Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
Using the output of a decoder (video_memory) in many encoders or vpp processors.
cedronius__anders
My decoder outputs a mfxFrameSurface1* (MFX_IOPATTERN_OUT_VIDEO_MEMORY) . Feeding one Encoder is simple and you basically just feed the mfxFrameSurface1* and off you go.
However since a session only supports one decoder/encoder/vpp adding another decoder to consume the  mfxFrameSurface1* is not possible as I understand it.
I tried feeding the mfxFrameSurface1* to multiple encoders but then I get ->
intel_transcoder: /opt/src/msdk/_studio/mfx_lib/shared/src/mfx_h264_encode_vaapi.cpp:3026: virtual mfxStatus MfxHwH264Encode::VAAPIEncoder::Execute(mfxHDLPair, const MfxHwH264Encode::DdiTask&, mfxU32, const MfxHwH264Encode::PreAllocatedVector&): Assertion `0x00000000 == vaSts' failed.
I guess it's due to the other encoders are using the same buffer in other sessions.
So I realise the 'problem' is that i need som kind of buffer management between the Producer (decoder) and Consumers (Encoder / VPP).
Is there a copy mfxFrameSurface1*?
I've looked at the multi-transcode sample but it's several 100kb of code and just too complex to understand for me what it's doing and there is no 'simple' multi_transcode example available that i've found.
My system is :
Ubuntu 20.04
bva info: VA-API version 1.10.0
libva info: User environment variable requested driver 'iHD'
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_9
libva info: va_openDriver() returns 0
MSDK 1.34
Is there a simple up to date information about how to feed multiple consumers a mfxFrameSurface1* that resides in the video memory?
Thanks for helping,
/Anders
Mark_L_Intel1
Hi Anders,
Did my answer solved your question?
Mark
cedronius__anders
I meant to write ->  "adding another encoder to consume the  mfxFrameSurface1* is not possible as I understand it."
AthiraM_Intel
We are forwarding your case to Subject matter Experts.
Mark_L_Intel1
Hi Anders,
Sorry for the late response. There seem to be 2 questions: multiple session and memory locking. Media SDK don't have specific memory locking APIs, so the general memory management should work.
For multi-session, would following document be helpful?
https://github.com/Intel-Media-SDK/MediaSDK/blob/master/doc/mediasdk-man.md#multiple-sessions
Mark
Mark_L_Intel1
Hi Anders,
Mark
