Community
cancel
Showing results for
Search instead for
Did you mean:
Wonseok_S_
Using VPP with P010 format
I've test of convert P010 to NV12 color using sample_vpp project in media sdk sample 6.0.0.142
sample info :
- FourCC : P010
- resolution : 3840 x 2160
Question 1
step 1 : Fix function Str2FourCC() as below
static mfxU32 Str2FourCC( msdk_char* strInput )
    mfxU32 fourcc = MFX_FOURCC_YV12;//default
	else if ( 0 == msdk_strcmp(strInput, MSDK_STRING("p010")) )
		fourcc = MFX_FOURCC_P010;
    return fourcc;
} // mfxU32 Str2FourCC( msdk_char* strInput )
step 2 : Fix function InitParamsVPP() as below
mfxStatus InitParamsVPP(mfxVideoParam* pParams, sInputParams* pInParams)
  /* input data */
  pParams->vpp.In.FourCC          = pInParams->inFrameInfo[VPP_IN].FourCC;
  if ( MFX_FOURCC_P010 == pInParams->inFrameInfo[VPP_IN].FourCC )
	  pParams->vpp.In.BitDepthChroma = 10;
	  pParams->vpp.In.BitDepthLuma = 10;
When run project with option
-lib hw -sw 3840 -sh 2160 -scc p010 -i p010.yuv -o nv12.yuv
MFXVideoVPP_Init() function returns -15
there is input/output video parameter set on runtime debugging.
The tests with other input color format (YV12) shows correct result and converted image.
The SDK documentation (https://software.intel.com/sites/default/files/managed/47/49/mediasdk-man.pdf) describes it's able to convert P010 to NV12 with VPP.
Question 2.
This test was done with option -lib hw.
In CreateFrameProcessor() function, mfxSession initialize with HW implementation and returns MFX_ERR_NONE,
but in function PrintInfo() function, pMfxSession->QueryIMPL(&impl); function set impl with 517 and describe as SW implementaion.
I want to know VPP can run with HW implementation?
Could anybody tell me how to solve this problem?
Surbhi_M_Intel
Looking at it now, will try to reproduce the issue at our end and get back soon to you.
Surbhi_M_Intel
Hi Wonseok,
Sample_vpp doesn't support P010 color format by default so it need few changes in the application, please add P010 color format in multiple functions where this format is missing - theConverColortFormat(), LoadNextFrame(), FourCC2Str() and ConvertMfxFourccToD3dFormat(). Please add the color format, build sample and run the application again.
Surbhi
Wonseok_S_
Thanks, Surbhi.
I'd prove that problem with your help.
