Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
Using Timestamps to Syncronize Display of Decoded Video
simerly__tim
Dear Tech Support:
I am using the Intel Media SDK to decode an H.264 bitstream and needing to use timestamps to synchronize the displaying of the video frame.  I don't see the sample code addressing how to go about doing using a timestamp to render the recently decoded frame.  Per the sample code that is provided, there is a m_d3dRender.RenderFrame( frame, m_pGeneralAllocator ); call that I assume displays the newly decoded frame shortly thereafter.  Is this the place where I determine exactly when to render the frame based on a timestamp or is there a better way of doing this using the Media SDK example code?  Please advise.
Tim
Stefan_S_2
Hello Tim,
the timestamp of the decoded frame can be found in the surface data:
mfxFrameSurface1 -> mfxFrameData -> TimeStamp
Stefan.
simerly__tim
Hey Stefan:
Ok, thanks for the info on this.
Tim
