VPP SampleCamera.exe is not able to generate ARGB64 bit output
VnsMurthy_S_Intel
Hello
I am using Intel 6th generation Intel system with the latest Graphics driver update, i have installed Intel SDK 2016 R2 version already and Intel Media SDK Samples 2016 6.0.0.142 samples version
OS : WIndows 10,
sample_camera.exe is working fine with the below command,
sample_camera.exe -i test_RAW14.bin -w 5494 -h 4114 -f rggb -b 14 -a 3 -o test
it generates test.bmp file which is fine of ARGB8 format, But when i pass arguement as -of 16 it returns me error
sample_camera.exe -i test_RAW14.bin -w 5494 -h 4114 -f rggb -b 14 -a 3 -of 16 -o test
Return on error: error code -3, src\sample_camera_utils.cpp     144
Return on error: error code -3, src\pipeline_camera.cpp 391
Return on error: error code -3, src\pipeline_camera.cpp 1042
Return on error: error code 1,  src\sample_camera.cpp   605
Can some one help me with the issue?
Please help me with above issue.
Murthy
Jiandong_Z_Intel
Hi Murthy,
Can you share me your test_RAW14.bin  if possible ?
I will check with team internal and get back to you.
Zachary
VnsMurthy_S_Intel
Hello Zachry,
Attaching the bin file
509498
Jiandong_Z_Intel
Hi Murthy,
I can't reproduce this issue on my end. I use your input test_RAW14.zip , and it work for me to use following command line -
$ sample_camera.exe -i test_RAW14.bin -w 5494 -h 4114 -f rggb -b 14 -a 3 -of 16 -o zach
Intel(R) Camera SDK Sample Version 6.0.0.49
Input format R16
Resolution 5504x4128
Crop X,Y,W,H 0,0,5494,4114
Frame rate 24.00
Output format YV12
Frame rate 24.00
Memory type system
MediaSDK impl hw
MediaSDK version 1.17
Camera pipe started
Total frames 1
Total time 0.81 sec
Total FPS 1.23 fps
Camera pipe finished
my configure like below:
Intel(R) Media Server Studio 2016 R2 - System Analyzer (64-bit)
Graphics Devices:
        Name                                         Version             State
        Intel(R) HD Graphics 520                     20.19.15.4424       Active
System info:
        CPU:    Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz
        OS:     Microsoft Windows 10 Enterprise
        Arch:   64-bit
MSDK sample: Samples for Intel Media Client version 6.0.0.49
Zachary
keiyuen__feng
hey,can i use sample_camera.exe to capture screen my desktop??
Jiandong Z. (Intel) wrote:
Hi Murthy,
Input format R16
Frame rate 24.00
Output format YV12
Frame rate 24.00
Memory type system
MediaSDK impl hw
Camera pipe started
Total frames 1
Total time 0.81 sec
Total FPS 1.23 fps
Graphics Devices:
        Name                                         Version             State
System info:
        Arch:   64-bit
Zachary
Mark_L_Intel1
Hi keiyuen,
Could you make the request in different post?
You can check the following article for screen capture but we are no long support this feature.
https://software.intel.com/en-us/articles/intel-media-sdk-screen-capture
Mark
