Community
cancel
Showing results for
Search instead for
Did you mean:
duncanchou
VAAPI MSDK CPU usage too heavy
Jump to solution
Hello Sir,
We decoded the h264 video file to RGB by sample_decode of  mediasdk, we found the CPU usage is  too heavy 100.7 %, is it correct? or some setting  we missed?
Michael Wu
duncanchou
Hello Mark,
I  understand them clearly from your answer now.
Thank you for your help.
Michael Wu
Mark_L_Intel1
Hi Michael,
It seems you are running on Open Source Media SDK 20.2.0 or 20.2.1. Yes I think the CPU usage is too heavy so not sure if this related to I/O or hardware codec enabling.
What's your environment, a Linux host, VM or Docker?
What's the Intel processor are you using?
You can also try followings:
  • Remove the output see if the CPU usage improved:./sample_decode h264 -i <input.h264> -rgb4 -hw -vaapi
  • Change the output format: ./sample_decode h264 -i <input.h264> -o output.yuv -hw -vaapi
  • Enable GPU copy: /sample_decode h264 -i <input.h264> -o output.yuv -hw -vaapi -gpucopy::on
Mark
duncanchou
Hello Mark,
We found remove the "-vaapi" and added  "-gpucopy::on" parameter, the performance will be improved and very good.
BTW
What difference between with and without  "-vaapi"?
And
#What's your environment, a Linux host, VM or Docker?
====> Linux host
#What's the Intel processor are you using?
====> Atom E3950
The attached is some test pictures. (Test_Record_0924_1.doc)
Thanks for your support.
Michael Wu
Mark_L_Intel1
Hi Michael,
Thanks for the detailed test results and comparison.
It is good to see that performance got improved but I am still not understand why removing "-vaapi" will improve it. The fact that you are using Apollo Lake(E3950) should limited the usage of video memory. This is '-vaapi' mean: "work with vaapi surfaces". Here it should means video memory, this should improve the copying speed in geneory, but let me ask dev team.
Did you also try to remove "-rgb4" and see if the performance improved?
By the way, you can check the online sample documentation here by going to "sample" subdirectory:
https://github.com/Intel-Media-SDK/MediaSDK/tree/master/doc
Mark
duncanchou
Hello Mark,
If we remove the -rgb4, a little improved the performance,
FPS is from 15 to 22, CPU usage is from 100 to 99....
The attached is our testing picture Test_Record_0925.doc .
Michael Wu
Mark_L_Intel1
Hi Michael,
Thanks for the testing, it seems -rgb4 is not the main bottleneck here.
For your question: "What difference between with and without "-vaapi"?" We have following analysis on sample_decode:
The expected results (from best to worst) are:
1) “-vaapi” – output surface in video memory without touching (e.g. dumping to file) them on CPU
2) “-o” – output surface in system memory with touching them on CPU (copy video->system memory is inside MSDK).
3) “-o -vaapi” – output surface in video memory with touching them on CPU (copy video->system memory is on app level).
So your first result is expected, since it is the worst cast in above list.
Mark
duncanchou
Hello Mark,
Michael Wu
Kimi1
Hi Mark,
I have the same problem. I want to ask you about the third case.(“-o -vaapi” – output surface in video memory with touching them on CPU (copy video->system memory is on app level)
In this case,How can we improve copy efficiency from video memory to system memory?  (copy video->system memory is on app level) Because we should use the data in system memory.
James
