VP8 decode problem
yuxiao_z_
I used sample_decode to decode test_stream_vp8.ivf but failed with Segmentation fault (core dumped). Can you tell me what to do?
The command is: ./sample_decode vp8 -hw -vaapi  -i test_stream_vp8.ivf -o out.yuv -p f622394d8d87452f878c51f2fc9b4131
uname -r  shows:  3.10.0-229.1.2.47109.MSSr1.el7.centos.x86_64
Surbhi_M_Intel
Sorry for the late response. Is your system 4th or 5th generation Intel core system? If so, check plugins.cfg file at /opt/intel/media/plugins for VP8 decoder. If Vp8 decoder isn't mentioned then add below to cfg file and run the cmd line. It should work.
[VP8_Decoder_f622394d8d87452f878c51f2fc9b4131]
GUID = f622394d8d87452f878c51f2fc9b4131
PluginVersion = 1
APIVersion = 273
Path = /opt/intel/mediasdk/plugins/libmfx_vp8d_hw64.so
Type = 1
CodecID = VP8
Default = 0
If you still see an issue, please let us know.
Surbhi
yuxiao_z_
Hi, Surbhi
Thank you for your response.
We used Intel E3 v3 system. I checked plugin.cfg file, and it already contained the information of VP8 decoder. A file named libmfx_vp8d_hw64.so is in /opt/intel/mediasdk/plugins.
the sample_decode still doesn't work with the cmd line I mentioned above.
Best Wishes,
Yuxiao
Surbhi_M_Intel
Hi Yuxiao,
Can you tell about your system details - CPU, OS, Media Server Studio version?
output of cmd - vainfo and uname -r
Are you able to run h264 decode?
-Surbhi
yuxiao_z_
Hi, Surbhi,
CPU: Intel Xeon E3-1276 v3;
OS: CentOS 7
MSS Version: 16.4.4-47109.el7.x86_64
vainfo:
error: can't connect to X server!
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.99 (libva 1.67.0.pre1)
vainfo: Driver version: 16.4.4.47109-ubit
vainfo: Supported profile and entrypoints
      VAProfileH264Baseline           :	VAEntrypointEncSlice
      VAProfileH264Baseline           :	<unknown entrypoint>
      VAProfileH264ConstrainedBaseline:	VAEntrypointVLD
      VAProfileH264ConstrainedBaseline:	VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline:	<unknown entrypoint>
      VAProfileH264Main               :	VAEntrypointVLD
      VAProfileH264Main               :	VAEntrypointEncSlice
      VAProfileH264Main               :	<unknown entrypoint>
      VAProfileH264High               :	VAEntrypointVLD
      VAProfileH264High               :	VAEntrypointEncSlice
      VAProfileH264High               :	<unknown entrypoint>
      VAProfileMPEG2Simple            :	VAEntrypointEncSlice
      VAProfileMPEG2Simple            :	VAEntrypointVLD
      VAProfileMPEG2Main              :	VAEntrypointEncSlice
      VAProfileMPEG2Main              :	VAEntrypointVLD
      VAProfileVC1Advanced            :	VAEntrypointVLD
      VAProfileVC1Main                :	VAEntrypointVLD
      VAProfileVC1Simple              :	VAEntrypointVLD
      VAProfileJPEGBaseline           :	VAEntrypointVLD
      VAProfileJPEGBaseline           :	VAEntrypointEncPicture
      VAProfileVP8Version0_3          :	VAEntrypointEncSlice
      VAProfileVP8Version0_3          :	VAEntrypointVLD
      VAProfileVP8Version0_3          :	<unknown entrypoint>
      VAProfileHEVCMain               :	VAEntrypointEncSlice
      VAProfileVP9Profile0            :	VAEntrypointEncSlice
      VAProfileVP9Profile0            :	VAEntrypointVLD
      VAProfileVP9Profile0            :	<unknown entrypoint>
      <unknown profile>               :	VAEntrypointVideoProc
      VAProfileNone                   :	VAEntrypointVideoProc
      VAProfileNone                   :	<unknown entrypoint>
uname -r:
There is no problem with h264 decoding.
Yuxiao
Surbhi_M_Intel
Yuxiao - Everything looks normal, please send us the error output of the sample run. So far I am not able to reproduce the locally here.
yuxiao_z_
Hi, Surbhi,
Output is shown as below. The Chinese words is segmentation fault (core dumped) in English.
[root@localhost release]# ./sample_decode vp8 -hw -vaapi  -i test_stream_vp8.ivf -o out.yuv -p f622394d8d87452f878c51f2fc9b4131
plugin_loader.h :170 [INFO] Plugin was loaded from GUID: { 0xf6, 0x22, 0x39, 0x4d, 0x8d, 0x87, 0x45, 0x2f, 0x87, 0x8c, 0x51, 0xf2, 0xfc, 0x9b, 0x41, 0x31 } (Unknown plugin)
pretending that stream is 30fps one
Decoding Sample Version 0.0.000.0000
Input video    VP8
Output format    NV12
Input:
  Resolution    176x96
  Crop X,Y,W,H    0,0,176,96
Output:
  Resolution    176x96
Frame rate    30.00
Memory type        d3d
MediaSDK impl        hw
MediaSDK version    1.17
Decoding started
段错误(吐核)
Surbhi_M_Intel
Are you using pre compiled binaries? Seems like the error in the cleaning up the resources or closing the file.
-Surbhi
