I've test of convert P010 to NV12 color using sample_vpp project in media sdk sample 6.0.0.142
sample info :
- FourCC : P010
- resolution : 3840 x 2160
Question 1
step 1 : Fix function Str2FourCC() as below
static mfxU32 Str2FourCC( msdk_char* strInput )
mfxU32 fourcc = MFX_FOURCC_YV12;//default
else if ( 0 == msdk_strcmp(strInput, MSDK_STRING("p010")) )
fourcc = MFX_FOURCC_P010;
return fourcc;
} // mfxU32 Str2FourCC( msdk_char* strInput )
step 2 : Fix function InitParamsVPP() as below
mfxStatus InitParamsVPP(mfxVideoParam* pParams, sInputParams* pInParams)
/* input data */
pParams->vpp.In.FourCC = pInParams->inFrameInfo[VPP_IN].FourCC;
if ( MFX_FOURCC_P010 == pInParams->inFrameInfo[VPP_IN].FourCC )
pParams->vpp.In.BitDepthChroma = 10;
pParams->vpp.In.BitDepthLuma = 10;
When run project with option
-lib hw -sw 3840 -sh 2160 -scc p010 -i p010.yuv -o nv12.yuv
MFXVideoVPP_Init() function returns -15
The tests with other input color format (YV12) shows correct result and converted image.
The SDK documentation (https://software.intel.com/sites/default/files/managed/47/49/mediasdk-man.pdf) describes it's able to convert P010 to NV12 with VPP.
Question 2.
This test was done with option -lib hw.
In CreateFrameProcessor() function, mfxSession initialize with HW implementation and returns MFX_ERR_NONE,
but in function PrintInfo() function, pMfxSession->QueryIMPL(&impl); function set impl with 517 and describe as SW implementaion.
I want to know VPP can run with HW implementation?
Could anybody tell me how to solve this problem?
Looking at it now, will try to reproduce the issue at our end and get back soon to you.
Hi Wonseok,
Sample_vpp doesn't support P010 color format by default so it need few changes in the application, please add P010 color format in multiple functions where this format is missing - theConverColortFormat(), LoadNextFrame(), FourCC2Str() and ConvertMfxFourccToD3dFormat(). Please add the color format, build sample and run the application again.
Surbhi
Thanks, Surbhi.
I'd prove that problem with your help.
