VPP NV12 to YV12 Conversion?
Bob_Kirnum
Can the VPP be used to convert from the decoded NV12 to YV12?  I know it can be used to convert YV12 to NV12 for input to the encoder, this works for me.  I have been attempting to do this for decoding but I always get the unsupported error when calling the VPP Query with the video parameters initialized for this conversion.  Our application expects YV12 frames and I can use the IPP for this conversion but expect the VPP to be more efficient.
My debug output dump of the VPP video parameters before and after the call to VPP Query.  Note that after the error, the FourCC Out value is 0.
     56016: src/VtpXcoderMFX.cpp.4000:AllocFrames: mfxVideoParamVPP: AsyncDepth 4 Protected 0 IOPattern 33( IN_VIDEO OUT_SYSTEM) ExtParam 0x7f53d80ee7e0 NumExtParam 1
     56016: src/VtpXcoderMFX.cpp.4000:AllocFrames: mfxVideoParamVPP: vpp:  In Width 640 Height 480 Crop (0, 0, 640, 480) FourCC NV12 FrameRateExt (30, 2) AspectRatio (1, 1) PicStruct 1 ChromaFormat 1(YUV420)
     56016: src/VtpXcoderMFX.cpp.4000:AllocFrames: mfxVideoParamVPP: vpp: Out Width 640 Height 480 Crop (0, 0, 640, 480) FourCC YV12 FrameRateExt (30, 2) AspectRatio (1, 1) PicStruct 1 ChromaFormat 1(YUV420)
     56020: src/VtpXcoderMFX.cpp.4020:AllocFrames: -3(MFX_ERR_UNSUPPORTED) = m_pmfxVPP->Query(0x7f53d80ee6c0, 0x7f53d80ee6c0) m_bSysmemBetween false
     56020: src/VtpXcoderMFX.cpp.4024:AllocFrames: mfxVideoParamVPP: AsyncDepth 4 Protected 0 IOPattern 33( IN_VIDEO OUT_SYSTEM) ExtParam 0x7f53d80ee7e0 NumExtParam 1
     56020: src/VtpXcoderMFX.cpp.4024:AllocFrames: mfxVideoParamVPP: vpp:  In Width 640 Height 480 Crop (0, 0, 640, 480) FourCC NV12 FrameRateExt (30, 2) AspectRatio (1, 1) PicStruct 1 ChromaFormat 1(YUV420)
     56020: src/VtpXcoderMFX.cpp.4024:AllocFrames: mfxVideoParamVPP: vpp: Out Width 640 Height 480 Crop (0, 0, 640, 480) FourCC      FrameRateExt (30, 2) AspectRatio (1, 1) PicStruct 1 ChromaFormat 1(YUV420)
Thanks, Bob.
koby_s_
Hi Bob
According to the SDK API reference manual (page 7, table 2) - it is not possible to convert NV12 to YV12.
YV12 is not even mentioned as an output color space in that table.
Maybe I am wrong and I suggest for you to wait for someone from Intel..
Koby
Bob_Kirnum
Hey Koby
The encoder and decoder only support NV12 for sure.  The VPP does support YV12 to NV12 conversion.  I use this in my pipeline as input to the encoder.  I would expect that the reverse conversion also be supported but I have had no success.  Hopefully, Intel will respond soon.
Thx Bob
Harshdeep_B_Intel
Hi Bob,
In general, MediaSDK's default format is NV12. Most of the encoders/decoders only work with NV12, with exception of JPEG/MJPEG. VPP can help with converting to/from other formats in several cases, but software or OpenCL color conversion or IPP may be required if the conversion is not on the VPP's short list ( as koby mentioned above "SDK API reference manual (page 7, table 2)"). In this particular case VPP won't help as it can perform YUV12in/NV12out but not the reverse. Just mentioning this to illustrate the design.
Bob_Kirnum
Thanks Harsh.  I have the IPP working fine for NV12 to YV12 in the decode direction.  Also have the VPP working fine for YV12 to NV12.  Always love asymmetry,
Bob
Harshdeep_B_Intel
Great Bob, you have things working. So, then we will go ahead and close this thread as resolved. Please feel free to start a new thread if any further questions on the forum.
