VPP HW Impl blurs Text Image
Ramashankar
New Contributor III
I am using vpp samples from Intel Media SDK Samples 2016 6.0.0.142 and Intel(R)_Media_SDK_2016.0.1. I need to convert RGB32 (BGRA) frames into NV12 and pass them to h264 encoder.
I am observing that HW implementation of VPP is blurring the text images portion in output frame, but if I use SW implementation then conversion is perfectly fine. In HW impl, part of text (specifically the vertical lines area) are slightly reddish or blueish. Please refer the attachment.
Can you let me know if it is any known bug in VPP or Graphics driver? How to correct it and make it with same quality as in SW impl? I prefer not to use SW impl of VPP considering the speed factor.
i. sys_analyzer.txt: system analyzer log (Env: Win8.1 (64 bit), HD Graphics 4400, driver 10.18.14.4414)
ii. VppIn.bgr: input frame in BGRA format
iii. VppOut_HW.nv12: output nv12 frame generated through HW impl
iv. VppOut_SW.nv12: output nv12 frame generated through SW impl
v. Compare.jpg: snap shot of both output frame with highlighting the issue
Anna_B_Intel
Hi Ramashankar,
Could you please provide me command line parameters that you used for running sample_vpp?
Best wishes,
Anna
Ramashankar
New Contributor III
Hi Anna,
I used following command line parameters:
1. sample_vpp -i VppIn.bgr -sw 1920 -sh 1080 -scc rgb4 -dw 1920 -dh 1080 -dcc nv12 -lib hw -o VppOut_HW.nv12
2. sample_vpp -i VppIn.bgr -sw 1920 -sh 1080 -scc rgb4 -dw 1920 -dh 1080 -dcc nv12 -lib sw -o VppOut_SW.nv12
Anna_B_Intel
I reproduced the issue. I'll keep you in touch about further investigations.
Best wishes,
Anna
Ramashankar
New Contributor III
Is there any update on this?
Anna_B_Intel
Hi Ramashankar,
It's driver problem. Dev team is working on a solution now.
Best wishes,
Anna
Ramashankar
New Contributor III
Hi Anna,
Thanks for the update, glad to know that this issue is being fixed. It would be helpful if you can share the tentative timeline by when we get the fix.
Anna_B_Intel
One quick question: are you ok to use d3d11?
Best wishes,
Anna
Ramashankar
New Contributor III
Yes, but I am already using d3d11 memory on Windows8 onwards, and system memory or d3d9 memory on windows7 OS (as my product needs to support all OS from Win7 onwards).
Are you not seeing this issue if use d3d11? I observed this issue first on Win8.1 OS using d3d11 itself.
Anna_B_Intel
The question was about the fix. So we can only fix it for d3d11.
Best wishes,
Anna
Ramashankar
New Contributor III
Ok. Though I need the fix for windows7 OS also(i.e. using system or d3d9 memory), but if d3d11 fix is quick I can start using that at least for windows8 and 10 also.
Ramashankar
New Contributor III
Hi Anna,
Anna_B_Intel
Hi Ramashankar,
We are working on solution, but for now I can't say exactly when the fix will be ready. I'll keep you in touch.
Best wishes,
Anna
Ramashankar
New Contributor III
OK. Thanks for the information, I will wait for your update.
Ramashankar
New Contributor III
Hi Anna,
Is there any development on this? It would be very helpful if you can provide any tentative timeline for this fix,
~ Thanks,
Ramashankar
New Contributor III
Hi Anna,
Waiting for your reply. Is there any update on this?
Ramashankar
New Contributor III
Hi Anna,
Has Intel fixed this issue in driver? Please let me know if there is any update.
Ramashankar
New Contributor III
Still no reply :(
Dear Intel team members,
Please let me know if this issue has been fixed in any recent release of graphics driver or media sdk.
Avulapati__Balakrish
I am facing the same issue. Worried to see this post being unresolved from past 2 years.
Ramashankar
New Contributor III
Is anyone from intel team looking in to this issue? It is causing severe quality issue. Please provide some solution for this.
Mark_L_Intel1
Hi Ramashankar,
I am routed by your other post and I checked all the information, it looks like you want to port the solution of d3d11 to d3d9 on Win7.
The difficulty of this request is to address the legacy platform which might be out of life cycle, also this involves different team internally. So let me check the status and get back to you.
Mark
