection, I got the following error message:
Unsupported feature/library load error. src\simple_decode.cpp 112
(This is the error message of this function call sts = mfxDEC.QueryIOSurf(&mfxVideoParams, &Request);)
This remote PC is using CPU i7-9700 and Intel UHD Graphics 630.
So, I would like to ask whether Intel Media SDK (hardware acceleration) supports running over windows remote desktop connection or not.
I think this issue would be similar to https://community.intel.com/t5/Media-Intel-oneAPI-Video/Using-Media-SDK-samples-over-remote-desktop-... which dated back to 2011 and I don't know whether the latest Intel Media SDK has workaround on this issue or not
Edmond
Thanks for your reply.
After updating the display driver of the remote PC (Intel UHD Graphics 630) to the latest version, Intel Media SDK (with hardware acceleration) can now run over Remote Desktop Connection.
Edmond
Hi @Edmond_W ,
Thanks for reaching out. I did a quick test on one of my systems here (has an Intel® Celeron®CPU N3350 with Intel® HD Graphics 500) remotely connected with Remote Desktop Connection and the decode_sample.exe seems to run as expected.
sample_decode.exe h264 -i test_stream.264 -o output.yuv -hw
Decoding Sample Version 8.4.27.25
Input video AVC
Output format NV12
Input:
Resolution 176x96
Crop X,Y,W,H 0,0,176,96
Output:
Resolution 176x96
Frame rate 30.00
Memory type system
MediaSDK impl hw
MediaSDK version 1.32
Decoding started
Frame number: 101, fps: 111.638, fread_fps: 0.000, fwrite_fps: 4265.113
Decoding finished
I can see there is hardware acceleration when remotely connected with RDC so Intel® Media SDK seems to support it. If you run the decode_sample.exe on such machine directly (without RDC), does the sample execute correctly?
An observation from your command, please try specifying the codec (h264) see if that makes any difference:
simple_decode.exe h264 -i jellyfish-3-mbps-hd-h264.264 -o output.yuv -hw
Luis
Edmond
